Alan Ambrose Posted Saturday at 20:53 Posted Saturday at 20:53 It's been recommended I use KompeFix ventilation strip to keep the wood wall battens and horizontal cladding apart - presumably to avoid trapping moisture between adjacent wood and allow for a little movement. That is: https://www.russwood.co.uk/shop/product/kompefix/ It's only GBP 2.22 per m - which sounds OK value until I figured out I needed about 750m / 1,700 quids worth. Are there any good alternatives?
JohnMo Posted Saturday at 21:40 Posted Saturday at 21:40 45 minutes ago, Alan Ambrose said: Are there any good alternatives? Fix without them? 2
Onoff Posted yesterday at 05:45 Posted yesterday at 05:45 Being (half) silly...3D print the profile in say PETG as short strips with fixing slots in. Then glue on. You'd just import the profile above, convert to an SVG file and extrude, a doddle. Roughly a full infill, (solid), 250mm strip would weigh 34g. You could print diagonal on the bed to get a longer length but for batch printing a few at a time you'd have to work with the 256x256 bed. Out of a kilo of filament then you'd get 30 strips. 30 x 256mm is nom 7.7m. A kilo roll of PETG filament is circa a tenner on Amazon. So about £1.30/m Half the price! You could have that again as the strips wouldn't need to be full infill. Just add in the cost of your time, electric and buying a printer! 😂 1
MikeSharp01 Posted yesterday at 11:01 Posted yesterday at 11:01 We have purchased this with our cladding and they estimated 16 rolls, our cladding is vertical, I did the calcs and got a couple of rolls less but stuck with the estimate. We are not using their battening system as we don't have the depth. Instead I will make up some custom notched battens that create the air gap at the back, have the top slope and allow the use of the Kompefix on the front face. 1
mjc55 Posted 21 hours ago Posted 21 hours ago Hmm. Is this not an (expensive) solution looking for a problem? 2
MikeSharp01 Posted 10 hours ago Posted 10 hours ago 10 hours ago, mjc55 said: Hmm. Is this not an (expensive) solution looking for a problem? Could be - but at least I am following the manufacturers recommendations so I should be able to have some comeback if it does not work. This is the drawing I will be following in spirit at least.
Alan Ambrose Posted 7 hours ago Author Posted 7 hours ago I would have expected the slope to drain outwards, no?
G and J Posted 7 hours ago Posted 7 hours ago We've followed the above (vertical cladding) the first vertical batten means the slope on the second horizontal batten allows the water to run off into the cavity....or at least that's the plan!
BotusBuild Posted 6 hours ago Posted 6 hours ago Ooh, must remove the horizontal battens already installed and introduce them to a power tool 🙂 Won't bother with the spacers. Waste of time and money IMHO.
JohnMo Posted 5 hours ago Posted 5 hours ago Are you all have open cladding, so you do get plenty of driven water in there? Otherwise a little OTT. I would be more interested to see how you are keeping wasps out, one small crack or warp they seem to get behind the cladding, then they start building nests.
saveasteading Posted 4 hours ago Posted 4 hours ago 40 minutes ago, JohnMo said: keeping wasps out, one small crack or warp 1mm gap in our weatherboard seems to be enough. Which reminds me I didn't fill over last year's. On 23/05/2026 at 23:40, JohnMo said: Fix without them? I can see the point, as a direct batten contact will hold water, then algae and moss. Fine if you want to see it revert to nature as some Architects have been heard to say to justify "eco" products. All these ledges would need a lot of cleaning otherwise. @Alan Ambrose what type of timber? The £1700 would be a lot in comparison with pine, but not with more exotic types.
Alan Ambrose Posted 1 hour ago Author Posted 1 hour ago I can see this kind of thing which is about 1/2 the price and 1mm thick: https://direct.marley.co.uk/products/marley-weatherboard-epdm-tape
MikeSharp01 Posted 50 minutes ago Posted 50 minutes ago 4 hours ago, JohnMo said: Are you all have open cladding, Ours is closed, tung & groove, detail is the same though. If the drops are long you need a gap at the joins. I am hoping we don't need them.
