Thanks.
It is very rare any standards get mentioned or the grade of stainless steel.
For people interested in the serviceability of these hidden cisterns.
This one has also had a dodgy flush valve that sometimes kept running if you didn't push the flush plate long enough.
I had put off fixing it assuming it would be a pain to do.
I bought a new flush valve as I had disconnected it anyway to fix the pipework.
It took roughly five minutes to replace the flush valve. You literally just pull it out and push the new one in. It bends to fit through the flush plate hole. Taking off the front plate and putting it back n tight actually took longer than replacing the flush valve. It was an unusual instance of a job actually being as easy as it was supposed to be.
  • 2 months later...
Having just discovered a leaking flexi pipe on a toilet cistern, what is the general consensus on best practice here? Replace and set a 10 year reminder or fit something like https://www.screwfix.com/p/hep2o-plastic-push-fit-angled-tap-connector-15mm-x-1-2-/3036f to the cistern and go straight into plastic pipe, even if that involves a couple of elbows?
This is all inside a vanity cabinet so not something that can regularly be inspected, it needs silicone cutting back from the toilet to even see.
I didnt have a great deal of success with those fittings, I'm sure they are fine but this ham fisted eejit had a failure on the washer.  I used the 1/2" to 15 female coupler with a street elbow instead.
I use these regularly, very reliable bits of kit for concealed toilets / showers / wall mounted basic taps etc.
Did you swap the square edged rubber seal for the chamfered one?
@S2D2, it doesn’t say it, but these come with a second loose rubber seal, and you simply switch to the one that matches the application; square for a traditional tap aka ‘flat-faced’, or chamfered if its a cone fitting (that takes an olive usually).
Don’t use anything like lube or paste on these, just whack them in dry and you’ll be right for life.
Probably not...  Application was both gerberit, and grohe cisterns...
Immediate failure or at a later date?
Thanks both, parts ordered.
Straight away, so likely my fault, or has been pointed out the wrong washer used!
Have to say, I'm having the same issue as @crispy_wafer, doesn't seem to be a way to stop it leaking attaching to a plastic cistern feed with the flat washer as per a flexi pipe.
Takes a brass stop end with the tapered washer with zero issues, but flat washer and cistern, nope. Starting to suspect I might have loosened something in the cistern messing about with it but that'll be a full disassemble of the unit to confirm.
Forgot to follow up on this, I swapped to:
https://www.screwfix.com/p/hep2o-hx19-15ws-angled-service-valve-15mm/8634f
Which has no leak. The tap connector when tightened was causing the cistern connection move and leak. Wouldn't have been an issue if I could get more tools in to hold it but this was all through a 10x20cm access hole so a right pain.
I suspect the cistern leak is what caused issues with the flexi so the other two that I had planned to replace can stay put as an inspection camera showed no leak or corrosion.
