put solar on the new house last year and now having had a winter can say that i didi it wrong
i went for 13.6kw of panels--no problem
but went for 17kw of batteries -iwa going to go for only 4 batteries in the stack --but when they found they could not fit 30 panels and had to fit only 26
the deal was i get another battery instead
the bottom line is that when its all working on a sunny day then the batteries fill up quick
but in winter  get nothing
with the intelligent octopus tariff
they pay you same as they charge you for electic
 ,so once batteries are ful it goes back anyway
 at 27p a unit  and the batteries then discharge between 16.00 and 20,00 hrs at 29p
sounds good
but  it will never pay back the cost of  to many batteries
 I am electric only
so I am always importing  in  badmonths
 so better just to fill smaller batteries sooner   and just take the 27p for the rest of it -the 3p extra form storage will never  pay for the extra batteries
the other thing that happens is it priorities filling batteries ,so like today  I am paying out for import even though its charging batteries -yes iget 3p more when selling back -but not the point
If doing it again
yes all the panels the roof will hold .but do not go over the top on batteries ,unless you are dual fuel and then you would store and use it later
Useful.
What is your heating system? Storage heaters? Direct electric panels? Heatpump?
I'm currently using my batteries (15kwh) to store E7 electricity and that runs my (gas heated) house pretty much all day on low cost elec - the exception is days when we do alot of washing and there is not much sun, then we end up using a few hours at peak rate. Overall using 95% cheap rate elec.
Am on standard octopus outgoing which was more or less thr same as import (14p cheap rate import, 15p all day export). Unfortunately the export will drop to 12p, but it's not a big deal.
You may be able to get more use from your batteries by switching tariffs and tactics.
@scottishjohn can you not get a cheaper off peak tariff?
We’re all electric. Fill up at 7p export at 15p (soon to be 12p) if there is anything to export. We’ve used very little peak rate electrickery over winter
That's pretty normal
Maybe not the best tariff for winter, Cosy may be better. Fill up at 15p/kWh
You may actually make a loss in real terms if you are paying to charge and then discharging with round trip losses.
Not sure about that, its more about being on the correct tariff. My electric cost to buy is currently 15p, excess PV I get 15p. I never charge battery to get paid for discharging only, only export excess energy from PV.
