Has anyone built a wall build up like this? Any thoughts?
Walls – U-value 0.12 W/m²K
  • Internal Finish: 12.5 mm Plasterboard
  • Service Cavity: 50 mm battened void (filled with extra mineral wool?)
  • Airtight & VCL Layer: Pro Clima Intello with joints taped using Pro Clima Tescon Vana.
  • Structural Frame: 140 mm timber studs.
  • Insulation: 140 mm full-fill mineral wool cavity insulation (e.g., Knauf RS45 or Rockwool RWA45).
  • External Sheathing: 9 mm OSB3.
  • Breather Membrane (Frame): Protect TF200.
  • EWI: 160 mm high-density mineral wool (e.g., Rockwool Frontrock or density-equivalent RWA45 slabs).
  • Weather Seal: High-performance W1-rated breather membrane (e.g., Tyvek Housewrap) installed over EWI.
  • Cavity Fixings: Thermally broken structural insulation screws (e.g., HECO Topix-Plus Therm) installed at a 60–67° angle. Screws must achieve a minimum 50 mm embedment into structural timber studs.
  • Ventilation: Horizontal structural battens (min. 38x89 mm) + vertical counter-battens
  • Fire Safety: Euroclass A1 non-combustible cavity barriers.
  • External Finish: Cedral Click vertical cladding + starter/top profiles + vermin mesh.
A service cavity filled with mineral wool isn't accessible any longer.  Just partially fill?
Your thermal bridging is through the studs but this will be calculated... it is normal.
Have you a target for insulation or throwing all you can at it?
Do you need the internal breather membrane? Cannot see what that does.
Between studs knauf Frametherm 32, easier to install and better U value.
I would do a simple twin stud, fill with frametherm 32, or blown in insulation. OSB board outside with membrane. Or 140mm structural, OSB outside with membrane, internally PIR skin over studs to achieve u value
I have done something vaguely similar, but with wood fibre. Just stagger the outside and inside verticals and make it as 'fat' as you need to get your desired U value net of the timber fraction. In my case the external members were structural and the internals not so, but it can be either way round, or indeed the load can be shared.
Edited by Redbeard
Thanks all, very helpful thoughts. Yes I have been wondering whether a hybrid wall of 60mm woodfibre outside studs plus the mineral wool and then pir inside studs is more achievable
Think that 33% more complex than you need. Stud plus internal OR external, NOT both
Aiming for near-passive (and hoping to have walls around 0.13) so will need both internal and external the hybrid design
Go for a twin wall Larsen truss or I-beam, and lose all this unnecessary complication. ;)
PIR is a complete and total PITA to cut and fit (properly) so just go for blowing cellulose and gain the benefits of a one man insulation process (roof and walls) and also the hugely improved sound-deadening that you lose with PIR.
Your initial proposal is hugely over complicated, sorry. KISS wins every time, and will get you to PH targets quickly and simply, with far less to go wrong. The biggest issue will be getting all these layers, materials, installers to do their work meticulously, which most either can’t or don’t.
  • Like 3
If I were doing something like that I would use Pro Clima's Intello (which is vapour-closed in low temperatures but becomes slightly vapour-open as te weather warms up, allowing 'dumping' of any accumulated moisture) as VCL, not the foil on PIR, so just make the wall as thick as you need to get the U value you want without the PIR, then it could 'breathe' (a bit) both ways instead of being 'blocked off' on the inside.
30 minutes ago, Gballam said:
0.13
Or just do an ICF, stack the blocks fill with concrete, U value 0.14 with service void. Parge coat for airtight if woodcrete, no need with polystyrene blocks.
Our house, 4 weeks (end Nov to Christmas, bloody freezing) 70m perimeter and average 3m tall, two of us never done it before. 2 days to parge coat internal wall.
Edited by JohnMo
4 hours ago, Gballam said:
The why is trying to avoid thermal bridging without a twin frame. The issue is the complexity!
Single wall with horizontal studs on the inside lined with more insulation.
or go icf, or buy the frame all done
depending how much you want to do.
Edited by Russell griffiths
  • 3 weeks later...
Hi Gballam,
Just reading this and the comments and want to put in my 2 cents.
Outside to in:
  1. Breather Membrane - W1 or W2 depending on where you are
  2. 9mm OSB
  3. 140mm timber frame with 140mm 0.035R between studs
  4. 90mm PIR insulation to face = No thermal bridging, and keeps it thermally broken down to the foundation.
  5. Reflective vapour control layer
  6. Standard Service Battens OR theoretically can use a partition to save making any penetrations through the VCL but may affect sequencing!
  7. Plasterboard
Gets you 0.12, keeps it simple and follows passivehouse principles. I think it would be more cost effective than going down bigger stud or other forms of timber frame construction but open to debate! Obviously will come with it's own problems.
I also saw a comment about Frametherm 32 insulation, I just want to put a note on it I think it's mega expensive for the performance gain it gives.
Fraze
I completed my own house in December 2025, using a very similar system to yours.
For insulation, I selected Rockwool NyRock Frame Slab, combined with a thicker OSB layer to enhance structural performance.
The majority of the building is finished with Hardie VL cladding so no external  (EWI) system.
I used the same construction approach on a house I built three years ago, which has performed faultlessly. Based on that experience, I chose to adopt the same system again for my own home.
I stick build this project using kiln dried treated timber, at the point of the build the timber was at 12.8% to minimise movement
Thanks for your replies - have decided to do almost exactly this 🙂
On 03/04/2026 at 15:08, TimberFraze said:
Hi Gballam,
Outside to in:
  2. 9mm OSB
  7. Plasterboard
Fraze
7 minutes ago, Iceverge said:
100mm pir might be cheaper than 90mm. Worth a look.
Agreed. I found that the cost is pretty much based on £/m3 except for 100mm. As this is the big seller the merchants will stock it by the lorry load and know they will sell it all.
Unconventional thicknesses may be special orders and so attract handling and delivery costs.
I assume you put battens inside the pir layer? 75*25?
Did you have any issues with keeping them straight to hang the plasterboard?
That's interesting - will look into to that
Here's the final plan (unless it makes sense to go to 100mm financially - although conscious of making doing the battening really hard)
1. Walls Target U-value: 0.12 W/m²K & Airtightness Target 0.6 ACH
  • Structural Frame:
    140 mm C24 timber studs with 9 mm OSB3 external sheathing
  • Primary Insulation:
    140 mm mineral wool (e.g. Rockwool Flexi) friction-fitted between studs
    Pro Clima Intello Plus installed to the internal face of 140 mm studs
    Membrane to extend 150–200 mm above the wall plate
  • Internal Insulation:
    80 mm continuous PIR board (e.g. Celotex)
  • Rim-board detail to accommodate 80 mm of insulation and a pre-installed Pro Clima Intello Plus strip
    All joints taped with Tescon Vana to create a secondary vapour barrier
  • Service Cavity:
    50 mm battened void
    Battens fixed through PIR/Intello into studs using Pro Clima Tescon Naide on back of every batten
  • Weathering & Ventilation:
    Taped Protect TF200 breather membrane
    Minimum 30 mm continuous cavity formed by vertical/horizontal counter-battens for boards
  • Fire & Vermin Safety:
    Non-combustible cavity barriers at windows/floor junctions
    Integrated vermin mesh at cavity base
2. Warm Eaves Hybrid Ventilated Roof Target U-value: 0.11 W/m²K
  • Main Insulation:
    400 mm mineral wool in two staggered layers
  • Eaves Detail:
    Tall ventilation baffle to maintain 50 mm continuous air path from soffit to ridge and act as wind-wash guard for insulation
  • Ceiling Service Void:
    25 x 50 mm battens under Intello membrane
  • Solar & Weathering:
    GSE in-roof integrated mounting system
    Protect TF200 under slates with ventilated ridge tiles
Just need to decide on beam and block vs slab plus strip footings for the floor. Have got a 450mm change in level running straight across the whole house on which will sit a load bearing wall. Anybody solved that well thermally before?
MBC have done loads with split-level insulated passive rafts.
I'd avoid a cold-ventilated sub floor like the plague, but if cost is the driver then B&B floor will likely be the most affordable / simpler to do. Just be sure to allow for 200mm of PIR insulation over the B&B to get back the loss of the cold underbelly.
Good layout,
Nice to see a sensible square foot print.
Personally I would pay the digger man another hour to level the site and forget about the step. It will make half the house unusable for anyone with a wheelchair or a pushchair.
