divorcingjack Posted January 31, 2018 Posted January 31, 2018 Morning all, Finally, we can see the light at the end of the tunnel with the zinc portion of our cladding nearly complete, so we can now think seriously about the brick portion. Our architect has specified a painted, bag rubbed finish, using reclaimed bricks - so it doesn't look "too perfect". The approx 120 sqm cladding is going on the outside of an MBC frame, just single skin, nothing too complicated. Zinc infill panels above windows. So, two questions: - What should I expect to be paying (scotland) either for the whole job or on an daily rate? We are supplying the bricks - probably reclaimed Victorian - Do I need to think about thermally efficient wall ties/fixings? If so, what should I be looking at? Cheers for any help, dj
Ian Posted January 31, 2018 Posted January 31, 2018 32 minutes ago, divorcingjack said: - Do I need to think about thermally efficient wall ties/fixings? If so, what should I be looking at? Normally the cavity between the timber frame and any external weather skin such as your brickwork should be ventilated top & bottom of the wall so I don't see the point in paying for thermally efficient wall ties. The standard SS ones will do. 1
Brickie Posted January 31, 2018 Posted January 31, 2018 If their to be painted then why the need for reclaims? There’s an imitation London Stock down here (brand new & much cheaper) that I’ve had the misfortune to have supplied to me by builders. If it’s imperfections you’re after...Jeez,the back of a brick on edge capping I did looked like a piano keyboard,that much variation in length. So Id guess your merchants up your way would do a cheap imitation of the local bricks too. If it were me,I’d be tempted to get brand new common flettons & give them a spin in the mixer for a minute before use,to rough them up a bit. Not really practical if you’ve got a big volume to lay though. 1
divorcingjack Posted February 12, 2018 Author Posted February 12, 2018 Just an update on this post for all those sourcing bricks at the minute (although it may apply only to Scotland). I spoke to a few reps and the "reclaimed style" of new bricks are horrifically expensive (approaching £1/brick or more), have to be specially ordered from outside the country and because we're not taking a full load - none of the merchants will order them for us anyway! I was also warned that because so many social housing projects are ordering millions of bricks at a time, lead times at the moment are STARTING at 26 weeks. So, I drove 10 minutes up the road to a demolition guy and picked up some sample reclaims. They weigh a ton, but the contractor says they're solid and shouldn't give us any problems. We'll see what the guy who has to lay them has to say ...
divorcingjack Posted February 12, 2018 Author Posted February 12, 2018 On 1/31/2018 at 13:51, Brickie said: If it were me,I’d be tempted to get brand new common flettons & give them a spin in the mixer for a minute before use,to rough them up a bit. Not really practical if you’ve got a big volume to lay though. Sounds a great idea, but we've got 7000 to lay. Reckon we'd go through a few mixers by the end of that! The reclaims I've found are coming out cheaper than new anyway, hopefully the brickie will agree to lay them.
PeterW Posted February 12, 2018 Posted February 12, 2018 I did the same - got Cottage reclaim blend from TP at £465/Thou and got my bricky on them at £500/thou laid. They were a bit of a mare as it was +/-15mm on pretty much every dimension but they look good now they are done. We reckon we nearly broke the hiab on the wagon as they could barely pick them up - guessing they were 3lb each on some of them ! 1
divorcingjack Posted April 4, 2018 Author Posted April 4, 2018 Just to update on this with a frankly ambitious quote from one brickie - we managed to source reclaims and have had half delivered already. The other half are another story - the guy is a bit dodgy to say the least, so we may have to get a threatening gang together to get the rest They weigh an absolute ton, but will look great once laid. So we had a brickie round yesterday who offered to have 2 gangs on site, and said they could lay 2000 bricks/day. All looked good while he was on site, but then he has sent us a labour only quote of £60/sqm for single skin. No lintels (zinc panels above windows), no decorative anything or fiddly details. The bricks are to be painted, so we don't require an absolutely perfect finish. We have a total area of 120 sqm with potential for additional work for a large garden wall as well. Am I right in thinking this is a little toppy, to say the least? Could anyone with SPONS give me an idea of recommended prices either /1000 bricks laid or psqm for single skin, facing reclaimed bricks? We are supplying the bricks, ties and all materials. Cheers, dj
RichS Posted April 4, 2018 Posted April 4, 2018 (edited) I don't have SPONS so can't help you there but that price relates to £1.00 per brick where as @PeterW paid 0.50p a brick so I'd go with the "bit pricey" analogy. Edited April 4, 2018 by RichS
Brickie Posted April 4, 2018 Posted April 4, 2018 Impossible to say without seeing the design. If there’s loads of ‘meat’ in it,good access all round & standard bucket handle joint then I’d say it’s slightly high,but not that much. Also depends on your area & the demand for brickies locally-this will determine how much he has to pay his people & allow some for his profit. Rates for a timber frame or similar structure are always going to be higher than brick & block construction,as the earning potential of the blockwork,especially party walls,isn’t there.
ToughButterCup Posted April 4, 2018 Posted April 4, 2018 3 hours ago, divorcingjack said: [...] Could anyone with SPONS give me an idea of recommended prices either /1000 bricks laid or psqm for single skin, facing reclaimed bricks? [...] There are many classifications in SPONS ( a few dozen) , among them the following, taken at random.... but none of them mention reclaimed bricks - a brick is a brick is a brick, I suspect. SPONS is expensive, but has saved it's cost many times over. This is from the 2015 edition. Facing bricks solid walls; handmade facings; bricks PC £700.00/1000 half brick thick; fair face one side m2 72.00 to 87.00 one brick thick; fair face both sides m2 160.00 to Facing brick walls; sand faced facings; bricks PC £550.00/1000 half brick thick; pointed one side m2 67.00 to 81.00 one brick thick; pointed both sides m2 130.00 to 160.00 SUPPLY AND LAY PRICES Common bricks In gauged mortar (1:1:6); prime cost for bricks 380.00 – – – 380.00 1000 380.00 Walls half brick thick 22.80 0.84 17.02 – 26.50 m2 43.52 half brick thick; building against other work; concrete 22.80 0.92 18.67 – 27.81 m2 46.48 half brick thick; building overhand 22.80 1.04 21.23 – 26.50 m2 47.73 half brick thick; curved; 6.00 m radii 22.80 1.08 21.97 – 26.50 m2 48.47 half brick thick; curved; 1.50 m radii 26.60 1.41 28.73 – 30.59 m2 59.32 one brick thick 45.60 1.41 28.73 – 52.99 m2 81.72 one brick thick; curved; 6.00 m radii 49.40 1.84 37.33 – 57.08 m2 94.41 one brick thick; curved; 1.50 m radii 49.40 2.29 46.48 – 57.74 m2 104.22 one and a half brick thick 68.40 1.92 38.98 – 79.50 m2 118.48 one and a half brick thick; battering 68.40 2.21 44.83 – 79.50 m2 124.33 two brick thick 91.20 2.33 47.40 – 106.00 m2 153.40 two brick thick; battering 91.20 2.75 55.82 – 106.00 m2 161.82 337 mm average thick; tapering, one side 68.40 2.41 49.05 – 79.50 m2 128.55 450 mm average thick; tapering, one side 91.20 3.12 63.50 – 106.00 m2 169.50 337 mm average thick; tapering, both sides 68.40 2.79 56.73 – 79.50 m2 136.23 450 mm average thick; tapering, both sides 91.20 3.50 71.19 – 106.64 m2 177.83 facework one side, half brick thick 22.80 0.92 18.67 – 26.50 m2 45.17 PS, the Kindle edition is £30 ish. I use the online version far more than the physical copy.
Dreadnaught Posted April 4, 2018 Posted April 4, 2018 Off topic. I wonder if SPONS goes out-of-date fast? A 2016 copy is available for £3.50 on eBay. I appreciate the some prices may have spiked after the Brexit referendum but would a 2016 copy of SPONS be better than nothing?
ToughButterCup Posted April 4, 2018 Posted April 4, 2018 8 minutes ago, Dreadnaught said: [...] A 2016 copy is available for £3.50 on eBay. [...] With the licence for online access? You can lose your way or overlook information in the hard copy of SPONS : using a combination of the online version and the physical one is very powerful : and quick. 1
