I’m having a couple of hours off the build, so of course I’m on here researching.   No hope is there.
We have 22mm decking (a caberboard equivalent) upstairs throughout.  I believe it’s really nice and flat but I will check that carefully.  I’ve read up all I could find on here, and as a result I think …..
I don’t need to fetch up the flooring to replace with marine ply, but I do need to prime it.  I think this is for adhesion rather than waterproofing.
The tray instructions say lay on a bed of sand and cement, but if the decking is flat then ct1 appears an excellent bedding material.  I can’t believe the mortar mix won’t just turn to dust over time, with footfall and temperature cycling (J has skin removing shower flow temperatures!).
We’ve put 15mm green plasterboard with oodles of screws on max 400mm centres, and we can tank that after fitting the shower tray.  If it’s better or easier or both to do beforehand please correct me.
The wastes are lurking in holes in the floor, all connected up and ready, they sit quivering with anticipation on their own special noggin so they can’t drop too low.  When I actually fit them to the tray I’ll put a wipe of ct1 on the trap itself under the rubber washer, then on the washer, before carefully not cross threading the top bit as I screw it in.   I’ve practised that a couple of times using a 12mm plywood stand in shower tray with a 90mm hole in it.   I really must get out more.
Then I scrubby scrub the shower tray’s bottom, (a clean bottom always helps) before carefully squirting ct1 on the bottom of the tray before dumping it in place.  I then pull it away from the walls a bit and squirt yet more ct1 into the gap before pushing it home.
Next day I run water into the tray and watch underneath for drips or expanding wet patches on my ceilings.  Simples.
So what can I improve on all that?
Edited by G and J
Guess who pressed return too early!
  • G and J changed the title to Shower tray fitting on wood decking
47 minutes ago, MikeGrahamT21 said:
I’ve heard people using flexible tile adhesive in place of sand and cement, seems a good strong option which will flex with heat cycles and loading
There’s a good few posts advocating that too, and I guess from my point of view both will give a good, strong bond with enough flexibility to endure.  I’ve got ct1 and I’ve used it many times so I’m at home with it, hence my preference.  But I’m open to other viewpoints.
Is it a stone-resin tray?
If so, use flexible tile adhesive, it takes much better to the tray, and as you say using said mixture to scrub and key the underside so get a great bond.
Same here. Every one I've taken up to replace has turned to crumbs.
Do as much tanking as you can before fitting, so you don't get it over the new tray. It's best to leave that cure and CT1 the tray to tanking, and then just cut in a final coat after you've fitted the tray. Lots of thin layers and make sure it has dried before fitting the tray.
They are, so will do.  Maybe bulk buying 38 tubes of ct1 wasn’t such a good idea….
Gotcha.  Makes perfect sense.
I think you’re pretty well covered with advice, but I’d second getting as much tanking done beforehand, for what it’s worth I also covered the floor, any joints that were under the tray too, and all round the keyhole for the waste.  Flexible tile adhesive was also used.
oh, have an old towel, some wipes nearby, and someone nearby to help wipe down cos tile adhesive sticks like sh*t and gets everywhere you don’t want it too 😂.
I knew there was a reason I wanted to use ct1 lol
Bucket of water and a sponge, is all you need. Wash your hands and tools frequently, but if you've done the job properly you should not see any tile adhesive after fitting the tray, whatsoever. It should all be under the tray only, so if it's looking like it's going to ooze out everywhere, you mixed too much up!!
Remember you do not put tile adhesive under the lip that runs around the tray underside, the adhesive stays away from those so they can move / flex, you just silicone these gaps later on.
3 minutes ago, G and J said:
Thank you NFW.
However, I must flag how much I hate that word.  Just.   Sigh.
"Simply" any better?
Just........an alternative suggestion lol. Just saying.
It’s the endless ‘just’ jobs that trash hours each day.
It’s the face in your hands frustration of struggling with an awkward task and being asked by those watching  ‘why can’t you just?’
I’ve decided to classify ‘just’ as a swear word.  It can join ‘should’ on the banned list.
I have just installed our Mira stone resin tray (900 x 1700) installation  methods vary manufacturer to manufacturer. Mira recommends bed on a weak sand and cement mix or use a suitable construction adhesive. Their tech help confirmed CT1 would be suitable. I tried the sand/cement mix but wasn’t happy so cleaned it up and redone using a few tubes of clear CT1. Took a leap of faith with the level because once laid in position I could not prize it up off the adhesive. I had lowered with banding straps which snapped when I tried the lift. Left 24hrs and all solid and level.
Check out what Rodger says on the skill builder YouTube channel.
I preferred the clear CT1 for this task. Thought process being that it’s a bit thicker in consistency than the white and the bed needed to make up a 3mm gap.
our previous tray which I installed approx 10 years ago was bedded on the sand and cement mix which was good for years but then developed creaking noises but no obvious movement? On removal,the bedding mix was all cracked and turning to dust.
I read everything the Welsh Wizard posts, he is amazing but do check out skill builder. Mira also told me not to use tile adhesive. You don’t want to bond the tray in position. Even flexi tile adhesive won’t allow for the different expansion movements.
The indecision is a painful.
You already have a suitable adhesive if that helps. How much of a bed do you need to make up under the tray?
