flanagaj Posted 17 hours ago Posted 17 hours ago I was given the following schematic diagram by St Goblain in relation to their suggested approach for a Radon membrane. Just wondering whether anyone know how you go about suspending insulation in the cavity with using wall ties? Visqueen are also showing a similar detail of insulation just suspended in thin air directly below the cavity tray.
BadgerBodger Posted 16 hours ago Posted 16 hours ago From experience this wouldn’t actually be hanging like that below the tray. That bit isn’t really their bag so they won’t pay much credence to it. I used Kingspan green guard full fill below DPC and PIR full fill above. The thermal bridge in the blockwork was dealt with by marmox blocks. The detail on the left, is that a tanking product running up to/under the tray? Assume so as EGL is above IGL
Redbeard Posted 16 hours ago Posted 16 hours ago 9 minutes ago, BadgerBodger said: The thermal bridge in the clockwork Messrs Bing and Hornby will be turning in their respective graves! ☺️
Nickfromwales Posted 14 hours ago Posted 14 hours ago 1 hour ago, Redbeard said: Messrs Bing and Hornby will be turning in their respective graves! ☺️ I sorted the typo, sorry, so now you look loopy. Lol.
Mr Punter Posted 14 hours ago Posted 14 hours ago Be interesting to see the as-built version of the drawings. That is a lot of different products being applied at the substructure level. The insulation could be held in place with wall ties, although you could just use blown beads.
dpmiller Posted 6 hours ago Posted 6 hours ago why don't you just put the radon membrane lower down, straight across the whole area before the cavity begins? Then you can deal with damp above it at your leisure...
flanagaj Posted 5 hours ago Author Posted 5 hours ago 49 minutes ago, dpmiller said: why don't you just put the radon membrane lower down, straight across the whole area before the cavity begins? Then you can deal with damp above it at your leisure... The membrane isn't the issue. It's the cavity tray that has to be there. Maybe full fill under compression will happily stay suspended in the cavity. The drawing has a vertical membrane against the inner leaf, so using wall ties will mean breaching said membrane.
Redbeard Posted 1 hour ago Posted 1 hour ago 13 hours ago, Nickfromwales said: I sorted the typo, sorry, so now you look loopy. Lol. @NickfromwalesWhat do you mean 'look'?! (I did spend half a minute looking for the typo in my post though! Got there!) 2
