Wire wool. that is a water pipe coming up through a sleeve ? keep stuffing it down, untill you cant get any more in. Rats or mice, wont chew through wire wool, because it makes there gums bleed. I'm not saying dont use poison, but it is always a shame that owls etc then eat the dead rats, and are poisoned. Rats need a food and water source. If you have either of them in your garden, such as a bird feeder, or a pond. Try and remove those. Best of luck. Getting rid of rats is much harder than most people think.
I've stopped feeding the birds.
A lot of the food is lost to the ground and rodents clear it. Also i read that we are fattening up our resident garden birds in winter, which then dominate the birds we see less.. esp the migrating ones arriving after an exhausting journey.
  • Like 3
I've heard of fine sand being used to fill such pipes. Even in highly airtight houses.
Would the rats bother digging through?
Cheap stainless steel pot scourers scrunched in and foamed.
Crushed, broken glass is good. Round here it was de rigueur to lay bottles down if building a shack, smash them all and cast the slab on top. Just to stop the tunnel bunnies gnawing their way through.
Similar situation here where my mains water comes up through the footings / slab then into a suspended floor space.
I ran the MDPE water pipe in a blue corrugated duct:
SAM_3967
2016-10-16_04-49-31
I then rolled a bit of perforated, galvanized sheet and wrapped the exposed section of duct within the suspended floor space:
SAM_4099
Like this:
29471390330_38ec0932ee_b.jpg.e43dd2a87d4988ca3b12c90c409fe1ad.thumb.jpg.48daedf2295ce26be574bb4c029b0c8a.jpg
I forgot to ask. What is the correct way to seal ducting like this on both ends? I saw diagrams online and there supposed to be sealed.
will stuffing wire wool down without foam do the job? I read that foam can damage pipe?
