Alan Ambrose Posted Monday at 12:09 Posted Monday at 12:09 (edited) Anyone found a nice solution to this, preferably hard-wired? By 'nice', I mean not too ugly and a thought out install into the window/door frame... I should say that I'm planning on external blinds and would like them to be smart enough to not come down when outward opening windows/doors are open. Edited Monday at 12:10 by Alan Ambrose
elite Posted Monday at 19:08 Posted Monday at 19:08 Recessed magnetic contact sensor / reed switch as used in alarms - depends on your doors / windows, then just need someway to make that info available to your blinds 1
-rick- Posted Monday at 19:15 Posted Monday at 19:15 When I looked, the window/door companies seemed to offer this as an option on their products. I'm sure vastly overpriced for what is a magnet and a reed switch (cost <50p). With planning I expect you could plan to retrofit something to windows doors just after they are installed but you would be putting holes in the frame and not sure how that affects warranties, etc. (though a common window install method holes in the frame as well so can't see it being a huge deal). Not got far enough to think about this in more detail.
Spinny Posted Monday at 21:16 Posted Monday at 21:16 (edited) You could consider using one of these... https://www.vesternet.com/collections/brands-sensative/products/z-wave-plus-sensative-strips-guard-800 https://sensative.com/sensors/strips-zwave/strips-guard-800/ It is battery powered but supposed to last years and designed to sit unobtrusively in the edge of the door/frame. Uses zwave to communicate with a smart home capable of linking to zwave devices - such as Samsung SmartThings, Home Assistant or others. If using Smart Home control for the blinds they could be using the same hub and then could be nicely integrated that way. When you say external blinds, do you mean shutters ? Edited Monday at 21:21 by Spinny
Spinny Posted Monday at 21:29 Posted Monday at 21:29 PS There are also numerous other more chunky window/door sensors including zigbee or matter ones around (always battery but life shorter than the sensative in built battery)... https://www.amazon.co.uk/s?k=door+and+window+sensor&crid=1BCTQXM1HXSS4&sprefix=door+and+window+sensor%2Caps%2C310&ref=nb_sb_noss_1
Spinny Posted Monday at 21:41 Posted Monday at 21:41 PPS Just remembered there is also this type if you can drill into the frame to fit it (a bit like a door latch barrel), such as wooden frames... https://www.vesternet.com/collections/door/products/z-wave-plus-aeotec-recessed-door-sensor-7
craig Posted yesterday at 09:14 Posted yesterday at 09:14 (edited) 21 hours ago, Alan Ambrose said: Anyone found a nice solution to this, preferably hard-wired? By 'nice', I mean not too ugly and a thought out install into the window/door frame... I should say that I'm planning on external blinds and would like them to be smart enough to not come down when outward opening windows/doors are open. Speak to your window supplier, they should be able to factory install them as most supply reed contacts. You can have this connected to your smart home if required, wireless enabled etc. If they do not know what you are referencing, look elsewhere. Edited yesterday at 09:17 by craig
craig Posted yesterday at 09:15 Posted yesterday at 09:15 13 hours ago, -rick- said: but you would be putting holes in the frame and not sure how that affects warranties, etc. It immediately voids them, as the window has been altered. It does depend on the manufacturer, some won't mind but if it is the root cause, warranty is void.
