Super_Paulie Posted July 14 Author Posted July 14 On 15/02/2026 at 23:51, Nickfromwales said: I've never used backer board and only ever 6mm or more of plywood (glued and screwed down) and then tile straight onto the ply. I've bought this from Wickes before I even clicked on I should have got marine ply. Wickes 6mm ply Will this stuff be ok? I'll be tiling, so priming and flexible adhesive on top of this.
Nickfromwales Posted July 14 Posted July 14 39 minutes ago, Super_Paulie said: I've bought this from Wickes before I even clicked on I should have got marine ply. Wickes 6mm ply Will this stuff be ok? I'll be tiling, so priming and flexible adhesive on top of this. Yup. It'll stick like shit to 2 blankets I've never bought marine ply as if the water is getting to the plywood, you're already wrapped in both of those blankets! 1
Super_Paulie Posted July 15 Author Posted July 15 12 hours ago, Nickfromwales said: Yup. It'll stick like shit to 2 blankets I've never bought marine ply as if the water is getting to the plywood, you're already wrapped in both of those blankets! Great, I'll crack on then. Off work for a few weeks so I'm hoping to get the bathroom somewhere near sorted. Just spent the day setting up a temporary bathroom in the neighbouring bedroom... When you gotta go you gotta go! 1
Nickfromwales Posted July 15 Posted July 15 8 hours ago, Super_Paulie said: Great, I'll crack on then. Off work for a few weeks so I'm hoping to get the bathroom somewhere near sorted. Use LOTS of 4.0 x 25mm screws to fix the plywood down, and if the subfloor is even SLIGHTLY suspect I put the ply down over a 3mm notched bed of neat PVA.
Super_Paulie Posted July 15 Author Posted July 15 5 hours ago, Nickfromwales said: Use LOTS of 4.0 x 25mm screws to fix the plywood down, and if the subfloor is even SLIGHTLY suspect I put the ply down over a 3mm notched bed of neat PVA. That's my plan. 25mm seems scarily close to the pipes though. I've got 20mm and 25mm screws, just to see what I dare put in. Seems 25mm is only an impact driver away from spoiling the whole party with the pipes underneath.
Nickfromwales Posted July 16 Posted July 16 7 hours ago, Super_Paulie said: That's my plan. 25mm seems scarily close to the pipes though. I've got 20mm and 25mm screws, just to see what I dare put in. Seems 25mm is only an impact driver away from spoiling the whole party with the pipes underneath. 22mm deck or 18mm deck? If 22mm deck, plus 6mm ply, then you’ve got 4mm before you poke out the other side. My impact drill has 4 setting for speed / torque, so is much more manageable, but if you’re not rushing you’ll be fine. I mark a grid out and go for a minimum of 120 centres, 100mm best practice imho. Never had issues so I don’t deviate from this.
Super_Paulie Posted July 16 Author Posted July 16 11 hours ago, Nickfromwales said: 22mm deck or 18mm deck? If 22mm deck, plus 6mm ply, then you’ve got 4mm before you poke out the other side. My impact drill has 4 setting for speed / torque, so is much more manageable, but if you’re not rushing you’ll be fine. I mark a grid out and go for a minimum of 120 centres, 100mm best practice imho. Never had issues so I don’t deviate from this. 22mm. Impact is DeWalt and just one speed, it often gets a bit speedy. Wonder if I can use one of those drywall type depth restrictor bits. Probably being overly cautious but the thought of all the work required to sort out a hit pipe under this lot, doesn't bear thinking about quite frankly.
Nickfromwales Posted July 16 Posted July 16 4 hours ago, Super_Paulie said: 22mm. Impact is DeWalt and just one speed, it often gets a bit speedy. Wonder if I can use one of those drywall type depth restrictor bits. Probably being overly cautious but the thought of all the work required to sort out a hit pipe under this lot, doesn't bear thinking about quite frankly. Lol. Squeeze the trigger GENTLY!
Nickfromwales Posted July 16 Posted July 16 👌👍. As the screws will be PZ2 and these bits are PH2, you’ll need to keep a lot of weight on the impact when you’re sending these home. Should work fine, just test fire a few off to get settled in, and bingo-bango. 👌
Russell griffiths Posted July 17 Posted July 17 Wera do a pz2 bit that has a collar on the bit holder so you can’t sink them in past flush. 2
Super_Paulie Posted July 18 Author Posted July 18 On 16/07/2026 at 07:57, Nickfromwales said: I mark a grid out and go for a minimum of 120 centres, 100mm How many screws is this, jesus 😂
Nickfromwales Posted July 19 Posted July 19 7 hours ago, Super_Paulie said: How many screws is this, jesus 😂 Jesus is my stage name, please use it sparingly........my child. lol. Stop whinging and go buy loads of screws, they're cheaper than shoplifting. https://www.screwfix.com/p/goldscrew-pz-double-countersunk-thread-cutting-multipurpose-screws-4mm-x-25mm-200-pack/17430?tc=ET2&gclsrc=aw.ds&gad_source=1&gad_campaignid=19815174909&gbraid=0AAAAAD8IdPxO0lenZYLD6Z3KcA6zQZjuy&gclid=CjwKCAjwyOzSBhBTEiwAmxvJ-rrQHxbaDIuLj8bFNZ-ErefwWyeaAMa9xO000NkTVbbporAuhnbGrRoCf7QQAvD_BwE Amen.
Super_Paulie Posted July 19 Author Posted July 19 9 hours ago, Nickfromwales said: Jesus is my stage name, please use it sparingly........my child. lol. Stop whinging and go buy loads of screws, they're cheaper than shoplifting. https://www.screwfix.com/p/goldscrew-pz-double-countersunk-thread-cutting-multipurpose-screws-4mm-x-25mm-200-pack/17430?tc=ET2&gclsrc=aw.ds&gad_source=1&gad_campaignid=19815174909&gbraid=0AAAAAD8IdPxO0lenZYLD6Z3KcA6zQZjuy&gclid=CjwKCAjwyOzSBhBTEiwAmxvJ-rrQHxbaDIuLj8bFNZ-ErefwWyeaAMa9xO000NkTVbbporAuhnbGrRoCf7QQAvD_BwE Amen. Aye I've got my screws all ready. Just seems a mental amount to put in but I've already drawn the grid now, looks like a Sunday afternoon job. Ran a few tests, think I'm ok with the depth and 25mm screws, takes a lot to get it to go through the other end of the chipboard to be fair. 1
Super_Paulie Posted July 19 Author Posted July 19 Am I just throwing down a load of PVA onto the P5? Just brush the chipboard down, PVA the lot and go to town with the ply and screws? Seems an easy enough job for today.
Nickfromwales Posted July 19 Posted July 19 41 minutes ago, Super_Paulie said: Aye I've got my screws all ready. Just seems a mental amount to put in but I've already drawn the grid now, looks like a Sunday afternoon job. Ran a few tests, think I'm ok with the depth and 25mm screws, takes a lot to get it to go through the other end of the chipboard to be fair. Yup. You’d need to punch them almost completely through the ply to cause any issues, so plenty of time to get off the trigger. Don’t panic if one starts to head in and you didn’t halt at the perfect moment, as that kind of hesitance could mean you're not actually pulling the ply 100% tight to the deck, which is far worse. Just get the screw to pull in so it’s a little countersunk and job done. 1
Nickfromwales Posted July 19 Posted July 19 3 minutes ago, Super_Paulie said: Am I just throwing down a load of PVA onto the P5? Just brush the chipboard down, PVA the lot and go to town with the ply and screws? I use a 3mm notched tile adhesive trowel if it’s a big area, but you can make a ‘comb’ with an 8” bit of the 6mm ply and just cut a load of notches our with a saw. 3 minutes ago, Super_Paulie said: Seems an easy enough job for today That’s the spirit, go get after it! 1
Super_Paulie Posted July 19 Author Posted July 19 Just now, Nickfromwales said: I use a 3mm notched tile adhesive trowel if it’s a big area, but you can make a ‘comb’ with an 8” bit of the 6mm ply and just cut a load of notches our with a saw. That's what I'll try my man, thanks for the tip. 1
Nickfromwales Posted July 19 Posted July 19 24 minutes ago, Super_Paulie said: That's what I'll try my man, thanks for the tip. 👍👍👍
crispy_wafer Posted July 19 Posted July 19 Apologies for butting in, this PVA, is this the same as the contractors liquid PVA that you dilute down, or is this special thicker stuff specifically used as a glue?
Super_Paulie Posted July 19 Author Posted July 19 8 minutes ago, crispy_wafer said: Apologies for butting in, this PVA, is this the same as the contractors liquid PVA that you dilute down, or is this special thicker stuff specifically used as a glue? Hopefully normal stuff as I got this from Screwfix. Just about to start but I'll hang fire 😆
Nickfromwales Posted July 19 Posted July 19 45 minutes ago, Super_Paulie said: Hopefully normal stuff as I got this from Screwfix. Just about to start but I'll hang fire 😆 Fire away.
Super_Paulie Posted July 19 Author Posted July 19 1 minute ago, Nickfromwales said: Fire away. Let's go!
Nickfromwales Posted July 19 Posted July 19 1 minute ago, Super_Paulie said: Let's go! Less typing, more gluing and screwing. “Chop chop”. 👍 1
Super_Paulie Posted July 19 Author Posted July 19 Sorted, thanks Nick and everyone. Time to get the walls boarded. 1
Nickfromwales Posted July 19 Posted July 19 4 minutes ago, Super_Paulie said: Sorted, thanks Nick and everyone. Time to get the walls boarded. Looking A1 👌. Happy days. Another job ticked off 🫡👍 1
