flanagaj Posted Monday at 19:18 Posted Monday at 19:18 I've been asleep at the wheel on this one and should have realised I need to put in another VoC. Due to a pain in the xxxx neighbour, I put the steels in for our retaining wall set forward 400mm to avoid ripping out all of their hedging to the boundary. This has meant that to maintain a reasonable width path (900mm) on the far corner of the property, I need to pull one corner forward 400mm. At the same time, I'd like to raise the ridge height 200mm so that FFL is a bit higher than the surrounding ground level. The houses on the land are all orientated differently and set back from the road by different distances. So I don't suspect it will be refused, but I suppose I don't have any options but to wait the 8 weeks for it to be processed, before making a start?
Big Jimbo Posted Monday at 20:08 Posted Monday at 20:08 If you have got a pain in the butt neighbour it would be safer. However, you can always ask for forgiveness if it gets pulled.
kandgmitchell Posted Tuesday at 12:14 Posted Tuesday at 12:14 I doubt if the height one would even get noticed. Not easy for a planner/man in the street to measure to the ridge when completed. I got planning with stated height of 7580mm, the final design when engineered out was nigh on 7900mm. I didn't go back to revise. It's been 18 months since completion and no-one has commented, indeed everyone has been complimentary. As for pulling the corner forward I'd probably just do it and say you were supporting the neighbour by doing it. I think one has to consider the circumstances carefully. Would there be a reasonable objection to either of these minor changes that if proposed originally would have jeopardized the approval of the scheme? If not then in the worst case a revised application should deal with it. If it might, then I would be more circumspect. My detached garage for instance was approved with a pitched roof. We thought of buying a kit which my wife liked but it was a modern style (as the house is) and had a flat roof. Since it sat close to the road and may have raised a few eyebrows in this rural parish, I varied the condition that said build as per the approval so as to include the flat roof design just to be cautious. @DevilDamo will rightly say that by not complying with the condition to build as per the approved drawings, could put the approval at risk but what's life without a little jeopardy?
Mr Punter Posted Tuesday at 12:27 Posted Tuesday at 12:27 I would just go ahead and do a retrospective if it crops up.
Alan Ambrose Posted Tuesday at 17:41 Posted Tuesday at 17:41 >>> At the same time, I'd like to raise the ridge height 200mm so that FFL is a bit higher than the surrounding ground level. Don't most elevation drawings have ridge relative to ground level anyway so FFL is generally unimportant? Agree VOC's are a bit odd, also the question of whether to file them for inconsequential stuff. Currently my planners want me to do a VOC for a dumb clarification on the elevations. Nothing changes (i.e. it's not a 'variation') - it will just massage the ego of a junior enforcement person.
Nickfromwales Posted Tuesday at 17:46 Posted Tuesday at 17:46 We're dropping DPC by 500mm on a current knock-down, but retaining (or slightly raising) the original ridge height. At +200mm ridge height, I doubt anyone would a) notice, or b) give a shit. If the old biddy next door can see the church tower clock before you know down, and cant see it afterwards, expect trouble, for eg, so each case is completely unique in being able to advise for / against "pushing one's luck".
kandgmitchell Posted Wednesday at 11:28 Posted Wednesday at 11:28 17 hours ago, Nickfromwales said: so each case is completely unique in being able to advise for / against "pushing one's luck". Exactly, we're one of two houses along a length of farm road so who's going to worry/even know the ridge height is a bit higher than approved. It's about being aware of what impact any unauthorised change will have and even if it does have net curtains wobbling, whether the planners will be p...d off enough to take any action. 1
Alan Ambrose Posted yesterday at 10:44 Posted yesterday at 10:44 (edited) It depends entirely on your neighbours. My LPA has taken to fabricating nonsense sourced from my evil neighbour and has recently segued though: i. The building is too high. ii. You are planning unauthorised engineering operations. iii. Your intention is to raise the ground levels on the site. iv. There is unreasonable overlooking. ... and asked me to submit a VOC covering whatever it is they're actually talking about. I've submitted a VOC essentially telling them they need to get better training - I'm sure that will go down well. ... I should add that none of the accusations are true and the Enforcement Officer has not produced any evidence. Doesn't stop them being a nuisance though. p.s. submit a VOC and they won't bother you for 8 weeks or so, and they never will (at least over that issue) if they approve it. That is, you don't need for it to be approved before you start, although you might have a backup plan in case they don't. Edited yesterday at 11:05 by Alan Ambrose 1
Nickfromwales Posted yesterday at 12:11 Posted yesterday at 12:11 Permissions get handed out like penny sweets to developers. Had one client jumping backwards through hoops for 2 years of battling, costs of over £25k for the ‘privilege’, had to set the medium sized house back from the road to not offend the morning commuters, and half a mile further up the road was a developer site, houses 2m from the pavement, and all squeezed in with a shoe horn. These were just horrid red boxes, zero interest and not very ‘easy on the eye’, 2 or 3 PV panels on each, so the developer could trim back of insulation and boost the SAP by cheating, as the cheaper option to facilitate, and garages you couldn’t get a car into if it was tipped on its side = parking on streets / mayhem. The client had to do all sort of things to the house to please the public, including a faux chimney breast (on a PH!); the list went on……just an absolute piss take. Double standards tossers, and the fact it’s ultimately down to one individual to decide is just ridiculous.
marshian Posted 14 hours ago Posted 14 hours ago 11 hours ago, Nickfromwales said: Permissions get handed out like penny sweets to developers. Had one client jumping backwards through hoops for 2 years of battling, costs of over £25k for the ‘privilege’, had to set the medium sized house back from the road to not offend the morning commuters, and half a mile further up the road was a developer site, houses 2m from the pavement, and all squeezed in with a shoe horn. These were just horrid red boxes, zero interest and not very ‘easy on the eye’, 2 or 3 PV panels on each, so the developer could trim back of insulation and boost the SAP by cheating, as the cheaper option to facilitate, and garages you couldn’t get a car into if it was tipped on its side = parking on streets / mayhem. I went to see a friend in Essex a couple of weekend back - passed a new development just outside a village - all 4/5 bed detached houses - all the houses had different aspects north, south, east and west facing - normal for a small dense estate except all the PV was on the front facing roofs so some of the north facing houses it was pretty much window dressing
Nickfromwales Posted 14 hours ago Posted 14 hours ago 23 minutes ago, marshian said: it was pretty much window dressing 12 hours ago, Nickfromwales said: the developer could trim back of insulation and boost the SAP by cheating, as the cheaper option to facilitate Brown envelope city. A north facing array will not get through a basic MCS proposal btw, so these are just for dimwits who favour convenience. Developers say "long live the dimwits".
Big Jimbo Posted 2 hours ago Posted 2 hours ago I used to have planning enforcement down to my place all the time. Building an unauthorised structure in the garden, which turned out to me laying a lawn. I told them to f.off. I then had a legal letter sent to them saying that if they came to my property again, wasting my time, without doing due dilligence first. I would sue the arse off them. Never heard from them since, but i expect when i start my build, they will come calling. I might throw eggs at them next time. I have not made my mind up yet. I find the level of intelligence within the council to be rather lacking. Highways came to inform me that i had to keep the ditch at the front of the property clear. I pointed out that it was full of water. He replied exactly. I pointed out that the reason my ditch was full of water was because i was the only twat in the lane that bothered to keep my ditch clear, while all the others are blocked or non existant. I asked how much he was willing to pay for my education services. He mumbled something, got back in his car, and drove off. Twat. Then there was the twat from the council, who came about my garden fire. I asked him when the council had made the area, a no smoke zone. They hadn't, so i told him i could store 50tons of wood, and burn something like 5tons a day. To f.off and not come back. The list goes on. Total muppets, sharing a brain cell between them.
