jimseng Posted 4 hours ago Posted 4 hours ago Hello. I am trying to establish what the regs say about access to my LED drivers which I am installing in a cupboard set into the timber frame of my new build. The system is 24v DC (powered from solar batteries, there is no mains involved at any point). I am building a box set into the wall and the carpenter has suggested using some fixing where the front of the cupboard/box can be removed without using a tool. (Such as magnets). This is so we can make the panel as invisible as possible with no screw heads showing, it will be flush with the plasterboard and plaster finish and painted. I expressed concern about the whole access to live terminals without the use of a tool thing but I have only found ambiguity about whether this applies to 24v DC or not. Can someone point to what the actual regs say? One point to make is that in order to pry the front of the panel off one would have to insert something like a thin blade or screwdriver into the gap between the front panel and the wall to remove it. Perhaps that counts as the use of a tool? Regulations seem to be an art rather than actual rules.
markc Posted 4 hours ago Posted 4 hours ago If only 24v then no precautions necessary - good practice to mitigate fire of course, terminals can be exposed .. as in vehicles etc.
Nickfromwales Posted 4 hours ago Posted 4 hours ago @jimseng https://tradeaccesspanels.co.uk/product/fire-rated-plasterboard-access-panels/?gad_source=1&gad_campaignid=17336436168&gbraid=0AAAAADqcc2NvcVDH3OPU6cTaBGL9O6YYE&gclid=Cj0KCQjwk_bPBhDXARIsACiq8R3L6SPOQXz1gdePeNbesc0EaPv1Q_Guurb7OuhtdCA38PNVFVlX5ugaAjOaEALw_wcB
SteamyTea Posted 1 hour ago Posted 1 hour ago This seems to explain it all quite well. You can put a sticker in there saying what it is. https://voltage-disturbance.com/power-quality/difference-between-elv-selv-pelv-and-felv/ 1 hour ago, billt said: You might want to edit that rather offensive post. Yes, I agree.
ProDave Posted 42 minutes ago Posted 42 minutes ago One of my more unusual jobs was to wire a very remote public toilet. The wiring consisted of a 12V wind turbine and a small solar panel to charge a 12V battery that ran a small low power fan to ventilate the composting tank, and a small 12V light and switch. Building control still wanted an EIC for the work, even though as far as I am concerned it does not come under BS7671
SteamyTea Posted 27 minutes ago Posted 27 minutes ago 13 minutes ago, ProDave said: BS7671 Be so much simpler if it was available free of charge. What does section 543.3.201 say?
