I’m having a couple of hours off the build, so of course I’m on here researching.   No hope is there.
We have 22mm decking (a caberboard equivalent) upstairs throughout.  I believe it’s really nice and flat but I will check that carefully.  I’ve read up all I could find on here, and as a result I think …..
I don’t need to fetch up the flooring to replace with marine ply, but I do need to prime it.  I think this is for adhesion rather than waterproofing.
The tray instructions say lay on a bed of sand and cement, but if the decking is flat then ct1 appears an excellent bedding material.  I can’t believe the mortar mix won’t just turn to dust over time, with footfall and temperature cycling (J has skin removing shower flow temperatures!).
We’ve put 15mm green plasterboard with oodles of screws on max 400mm centres, and we can tank that after fitting the shower tray.  If it’s better or easier or both to do beforehand please correct me.
The wastes are lurking in holes in the floor, all connected up and ready, they sit quivering with anticipation on their own special noggin so they can’t drop too low.  When I actually fit them to the tray I’ll put a wipe of ct1 on the trap itself under the rubber washer, then on the washer, before carefully not cross threading the top bit as I screw it in.   I’ve practised that a couple of times using a 12mm plywood stand in shower tray with a 90mm hole in it.   I really must get out more.
Then I scrubby scrub the shower tray’s bottom, (a clean bottom always helps) before carefully squirting ct1 on the bottom of the tray before dumping it in place.  I then pull it away from the walls a bit and squirt yet more ct1 into the gap before pushing it home.
Next day I run water into the tray and watch underneath for drips or expanding wet patches on my ceilings.  Simples.
So what can I improve on all that?
Edited by G and J
Guess who pressed return too early!
  • G and J changed the title to Shower tray fitting on wood decking
52 minutes ago, Oz07 said:
Has anyone ever bedded one in on foam?
That would scare me.  Partly as I hate foam.
47 minutes ago, MikeGrahamT21 said:
I’ve heard people using flexible tile adhesive in place of sand and cement, seems a good strong option which will flex with heat cycles and loading
There’s a good few posts advocating that too, and I guess from my point of view both will give a good, strong bond with enough flexibility to endure.  I’ve got ct1 and I’ve used it many times so I’m at home with it, hence my preference.  But I’m open to other viewpoints.
Is it a stone-resin tray?
If so, use flexible tile adhesive, it takes much better to the tray, and as you say using said mixture to scrub and key the underside so get a great bond.
Same here. Every one I've taken up to replace has turned to crumbs.
Do as much tanking as you can before fitting, so you don't get it over the new tray. It's best to leave that cure and CT1 the tray to tanking, and then just cut in a final coat after you've fitted the tray. Lots of thin layers and make sure it has dried before fitting the tray.
They are, so will do.  Maybe bulk buying 38 tubes of ct1 wasn’t such a good idea….
Gotcha.  Makes perfect sense.
