Arnold9801 Posted 12 hours ago Posted 12 hours ago I have a lot of insulated plasterboards to fix to external concrete block walls. I've previously used Insta stick, but it's quite expensive anc I need approx 30 cans. Can anyone recommend a good alternative that's cheaper? Thank you Arnold9801
Beau Posted 11 hours ago Posted 11 hours ago I've been pleased with this which has bonded insulated plasterboard to some dodgy old lime plastered walls successfully. Cheapest I found was an ebay seller which worked out around £6.50 a can https://www.soudal.co.uk/diy/products/adhesives/foam-adhesives/soudabond-plasterboard-gun
Arnold9801 Posted 11 hours ago Author Posted 11 hours ago I've been looking at Soudabond, but being so cheap I was concerned about its reliability. Thank you for replying.
Super_Paulie Posted 7 hours ago Posted 7 hours ago I used Soudabond for my whole place. Only difference from Insta seems to be it takes longer to "skin over". I used Insta when I couldn't get my usual stuff and was caught out as I left it 5 minutes like the souda and it had almost gone off.
Russell griffiths Posted 28 minutes ago Posted 28 minutes ago Go online and buy in box quantities of 12.
saveasteading Posted 9 minutes ago Posted 9 minutes ago 18 minutes ago, Russell griffiths said: online and buy in box quantities of 12. Try your local independent BM. A relationship can be good for you and them.
Gone West Posted 4 minutes ago Posted 4 minutes ago +1 for Soudabond, I've never had a problem with it.
