Alan Ambrose Posted March 23 Posted March 23 (edited) Anyone found a nice solution to this, preferably hard-wired? By 'nice', I mean not too ugly and a thought out install into the window/door frame... I should say that I'm planning on external blinds and would like them to be smart enough to not come down when outward opening windows/doors are open. Edited March 23 by Alan Ambrose
elite Posted March 23 Posted March 23 Recessed magnetic contact sensor / reed switch as used in alarms - depends on your doors / windows, then just need someway to make that info available to your blinds 1
-rick- Posted March 23 Posted March 23 When I looked, the window/door companies seemed to offer this as an option on their products. I'm sure vastly overpriced for what is a magnet and a reed switch (cost <50p). With planning I expect you could plan to retrofit something to windows doors just after they are installed but you would be putting holes in the frame and not sure how that affects warranties, etc. (though a common window install method holes in the frame as well so can't see it being a huge deal). Not got far enough to think about this in more detail.
Spinny Posted March 23 Posted March 23 (edited) You could consider using one of these... https://www.vesternet.com/collections/brands-sensative/products/z-wave-plus-sensative-strips-guard-800 https://sensative.com/sensors/strips-zwave/strips-guard-800/ It is battery powered but supposed to last years and designed to sit unobtrusively in the edge of the door/frame. Uses zwave to communicate with a smart home capable of linking to zwave devices - such as Samsung SmartThings, Home Assistant or others. If using Smart Home control for the blinds they could be using the same hub and then could be nicely integrated that way. When you say external blinds, do you mean shutters ? Edited March 23 by Spinny
Spinny Posted March 23 Posted March 23 PS There are also numerous other more chunky window/door sensors including zigbee or matter ones around (always battery but life shorter than the sensative in built battery)... https://www.amazon.co.uk/s?k=door+and+window+sensor&crid=1BCTQXM1HXSS4&sprefix=door+and+window+sensor%2Caps%2C310&ref=nb_sb_noss_1
Spinny Posted March 23 Posted March 23 PPS Just remembered there is also this type if you can drill into the frame to fit it (a bit like a door latch barrel), such as wooden frames... https://www.vesternet.com/collections/door/products/z-wave-plus-aeotec-recessed-door-sensor-7
craig Posted March 24 Posted March 24 (edited) 21 hours ago, Alan Ambrose said: Anyone found a nice solution to this, preferably hard-wired? By 'nice', I mean not too ugly and a thought out install into the window/door frame... I should say that I'm planning on external blinds and would like them to be smart enough to not come down when outward opening windows/doors are open. Speak to your window supplier, they should be able to factory install them as most supply reed contacts. You can have this connected to your smart home if required, wireless enabled etc. If they do not know what you are referencing, look elsewhere. Edited March 24 by craig
craig Posted March 24 Posted March 24 13 hours ago, -rick- said: but you would be putting holes in the frame and not sure how that affects warranties, etc. It immediately voids them, as the window has been altered. It does depend on the manufacturer, some won't mind but if it is the root cause, warranty is void.
Alan Ambrose Posted April 4 Author Posted April 4 It’s struck me that you could use as IR beam thingy across the outside (or inside for inward opening). Suggest that open/closed sensors (as they’re so simple) should be an option from all suppliers. Will check with the two I’m talking ro.
-rick- Posted April 4 Posted April 4 4 hours ago, Alan Ambrose said: It’s struck me that you could use as IR beam thingy across the outside (or inside for inward opening). Suggest that open/closed sensors (as they’re so simple) should be an option from all suppliers. Will check with the two I’m talking ro. Magnet + reed switch is by far the most reliable method. Anything involving an IR beam requires an IR emitter, which will fail in time. PIR (ie, passive) is more reliable but won't tell you a window is open, only that someone is near a window. I don't know how manufacturers fit the reed switches if you order that option but it would seem feasible for them to install them in such a way that they can sense not whether the window is open or closed, but rather whether the window is closed and secure (ie the latch is engaged) or not.
craig Posted April 5 Posted April 5 17 hours ago, -rick- said: they can sense not whether the window is open or closed, but rather whether the window is closed and secure (ie the latch is engaged) or not They can do both open and closed.
-rick- Posted April 5 Posted April 5 3 hours ago, craig said: They can do both open and closed. Not sure you got what I was trying to say? Signalling open or closed would be the default assumption but I'd guess with careful placement of the the sensor you could instead have secure / not-secure. ie. to tell the difference between a window that is closed but with the handle in a position where the window could be pushed open from outside to one where the handle has latched the window securely closed (or in trickle position if it exists). 1
Alan Ambrose Posted April 13 Author Posted April 13 Reporting back: Rationel has these as an option, but not, it seems for tilt-and-turn e.g.
Spinny Posted April 13 Posted April 13 You could take a look at this... https://shellystore.co.uk/product/shelly-2pm-gen4/ This can be used for shutters, blinds etc and it has obstacle detection and can then return the shutter/blind to it's original position. Basically electrically detecting that the shutter/blind is not moving normally because of the obstruction. Depends on the shutter/blind making contact with the obstruction, but if it has flex or a non marking edge then that shouldn't be a problem. So you wouldn't have to detect whether the window was open, and it would also stop the blind/shutter if some other object was in the way. 1
Alan Ambrose Posted April 16 Author Posted April 16 Thanks, that's interesting. I also just found that 21 degrees offer the open/close sensors too, but no more detail than that right now.
Alan Ambrose Posted Monday at 11:27 Author Posted Monday at 11:27 Yeah, OK I've learnt that while some windows suppliers are keen to claim they 'offer the open/close contact option' - when you ask them 'great, so where should I place my cable ducts then' they go all 'errr, nobody here knows, I'll have to check with the supplier'. So, my advice is to start this conversation v early.
craig Posted Tuesday at 07:56 Posted Tuesday at 07:56 They don’t have a clue because they don’t check the details or enquire where the reed contacts come out of the frame. Most don’t even know where the reed contacts are located.
Nickfromwales Posted Tuesday at 13:13 Posted Tuesday at 13:13 Fakro are bell-ends too, as their reed switches are on flying leads, 4 tiny wires…….which are ALL feckin WHITE. Cheers you muppets! 1
