markharro Posted yesterday at 10:39 Posted yesterday at 10:39 I need to bolt down a post and also 2 rollers being running gear for a cantilevered gate. what are the best bolts/fixings to use? thanks
Mr Punter Posted yesterday at 11:18 Posted yesterday at 11:18 25 minutes ago, Iceverge said: Chemical anchor and threaded rod. +1 Ensure stud, washers and nuts are corrosion resistant (stainless or galv). Clean the drilled holes thoroughly.
Onoff Posted 21 hours ago Posted 21 hours ago I'd cast in J bolts for that as a "holding down unit". Hooked round mesh going down into the concrete. Don't get me wrong I love chemical anchors.
Conor Posted 20 hours ago Posted 20 hours ago Your gate kit should have them included or at least the spec. Mine required 12mm SS rods cast into the concrete. Think they had to be 250mm long, 50mm proud, 200mm set in. A rather large sliding gate tho.
Andeh Posted 15 hours ago Posted 15 hours ago I also really like chemical anchors! 🥰 I'm almost disappointed I don't have more stuff to bolt down with it. It's a hard life post-build... When you run out of fun stuff to sink your teeth into... 1
Onoff Posted 6 hours ago Posted 6 hours ago Again, J bolts hooked under reinforcing mesh or some similar design of holding down unit with plates and long studs. Windage against a gate and offset loads will just worry chemical anchors out over time. With something locked into the concrete you're trying to "worry" the whole, large concrete footing.
SteamyTea Posted 2 hours ago Posted 2 hours ago 4 hours ago, Onoff said: Windage against a gate and offset loads will just worry chemical anchors out over time but the sheep can escape the worrier.
markharro Posted 1 hour ago Author Posted 1 hour ago Hi @Onoff @Conor too late now for the J bolts....the pad was placed ages ago. In any event here is the manual for the gate - it shows preparation for the fixings happening after the pad has gone in. No info on the diameter of bolt etc needed.
Mr Punter Posted 55 minutes ago Posted 55 minutes ago Measure the holes in the rollers. Your stud should be snug but not tight. It is probably M12.
Conor Posted 20 minutes ago Posted 20 minutes ago 58 minutes ago, markharro said: Hi @Onoff @Conor too late now for the J bolts....the pad was placed ages ago. In any event here is the manual for the gate - it shows preparation for the fixings happening after the pad has gone in. No info on the diameter of bolt etc needed. Look just like my rollers. 12mm resin anchors will be what you want.
markharro Posted 15 minutes ago Author Posted 15 minutes ago Thanks. I actually have a bit of 16mm threaded rod and it fits but maybe I want more wriggle room that I would get with 12mm to make sure I get both rollers in line? There is no guidance of the length of rod to bury in the concrete however? Also can anyone recommend a particular brand of resin? Do I need one of the tools shown to blown out the drill dust or will a vacuum do that?
