BotusBuild Posted 20 hours ago Author Posted 20 hours ago I was thinking 2 x 45's, but then how to get that waste in is the issue, which I haven't figured out a solution yet apart from cut and glue (NO!)
Nickfromwales Posted 20 hours ago Posted 20 hours ago 8 minutes ago, BotusBuild said: I was thinking 2 x 45's, but then how to get that waste in is the issue, which I haven't figured out a solution yet apart from cut and glue (NO!) Just change the branch! You'll still pick the waste up exactly the same way.
Gone West Posted 10 hours ago Posted 10 hours ago 10 hours ago, Nickfromwales said: My only issue is, that is a T branch, and should be a Y branch like the other if poop is dropping into it from "Le Bog". That's interesting, what is the reasoning behind having to use a Y instead of a swept T in that position.
BotusBuild Posted 6 hours ago Author Posted 6 hours ago (edited) 14 hours ago, Nickfromwales said: Just change the branch! You'll still pick the waste up exactly the same way. Done. Frame time Edited 6 hours ago by BotusBuild 1
BotusBuild Posted 5 hours ago Author Posted 5 hours ago I've started a topic HERE to cover GROHE frame install for others to reference. 1
Nickfromwales Posted 5 hours ago Posted 5 hours ago 53 minutes ago, BotusBuild said: Done. Frame time “By Jove, I think he’s got it!” 🤝👍 1 1
Nickfromwales Posted 4 hours ago Posted 4 hours ago 5 hours ago, Gone West said: That's interesting, what is the reasoning behind having to use a Y instead of a swept T in that position. There’s not enough sweep, and there would be a lot of ‘matter’ going to the right as well as flowing away to the left. If a T is laid horizontally with a good fall then you can get away with it (just), but I avoid using them tbh. Not such a worry if theres a flushing WC upstream, but here there’s just a 40mm waste which isn't sufficient to ‘move things along’ (if there are any stragglers ). 1
BotusBuild Posted 2 hours ago Author Posted 2 hours ago 2 hours ago, Nickfromwales said: 40mm waste which isn't sufficient to ‘move things along’ (if there are any stragglers ). Not even if it a full flowing shower 😀 (statement, not question)
BotusBuild Posted 7 minutes ago Author Posted 7 minutes ago Here is the frame fitted Better explanation of the Grohe instructions HERE that I took to fit to this stage. That topic will be updated with the extra steps still required.
