flanagaj Posted 2 hours ago Posted 2 hours ago I've been asleep at the wheel on this one and should have realised I need to put in another VoC. Due to a pain in the xxxx neighbour, I put the steels in for our retaining wall set forward 400mm to avoid ripping out all of their hedging to the boundary. This has meant that to maintain a reasonable width path (900mm) on the far corner of the property, I need to pull one corner forward 400mm. At the same time, I'd like to raise the ridge height 200mm so that FFL is a bit higher than the surrounding ground level. The houses on the land are all orientated differently and set back from the road by different distances. So I don't suspect it will be refused, but I suppose I don't have any options but to wait the 8 weeks for it to be processed, before making a start?
Big Jimbo Posted 1 hour ago Posted 1 hour ago If you have got a pain in the butt neighbour it would be safer. However, you can always ask for forgiveness if it gets pulled.
