jfb Posted Saturday at 21:09 Posted Saturday at 21:09 Can anyone recommend a suitable pump replacement for this one? well, I’m assuming it’s the pump as the boiler is working but the heat never gets far from the boiler at all and the pump is making non standard noises!
Nickfromwales Posted Saturday at 21:15 Posted Saturday at 21:15 Gravity system with a heat only boiler? I'm less of a fan of Grundfos these days, and am steering towards Wilo more often. The 5 means 5m head, so most off the shelf standard circulators will do the job. This one may suit your needs and should be available locally LINK Hopefully the pump valves will hold well enough for a deft switch over, but expect them to not close fully.
John Carroll Posted Saturday at 21:54 Posted Saturday at 21:54 Open & shut the pump isolating valves 3 or 4 times, should then hold OK. I have a 6M Wilo Yonos Pico Pump, running fine and silent for the past 7 years.
ProDave Posted Saturday at 22:03 Posted Saturday at 22:03 48 minutes ago, Nickfromwales said: Gravity system with a heat only boiler? First check the header tank is not dry.
jfb Posted Saturday at 22:14 Author Posted Saturday at 22:14 32 minutes ago, Nickfromwales said: Gravity system with a heat only boiler? Thanks for the quick response Nick. I’m not a plumbing expert but I think it’s a gravity system! The boiler does heating and feeds the hot water tank and there are a couple of tanks in the loft. im a bit worried about how well the isolators will work as I know there’s already an old isolator in the hot water cupboard that doesn’t turn! So im a little reluctant to have a go myself in case I can’t get the new one to fit properly. But it would be cheaper than getting someone in to do it!
jfb Posted Saturday at 22:18 Author Posted Saturday at 22:18 11 minutes ago, ProDave said: First check the header tank is not dry. Just seen this. Ok I will do. Does that still influence whether the boiler will work for the heating if there is no call for hot water?
marshian Posted 12 hours ago Posted 12 hours ago 23 hours ago, Nickfromwales said: Gravity system with a heat only boiler? I'm less of a fan of Grundfos these days, and am steering towards Wilo more often. The 5 means 5m head, I bought a DAB but since hearing what you can do with the head adjustment from @John Carroll if I ever have to replace it I'll go for Wilo 23 hours ago, Nickfromwales said: This one may suit your needs and should be available locally LINK Drop in replacement 23 hours ago, Nickfromwales said: Hopefully the pump valves will hold well enough for a deft switch over, but expect them to not close fully. I think I'd do the job properly - drain system down and replace the valves at the same time as the pump but that's because I'd want to give the valves the best chance next time the pump needs replacing
Nickfromwales Posted 10 hours ago Posted 10 hours ago 1 hour ago, marshian said: I think I'd do the job properly - drain system down and replace the valves at the same time as the pump but that's because I'd want to give the valves the best chance next time the pump needs replacing Yes, but what exactly is the point in fitting pump isolation valves, if you change them every time you change the pump? May as well just hard plumb the pumps at that stage. Worth seeing if they hold as it's a basement or summat by the look of it, so a few drops of water ain't gonna hurt, but the changeover will be a 30 min job.
marshian Posted 10 hours ago Posted 10 hours ago 21 minutes ago, Nickfromwales said: Yes, but what exactly is the point in fitting pump isolation valves, if you change them every time you change the pump? May as well just hard plumb the pumps at that stage. Worth seeing if they hold as it's a basement or summat by the look of it, so a few drops of water ain't gonna hurt, but the changeover will be a 30 min job. I hear you but in my experience the pump valves have normally been in a heck of a lot longer than the current pump and are normally badgered Time before last when I replaced a pump the valves were badgered and I did it with the acceptance of some water leakage The next time I replace the pump I did pump and valves with a partial drain down - when that pump failed the valves held with the next pump replacement Caveat - I've been in this house since 1991 so it not like I've burnt thro pumps
Nickfromwales Posted 10 hours ago Posted 10 hours ago 13 minutes ago, marshian said: I hear you Likewise, but these aren’t original-looking, old ass valves in the op. You know I’m like a dog with a bone so this one’s worth a bit of (maybe mis) adventure afaic. “What if they work?” 👀
marshian Posted 10 hours ago Posted 10 hours ago 7 minutes ago, Nickfromwales said: Likewise, but these aren’t original-looking, old ass valves in the op. You know I’m like a dog with a bone so this one’s worth a bit of (maybe mis) adventure afaic. “What if they work?” 👀 Yeah but they look a bit leaky!!! Perhaps that's just me!!!
Nickfromwales Posted 9 hours ago Posted 9 hours ago Not the stems, just the pump nuts. Also, brass doesn’t rust so it’s the pump that’s corroding not the valves. Very likely the original pump has those nasty rigid washers, not the modern, more compliant rubber ones. Dog. Bone. 🤣 1
Nickfromwales Posted 9 hours ago Posted 9 hours ago @jfb Get your wellies ready son, we’re going in…..
marshian Posted 8 hours ago Posted 8 hours ago 32 minutes ago, Nickfromwales said: @jfb Get your wellies ready son, we’re going in….. Bucket and towels Leave the spade for the beach
Nickfromwales Posted 8 hours ago Posted 8 hours ago 8 minutes ago, marshian said: Bucket and towels Leave the spade for the beach The spade is for me to dig my own hole, if the house floods when he pulls the pump out
Onoff Posted 7 hours ago Posted 7 hours ago I'd give the pump threads and washer faces a good smear of Jet Blue Plus. Each to their own on goopy tub stuff but it's my goto. I use it mainly on compression fittings and find I don't need PTFE tape. The stuff stops that horrible brass squeak noise, let's you nip a bit tighter and fills any little voids, it's just wonderful. No more weepy joints here.
Nickfromwales Posted 53 minutes ago Posted 53 minutes ago 6 hours ago, Onoff said: I'd give the pump threads and washer faces a good smear of Jet Blue Plus. Each to their own on goopy tub stuff but it's my goto. I use it mainly on compression fittings and find I don't need PTFE tape. The stuff stops that horrible brass squeak noise, let's you nip a bit tighter and fills any little voids, it's just wonderful. No more weepy joints here. Now I’m the complete opposite. Yes to putting something on the threads, but I always clean the mating faces and that allows the rubber to have friction. This otherwise, in the hands of someone not doing this day in day out, can lead to the rubber just being displaced and ending up in the centre of the fitting doing feck all. Threads yes, mating faces clean and dry for me.
