Basic question - should there be a rubber washer / seal on this connection on the tap to the HDPE connection (would have thought it would be supplied).
Thread dia is 25mm and as the photo shows, even when just nipped up, it’s off centre.
Use a thread sealant, I like to use Loctite 55.
Some versions of that tap come with PTFE tape to seal the thread.
PTFE tape, applied so turning the tap in doesn't unravel the tape, and stop turning it into the fitting before it gets completely fully home. 21 full turns on a 3/4” thread should be Ok.
The thread is 3/4” BSP, none of the threads you’ll see are metric ;); 1/2” (15mm) > 3/4” (22mm) > 1” (28mm).
Check you're not cross-threading the tap into the plastic fitting, as it should be straight. PTFE is forgiving, so even if out a bit you should be leak free.
11 minutes ago, Nickfromwales said:
fully home.
Is there truth, as I've had it said, that you can't turn it back again if it's not sitting quite right?
I thought the idea was that the fibres expand when the pressure reaches them. And I have turned some back without problems.
Yup. Even 1/4 - 1/2 a turn back off can cause it to leak.
Needs taking off, cleaning, re-taping, and doing again if so.
