iMCaan Posted 1 hour ago Posted 1 hour ago I hope this thread is in the correct section. Hi The company that is doing our house as built SAPs as asked me to sign and return Part L1A 2013 Specification to sign off the dwelling, see attached. My concern is we didn't use as much insulation as stated on the form for walls (stated 100mm but used 50mm PIR) and floor (stated 150mm but used 100mm PIR for UFH). Therefore, the house won't achieve the stated u-values. Any suggestions as to what to do? We are ready to move in. Should I be concerned? Oh boy this feels bad but I must ask, should I sign it as stated should I amended it then sign it? What are the consequences? Thanks
JohnMo Posted 1 hour ago Posted 1 hour ago Email them back and state what you did, they will update the U values etc. Then if you get a fail, get ready to install solar PV to make up the difference.
Mr Punter Posted 1 hour ago Posted 1 hour ago If you amend it the house will fail and you will need to spend ££££ on PV to get a pass. That said, solar PV is quite useful. It could still fail on fabric efficiency.
iMCaan Posted 50 minutes ago Author Posted 50 minutes ago I was hoping you would just say just sign the form without amendments. How would they know what insulation you have used? arggggh I don't have the funds for the solar After 5 years, we just want to move in.
JohnMo Posted 46 minutes ago Posted 46 minutes ago 2 minutes ago, iMCaan said: I was hoping you would just say just sign the form without amendments. How would they know what insulation you have used? arggggh I don't have the funds for the solar After 5 years, we just want to move in. Then don't ask questions you don't want a truthful answer too - which isn't what you want hear!🫣
iMCaan Posted 37 minutes ago Author Posted 37 minutes ago (edited) It's just frustration. I asked the questions to hear the truth. Besides solar, how long would you have to fit the solar? Can they enforce adding insulated plasterboard, which would mean a lot of work? Edited 35 minutes ago by iMCaan
saveasteading Posted 34 minutes ago Posted 34 minutes ago But have yph changed from 100 dritgerm to 50 pir? Much the same performance?
iMCaan Posted 17 minutes ago Author Posted 17 minutes ago Yeh we used 50mm pir insulation in walls. The cavity walls were 300mm with in total (100mm blocks, 50mm PIR insulation, 50mm cavity and 100mm stone). 100mm PIR insulation on ground floor for UFH. 25mm PIR insulation for first floor UFH. 200mm earthwool between joists. 400mm earthwool above joists. 150mm PIR insulation for slopped roof.
