Bluebaron Posted May 2 Posted May 2 My planning has been knocked back for the second time due basically to size. I'm now falling back on a 3 floor design that my designer originally suggested but i rejected. I don't like the dormer at the back so i've ditched the single storey rear kitchen and gone 2 storey. I've also ditched the garage and brought the left side down to one storey to give an extra downstairs room. (this was the main planning issue, to imposing) I've attached my designers early plan and my 'very' rough ideas but wondered if anyone could suggest something better before I ask him to do the same. Also to note a separate issue i can't go any further to the left or right although slight movement back may be allowed. (but not the left single storey). first photo shows rejected plan Thanks everyone.
ProDave Posted May 2 Posted May 2 That's a big compromise from what you want. Have you considered appealing the refusal?
ETC Posted May 2 Posted May 2 56 minutes ago, ProDave said: That's a big compromise from what you want. Have you considered appealing the refusal? Or change your designer?
ETC Posted May 2 Posted May 2 Just now, ETC said: Or change your designer? Or lower your expectations?
Bluebaron Posted May 2 Author Posted May 2 1 hour ago, ProDave said: That's a big compromise from what you want. Have you considered appealing the refusal? It’s on appeal now but doesn’t look hopeful so trying to get ahead with a redesign.
Bluebaron Posted May 2 Author Posted May 2 7 minutes ago, ETC said: Or change your designer? Well I’ve spent £4k on him already so don’t want to start from scratch. I’m hoping he will just amend this plan for a reasonable amount.
LDNRennovation Posted May 3 Posted May 3 (edited) post the refusal reasons please? Flat roof rear extension reduced size, roof lights not dormers in the loft conversion. House is still too big for the plot though, you don’t have enough garden or parking. Ditch the garage for now. Edited May 3 by LDNRennovation
Spinny Posted May 3 Posted May 3 Surely you need to understand the specifics of the refusal. Have you or the architect spoken to the planning people to discuss ? Did neighbours object ? Perhaps modest modifications to your original plans would be approved ? I'd have expected the architect to be proactive with the planners - unless they told you it was unlikely to be approved. As ever, and in my view always a hugely bad thing, planning drawings do not show the wider street scene. What does the surrounding street and other houses look like ? I would have thought going 3 storey is more imposing, and never great for layout. Redesign the roof above the garage ? Flat Roof ? Lowered ridge line with gable end ?
Bluebaron Posted May 3 Author Posted May 3 14 hours ago, Mr Punter said: If you post up the reasons for refusal it may help. The proposed development, by reason of its scale, footprint and siting on a constrained corner plot, would result in a cramped and visually intrusive form of development that fails to reflect the established pattern, spacing and character of XXX Avenue. The creation of a reduced and constrained garden for the host dwelling, materially smaller than neighbouring properties, would further emphasise the sense of overdevelopment. The proposal would therefore appear as an incongruous and overly intensive addition to the street scene, harming the character and visual amenities of the area. The development would conflict with Policies 25, 32 and 33 of the XXX Planning Framework (2015), which require high-quality design that respects local character, ensures appropriate townscape integration and safeguards amenity. It would also be contrary to the design and character-based provisions of the National Planning Policy Framework (2024), including paragraphs 135, 136 and 139, which require development to respond positively to local distinctiveness and avoid poor design. So i'm reducing the footprint by around 15%, reducing a third off the front to single storey. It's really the internal layout i'm looking for advice on. thanks 1
Bluebaron Posted May 3 Author Posted May 3 This was my appeal if it helps: 1. Site context and “corner plot” status The appeal site is located at the end of XXX, adjoining XXX and a public recreation ground. While the site is visible from more than one public route, it does not occupy a formal road junction, nor does it perform any defined townscape, visual or spatial function. The Council places significant weight on describing the site as a “prominent corner plot” and treats this characteristic as a determining constraint to development. However, neither the XXX District Planning Framework nor the National Planning Policy Framework identifies corner plots as inherently unsuitable for infill or redevelopment. The term “corner plot” is descriptive only and does not, in itself, attract any policy-based protection. Private residential garden land does not benefit from a presumption of retained openness unless such protection is explicitly identified in policy or designation, which is not the case for the appeal site. Inspectors have repeatedly found that the perception of openness arising from an unusually large residential curtilage does not amount to protected openness in planning terms. The correct test is therefore whether the proposal responds appropriately to its context in terms of scale, massing, layout and appearance, rather than whether it preserves an incidental gap within the built form. 2. Openness and character of the street scene The officer report repeatedly refers to the site as providing a “visual break” and contributing to a “sense of openness”. However, no evidence is presented to demonstrate that this openness is deliberate, planned or subject to policy protection. The site is not designated as open space, does not form part of a planned vista, and is not subject to any policy seeking to retain undeveloped frontage or gaps. The surrounding area exhibits a varied suburban character, including semi-detached, terraced and detached dwellings, with irregular plot sizes typical of cul-de-sac layouts. Corner and end-of-run plots within such estates are frequently larger and are commonly capable of accommodating additional built form without harm to character. The proposal would not introduce development of excessive scale or prominence. The dwelling would maintain a typical two-storey height, domestic proportions and conventional separation distances. Importantly, the Council acknowledges within the officer report that: • separation distances are typical for the suburban context; • there would be no unacceptable harm to residential amenity; and • there are no objections on highway, arboricultural or environmental grounds.In this context, the conclusion that the proposal would nevertheless appear “cramped and visually intrusive” is not robustly substantiated and appears to be driven by a preference for the site to remain underdeveloped rather than by identifiable planning harm. 3. Scale and massing The proposed dwelling would be materially smaller in overall massing than the existing semi- detached pairs that characterise XXX. When assessed as a single built form, the appeal dwelling would be approximately three-quarters of the combined scale and bulk of the adjoining semi-detached properties. As a result, the proposal would read as a modest and subordinate addition within the street scene rather than as a dominant or overbearing form. This reduced massing directly addresses concerns regarding visual impact and reinforces the conclusion that the proposal would not erode the established suburban character of the area. This proportional relationship is a material consideration and weighs significantly against the suggestion that the proposal represents overdevelopment or an unduly intensive use of the site. 4. Design and windows – correction of factual error The officer report refers to the presence and impact of a side-facing window, implying potential overlooking and character impacts. This is factually incorrect. The submitted drawings clearly show that: • the proposed dwelling includes no side-facing habitable room windows; • side windows have been intentionally omitted to minimise overlooking, enclosure and visual intrusion; and • fenestration is primarily confined to the front and rear elevations, consistent with the prevailing pattern of development. This factual error materially undermines the reliability of the Council’s assessment. Conclusions relating to perceived cramping or character harm cannot reasonably be sustained where they are based on an incorrect understanding of the scheme. 5. Policy assessment (HDPF Policies 32 & 33 and the NPPF) Policy 32 (Quality of New Development) and Policy 33 (Development Principles) require development to respect local character, avoid overdevelopment, and achieve appropriate scale, massing and spacing. The proposal complies with these requirements by: • maintaining typical suburban heights and separation distances; • providing adequate private amenity space for both dwellings;• presenting reduced massing relative to surrounding built form; and • avoiding overlooking through careful fenestration design. Paragraphs 135, 136 and 139 of the NPPF (2024) confirm that development should respond positively to local character without imposing unnecessary uniformity or preventing the appropriate optimisation of sites. The appeal proposal represents a proportionate and well-considered form of residential infill consistent with these objectives. 6. Appeal precedent and Inspector reasoning Appeal decisions consistently confirm that: • corner plots are not inherently constrained from development; • perceived openness of private garden land carries limited weight in the absence of policy protection; and • efficient use of land within built-up areas is supported where character and amenity impacts are acceptable. Inspectors have repeatedly found that resistance based solely on the retention of an incidental gap or sense of spaciousness does not justify refusal where scale, massing and amenity impacts are otherwise acceptable. The Council’s approach in this case conflicts with this established reasoning. 7. Planning balance The Council has not demonstrated a five-year supply of deliverable housing sites, engaging the presumption in favour of sustainable development under paragraph 11(d) of the NPPF. The proposal would: • deliver an additional dwelling within the built-up area boundary; • make efficient use of land in a sustainable location; and • do so without giving rise to unacceptable technical or amenity impacts. The alleged character harm relies on an overstated interpretation of openness and is further weakened by a material factual error regarding the scheme’s design. When weighed against the identified benefits, any perceived harm does not significantly and demonstrably outweigh the benefits when assessed against the Framework as a whole. Conclusion The appeal proposal represents a proportionate, well-designed and policy-compliant form of residential infill. The refusal places excessive weight on the incidental openness of private garden land and relies, in part, on an incorrect understanding of the proposal. The development accords with Policies 32 and 33 of the XXX District Planning Framework and the objectives of the National Plan
Nestor Posted May 3 Posted May 3 Back again. Revisit this thread, from December 2025, you had plenty of good advice and even drawings. 1
ETC Posted May 3 Posted May 3 Let me know if you want me to do (another) sketch. You’re trying to get the ugly sister’s foot into Cinderella’s shoe! 1
Bluebaron Posted May 3 Author Posted May 3 I think maybe I don’t understand the way things are done. I had an application in that was refused for being to big so now I’m attempting to reduce it but maintain a good size internal space. As such I’ve gone up a level, lost the garage and gone back a bit. now I’m trying to get a good floor plan together that works. previous comments in my last post said that making it more “L” shaped works better for the plot so that what I’ve gone back to. This reduced the overall frontage and is less imposing on the perceived corner .
Nestor Posted May 3 Posted May 3 This from the planners is fair. Wait for the appeal then proceed again. All the information is in your previous topics. 7 hours ago, Bluebaron said: The creation of a reduced and constrained garden for the host dwelling, materially smaller than neighbouring properties, would further emphasise the sense of overdevelopment. The proposal would therefore appear as an incongruous and overly intensive addition to the street scene, harming the character and visual amenities of the area.
Bluebaron Posted June 29 Author Posted June 29 As expected appeal was upheld. so back to the drawing board. I’ve asked the planners for a pre-app based on a smaller footprint/frontage. I’m still trying maximise the plot so will have to go into the roof. This is what I’m thinking for the downstairs now. Just need a rethink on the kitchen layout as I’ve moved it around a bit. I’m not sure if it’s worth stealing a bit and making the lounge bigger (where the counter is) or just a rearrange.
LDNRennovation Posted July 3 Posted July 3 Doesn’t ’appeal upheld’ mean you won the appeal? you need to make your plan smaller and listen to advice lol 1 1
ETC Posted July 5 Posted July 5 On 03/07/2026 at 13:56, LDNRennovation said: Doesn’t ’appeal upheld’ mean you won the appeal? you need to make your plan smaller and listen to advice lol Why start now!
Bluebaron Posted July 6 Author Posted July 6 On 05/07/2026 at 05:18, ETC said: Why start now! Well I have been doing exactly that. My “so called” professional advice from the ex head of planning for a nearby local authority was to resubmit as is with some minor amendments. Should have listened to my gut and told him no but that wasted 9 months. My architectural design guys charges £130ph and works slowly so I’m in for £6k on the design stage alone. Plus 2 applications at £700 a go. And the above advice at £3k. Now I’m in for £260 for a preapp. I will probably need another £1000 of tweaking the above design for a third and final go. all this when the planner verbally told me 18 months ago that the plot of crying out for infill and shouldn’t be a problem!
LDNRennovation Posted July 8 Posted July 8 On 06/07/2026 at 09:06, Bluebaron said: £6k on the design stage alone. Plus 2 applications at £700 a go. And the above advice at £3k. Now I’m in for £260 for a preapp. all this is insane! stop throwing money at this and just reduce the footprint and bulk. I would bet good money you didn’t listen to any advice, paid for or otherwise.
