BotusBuild Posted May 21 Author Posted May 21 I was thinking 2 x 45's, but then how to get that waste in is the issue, which I haven't figured out a solution yet apart from cut and glue (NO!)
Nickfromwales Posted May 21 Posted May 21 8 minutes ago, BotusBuild said: I was thinking 2 x 45's, but then how to get that waste in is the issue, which I haven't figured out a solution yet apart from cut and glue (NO!) Just change the branch! You'll still pick the waste up exactly the same way.
Gone West Posted May 22 Posted May 22 10 hours ago, Nickfromwales said: My only issue is, that is a T branch, and should be a Y branch like the other if poop is dropping into it from "Le Bog". That's interesting, what is the reasoning behind having to use a Y instead of a swept T in that position.
BotusBuild Posted May 22 Author Posted May 22 (edited) 14 hours ago, Nickfromwales said: Just change the branch! You'll still pick the waste up exactly the same way. Done. Frame time Edited May 22 by BotusBuild 1
BotusBuild Posted May 22 Author Posted May 22 I've started a topic HERE to cover GROHE frame install for others to reference. 1
Nickfromwales Posted May 22 Posted May 22 53 minutes ago, BotusBuild said: Done. Frame time “By Jove, I think he’s got it!” 🤝👍 1 1
Nickfromwales Posted May 22 Posted May 22 5 hours ago, Gone West said: That's interesting, what is the reasoning behind having to use a Y instead of a swept T in that position. There’s not enough sweep, and there would be a lot of ‘matter’ going to the right as well as flowing away to the left. If a T is laid horizontally with a good fall then you can get away with it (just), but I avoid using them tbh. Not such a worry if theres a flushing WC upstream, but here there’s just a 40mm waste which isn't sufficient to ‘move things along’ (if there are any stragglers ). 1
BotusBuild Posted May 22 Author Posted May 22 2 hours ago, Nickfromwales said: 40mm waste which isn't sufficient to ‘move things along’ (if there are any stragglers ). Not even if it a full flowing shower 😀 (statement, not question)
BotusBuild Posted May 22 Author Posted May 22 Here is the frame fitted Better explanation of the Grohe instructions HERE that I took to fit to this stage. That topic will be updated with the extra steps still required. 1
Nickfromwales Posted May 22 Posted May 22 1 hour ago, BotusBuild said: Here is the frame fitted Better explanation of the Grohe instructions HERE that I took to fit to this stage. That topic will be updated with the extra steps still required. Tres bien, Rodders. @Gone West, you can see the difference in the two branches, with the above being so much better for 'flow'. 1
BotusBuild Posted Tuesday at 17:09 Author Posted Tuesday at 17:09 Got the walls repaired, a backer panel fitted and the flusher panel on. Just awaiting the toilet pan tomorrow 1
crispy_wafer Posted 2 hours ago Posted 2 hours ago 1 hour ago, BotusBuild said: What have you used for the grey panel?
