SimonD Posted February 22 Posted February 22 I need to create a loft in the existing garage before I build the new one. It's got a traditional pitched roof with rafter tiers every other rafter. The ties aren't of sufficient size to use as rafters across the current span, so I'm considering how to easily add joists across to create my new loft space. Options I'm considering are: 1. Cut ends of new joist on the diagonal and then fix to existing wall plate - but with sufficient bearing on the wall plates I don't know if I can slot them in; 2. Install wall plates to the wall just below the ties and fix new joists to these (garage has sufficient height for this); 3. Sister the ties with the new deeper joists - and add new ones to rafters without existing ties. Walls are ashlar faced breeze block. Any thoughts, ideas and experience to help me decide? Any details I need to be aware of?
Oz07 Posted February 22 Posted February 22 Picture would be helpful of the existing situation. Can you put a plate ontop of existing ties or would it not be above existing due to rafters
SimonD Posted February 22 Author Posted February 22 54 minutes ago, Oz07 said: Picture would be helpful of the existing situation. Can you put a plate ontop of existing ties or would it not be above existing due to rafters It's just like this but with ties every other rafter.
Oz07 Posted February 22 Posted February 22 Can you lift the bottom row of tiles and felt and slide the new joists in from outside
SimonD Posted February 22 Author Posted February 22 1 minute ago, Oz07 said: Can you lift the bottom row of tiles and felt and slide the new joists in from outside Not without damage as the felt is properly fixed. I have to say that compared the the old bungalow, this garage was well built with attention to detail.
Oz07 Posted February 22 Posted February 22 Well I don't think you will ever be able to get a full length into the space with enough bearing on both plates. So looks to be leaving you with option 2. I'd be looking to strip the bottom row of felt and replace. 1
Nickfromwales Posted February 22 Posted February 22 I'd just use 2 pieces of timber, put together (sistered) so you can install them 'telescopically'. Clamp, and construction screw these together, and then infill the short pieces to make 2x full lengths per joist. Dead simple. 1
Iceverge Posted February 22 Posted February 22 How "good" does this need to be? I'd be surprised if you couldn't wiggle something up into place. 50mm would be enough bearing. Maybe use 2 plys of longer bendier timber like 150*25 instead of a single 150*50. You could "truss" the roof by adding vertical support to the existing joists from the rafters. 1
Oz07 Posted February 22 Posted February 22 (edited) Ive Just been assuming this ceiling is boarded. What an idiot. You might get away with poking them thru the inside. Edited February 22 by Oz07
SimonD Posted February 23 Author Posted February 23 14 hours ago, Oz07 said: Ive Just been assuming this ceiling is boarded. What an idiot. You might get away with poking them thru the inside. No worries! 😊 17 hours ago, Nickfromwales said: I'd just use 2 pieces of timber, put together (sistered) so you can install them 'telescopically'. Clamp, and construction screw these together, and then infill the short pieces to make 2x full lengths per joist. Dead simple. Yeah, that's one option, but will double up the amount of timber in need to use. I will keep this option in my back pocket. 15 hours ago, Iceverge said: How "good" does this need to be?.. 50mm would be enough bearing. Only good enough to use as loft storage to get things out of the way instead of having to make a shed or get a half container. I was wondering whether I could get away with 50mm bearing and even if it's 75-80mm that should be fine, which means I could get the joists in place with a small amount of bearing on existing wall plates and then bolt additional wall plates to the wall immediately below for the rest of the required bearing. I think this might be the solution.
Gus Potter Posted February 23 Posted February 23 (edited) 14 hours ago, SimonD said: Only good enough to use as loft storage to get things out of the way instead of having to make a shed or get a half container. Ah, so you are looking for a temporary solution. Putting my SE hat on. I need to know what the span of the ceiling joists are, their size (width, depth and spacing) and a photo of the timbers so I can see what grade of timber would be appropriate to use as a basis for a design check. Often I would plump for what is now known as a C16 grade, equivalent to an older SC3 timber grade common in the 1970's say. Next I need to know just how much weight you are going to put up there. Now when we design this sort of stuff we first need to absolutely make sure it is not going to fall down. The next check is to see if the existing ceiling ties bend (deflect) too much. In your case you have no ceiling that could crack, thus deflection is not an issue. The last check is to make sure that the deflection is not too wild as this can pull the walls in.. for the techy as SE's we call this a second order effect / large rotational / displacement effects.. for example. It may be that what you have is ok to carry some extra weight as it's a temporary design? Now if it turns out that deflection is a major issue then to control that we can sister the timbers.. but I know from experience that we can often do this by sistering almost to the wall, the sistering often does not have to extend to the wall head support. Crucially often the sistered joists don't have to bear on the wall head! But what is important is that if you sister all the joists all on the same side the cumulative effect is to introduce twisting (a rolling effect) in the roof at ceiling level in your case. To avoid this we sister so they face each other in one bay, then miss one and so on. This technique is used in industrial mezzanine cold form steel floors as standard practice. Turning back to the forces. The bending force is maximum at the centre span and reduces to almost zero at the wall head. At the wall head the critical check is what we call the vertical shear check. It's likely that if you stop the sistering short of the wall then the existing ceiling joists will pass the shear check unless they have been notched at the wall head. To conclude. I would first see how much load you want to add, do you need to do anything? As a quick temporary solution.. sistering is probably the easiest, if you can stop them short of the wall head. If not then you can traingulate the roof starting like this. The way this works is an essay.. but before you do this you have to make sure the nails at the ridge and eaves are not rusty for example! What happens in your case is the ceiling joists get almost hung from the rafters.. this increases the axial load in the rafter and if your eaves nails are rusty or connections are ropey you have a problem. Edited February 23 by Gus Potter
SteamyTea Posted February 24 Posted February 24 (edited) As this is temporary, could you not cut some plywood up that is deeper than the current beams/joists/rafter (not really sure of the correct terminology) and sister then up to the existing beams/joists/rafter. With correct trimming at the ends, they could bear onto the top of the wall. They could be cut to make the beams/joists/rafter either deeper or taller. Something like this. Or better still, if you are boarding, the other way around, so the original timbers are at the top. Edited February 24 by SteamyTea
SimonD Posted February 25 Author Posted February 25 On 23/02/2026 at 22:51, Gus Potter said: Ah, so you are looking for a temporary solution. Well, yes that was the plan and then I got the look from my wife when I mentioned temporary 😉 temporary that in true self-builder style becomes permanent, so I better plan ahead even though we have planning permission for another 1.5 width garage. On 23/02/2026 at 22:51, Gus Potter said: I need to know what the span of the ceiling joists are, their size (width, depth and spacing) and a photo of the timbers so I can see what grade of timber would be appropriate to use as a basis for a design check. Often I would plump for what is now known as a C16 grade, So the ties/joists are rough sawn 50 x 100mm with no grading on them at all. They're installed every other rafter at 32inch centres (approx. give or take an inch or so as they vary ) , so I guess I'll either need to add to each rafter missing the ties. Span is 3.3m. As for load, that's a very good question. I'm not imagining anything particularly heavy, but don't really know what's sensible here. Do I go with the ceiling joist span tables by BSW and the C24 (my usual supplier only stocks C24 anyway) and use something like 45 x 145 or 45 x 170 for some extra margin? If I can get them in there, I still wonder whether new joists bearing on the wall plate might overall be the simplest way?
SimonD Posted February 25 Author Posted February 25 On 24/02/2026 at 13:54, SteamyTea said: as this is temporary, could you not cut some plywood up Good question. I hadn't really thought about it this way but may not be practical given the span is 3.3m so I'd have to sister the plywood sheets too.
SteamyTea Posted February 25 Posted February 25 5 minutes ago, SimonD said: sister the plywood sheets Use an adhesive. You could do a couple of tests and see how it 'feels'.
SimonD Posted February 25 Author Posted February 25 4 minutes ago, SteamyTea said: Use an adhesive. You could do a couple of tests and see how it 'feels'. Yeah, that's what I did with the plywood sheets I used for the stringers for my construction stairs. They have a delightful bounce to them but have been plenty strong enough 😁
Gus Potter Posted February 25 Posted February 25 29 minutes ago, SimonD said: So the ties/joists are rough sawn 50 x 100mm with no grading on them at all. They're installed every other rafter at 32inch centres (approx. give or take an inch or so as they vary ) , so I guess I'll either need to add to each rafter missing the ties. Span is 3.3m. As for load, that's a very good question. I'm not imagining anything particularly heavy, but don't really know what's sensible here. Do I go with the ceiling joist span tables by BSW and the C24 (my usual supplier only stocks C24 anyway) and use something like 45 x 145 or 45 x 170 for some extra margin? If I can get them in there, I still wonder whether new joists bearing on the wall plate might overall be the simplest way? But of practical food for thought and info. 32 inches is about 800 mm. The ceiling ties you have are "economic and serving to hold the head of the wall against moving sideways. It's a basic garage after all. Next is if you have an attic say in a house what loads do the design codes prescribe? Well there are 3 types of load: 1 / The dead (permanent load) which is the self weight of the timber joists and the flooring. 2/ Where the space is habitable the load from people is 1.5 kN/m^2 (~150 kg/ sq metre) in domestic stuff = about 150 kg. This is an onerous load and not really applicable in your case. 3/ Attic storage is 25kg / sq metre.. but that includes the weight of the flooring.. so it works out at about 10 - 11 kg per square metre that you can use to store your xmas trees and empty suitceses etc. If it was a domestic floor (150 kg / m sq) then I would start using an old rule of thumb. It's ok to do this as your garage is probably built in feet / inches so why not use this as a basis. 3.3m ~ 129 inches which is about 11 feet. Divide 11 feet by 2 = 5.5 then add 2 = 7.5 inches depth based on a 2 foot spacing. 7.5" = 7.5 x 25.4 = 190mm! But at 400 mm centres that will drop below 170mm depth. Or lets say we can live with a bit more delfection and a reduced load. The rule of thumb is just to add 1 instead of 2 to the calculation above. This now gives.. divide 11 feet by 2 = 5.5 the add 1 = 6.5 inches depth based on a 2 foot spacing. = 6.5 x 25.4 = 165mm. In summary what I have done above just confirms your first thoughts are in line with normal expectation.. 145 - 170 deep timbers if you put them in at say 400 mm centres look at the moment adequate. I suspect that if you spent more time refining the loads then a 145 mm deep timber in C24 would be ok. After all there is only so much load you can get in there (unless you do something daft) due to the diminishing height as you appraoch the eaves. The main thing here is that the difference in cost between 170 and 145 deep joists is not a lot.. it's the head room and making sure you can open the doors that is key. Can you just essentially leave the roof as it is and introduce an independent floor? This might be possible if you have a timber wall plate on top of the wall. On the inside of the wall you fix a ledger piece, then use wrap over joist hangers with the wrp onto the existing wall plate. The beauty of this is that it's nearly all demountable so you get to recover the joists, flooring if you screw it down and not glue it, live with any squeeks! One last thing though.. you need to have a look at the walls and what they are sitting on, do you have any door openings below the new joists.. think lintel strength. If you add load you have to be sure the walls and founds are not going to misbehave. 1
SimonD Posted February 27 Author Posted February 27 On 25/02/2026 at 21:51, Gus Potter said: This might be possible if you have a timber wall plate on top of the wall. On the inside of the wall you fix a ledger piece, then use wrap over joist hangers with the wrp onto the existing wall plate. The beauty of this is that it's nearly all demountable so you get to recover the joists, flooring if you screw it down and not glue it, live with any squeeks! Thanks Gus, I think this is going to be the solution. I've got loads of spare joist hangers and heavy duty masonry bolts from installing ledgers on the old bungalow walls. With the metal connector nailer, they'll be in in a jiffy, job done! On 25/02/2026 at 21:51, Gus Potter said: One last thing though.. you need to have a look at the walls and what they are sitting on, do you have any door openings below the new joists.. think lintel strength. If you add load you have to be sure the walls and founds are not going to misbehave. From the looks of it, the founds are pretty good, so I think it'll be okay. The door lintel is also a beefy one.
Gus Potter Posted March 2 Posted March 2 On 27/02/2026 at 12:00, SimonD said: I've got loads of spare joist hangers and heavy duty masonry bolts from installing ledgers on the old bungalow walls. Looks like you are your way to a cost effective solution. Watch these masonry bolts as if the expansive anchor type or say Thunder Bolts you can easily disturb / crack the masonry at the top of a wall. If you use the wrap over type hanger then then the wrap (if of say 70mm) does most of the work. Have fun!
