Hi I have a 85sq m Bungalow which is pretty well sealed up, so consequently got mould problems. Thinking about getting some window vents fitted and a PIV system, what does anybody think of these, whats a good make to get, should I get one with a heater in or not, are they expensive to run with a heater in. anything I have missed ?Thanks in advance
You can either suck air from the loft and blow out of room vents, or suck in through room vents and blow out of wet rooms. I prefer the later but either will work. PIV may be easier to install.
But either way I would want it humidity controlled to limit ventilation when possible. So fan humidity controlled and room vents the same. This way you only really ventilate where it's needed.
So if PIV, find one with humidity control of fan speed
Or dMEV fans in wetrooms only, something like Greenwood CV2 or CV3.
Suck out if your can.
Replacing bathroom fans with dMEV like John said is the easiest and cheapest.
You probably have loft space for a centeralised MEV system or maybe even a MVHR if you want to go all in.
Hi, been talking to Vent Axia about their centralised MEV system and they have said I need to get somebody to survey the bungalow  as you need to measure duct length and pressure build up, etc to get the correct system for the job, is this correct. Or is there a better way to tailor the system to the house.
Plenty of companies do MEV. You want one that automatically adjusts fan speed for humidity levels with extract vents that open and close automatically also. Then couple that with humidity activated inlet vents either in window or through wall.
Do some reading via Google
Passivent, Deco, to name a couple.
You need to have air movement with cross ventilation dry areas to wet and out the house. To allow this you also need door under cuts or through wall vent grills.
I would keep it simple and do dMEV, with all the features mentioned above.
I fitted a PIV unit centrally in the house (4 bed over two floors) as a result of humidity levels spiking after I insulated under my suspended ground floor (great idea from a heat loss perspective but it had clearly been a major contributor of uncontrolled air ingress)
Within a few days the PIV unit had brought the house into a level of control initially on a higher flow setting but now it's on a timed schedule (midnight to 6.00 am and 8.30 am to 3.00 pm as this works for our occupancy routine.
I did buy one with a heater but 400W consumption can rapidly increase electricity usage when it cuts in so I've got it turned off.
I do have trickle vents in a few windows (not all because most predate the requirement) but a fair percentage of the air pushed into the house is ventilated out via bathrooms fan extracts even when the fans are off. (this is exactly what I need as dry air expels the warm wet air in bathrooms)
Overall it works well for us
They’re best avoided - the problem is that they tend to push moisture-laiden internal air through gaps in the building, leading to condensation within the structure.
MEV avoids this risk. Choose either a central central unit, or decentralised dMEV.
If you're not going to DIY it, then yes, you need to find a contractor to propose a solution. You can post their proposal here for feedback.
I once had a PIV and it failed after a year or so. Nuaire wanted me to send the whole unit to them for investigation. Never got around to it. I also had the model without a heater. Consequently, it was always freezing upstairs.
Anyway, I ended up fitting an MVHR system and its been game changing since. It was an absolute nightmare to install mind. Had to rebuild some stud walls upstairs to hide ducts, but got there in the end.
If you had the inclination, and being a bungalow, I imagine installing a similar system would be fairly straight forward and relatively cheaper. Something to mull over I suppose.
2 hours ago, Potatoman said:
dMEV fans but as it is retrofit project how would I power them
2 minutes ago, Iceverge said:
Swap straight out for bathroom extractor fans
If you go Greenwood CV2 or CV3 you just need mains power to the fan, nothing else. Then set to smart humidity control and it sort everything else out. If you don't have existing fans get the electrician to tap in to lighting ring main to powers, they draw a couple of watts.
For dMEV to work correctly you NEED vents in dry rooms, AND door under cuts.
  • 3 weeks later...
Easy to DIY MVHR in a banalow, these days I would use a good semi flexible duct system.   No need to balance or get airflow 100% correct.
But if cheap electricity a dehumidifier is also a good option.
Really! Missing a trick if you don't, the heat exchanger becomes unbalanced and you don't get the heat recovery you should. Do properly or really don't bother wasting your time, effort and shed load of cash on MVHR.
Let's go back a stage before throwing money at fashionable tech.
Where is the humidity coming from?
Is it just wet rooms and breathing? If so then extractor fans as above is the simple first step.
But could there be dampness problems through the fabric?
Many MVHR will these days automatically balance between extractions and replacement air flow.  I don't care how the extractions is balanced between kitchen and bathrooms, or the replacement between other rooms provided all rooms get a reasonable air flow.
  • Sad 1
Utter nonsense.
The system needs to be balanced, which is part of a proper commissioning process.
MVHR units can’t balance, they have fans pushing air in / out, and are subject to the flow and distance to each terminal; ones closer to the unit will see huge flow rates, ones furthest away much less.
Whether you care or not isn’t a good platform for giving advice. Do the job properly or not at all ;)
  • Like 3
The system should definitely be balanced by system design, but some units (including all Brink ones, I believe) auto balance by adjusting relative fan speeds.
I seem to recall that some actually allow you to set a slight bias one way or the other, to slightly pressurise or depressurise the house.
Does nobody agree with me that the first issue is find why it is damp.
It is unlikely to be a sealed building so extract fans will find air to pull in.
There is a tendency to throw expensive technology at an issue before proper investigation.
Gutter, dpc, render?
@Potatoman where is the damp? On windows, walls, generally?
I agree with this, but was just commenting on the MVHR balancing point (and not suggesting the MVHR is the solution here).
@Potatoman, for a short term fix while you figure out what's happening and what to do about it, consider getting a dehumidifier. They can make a world of difference and aren't expensive to run (pennies per hour). If you consider this option, look at Meaco. They're a British company who make very good quality units for not crazy prices. Three year warranty as standard and I've heard of them helping people beyond that time too.
Yea, same with systems we use in swimming pool halls, so the buildings constantly depressurised. This promotes chlorine being evacuated vs the space being pressurised and it then trying to find a way out through the build fabric (or into the house).
Learn some odd facts along the way when dealing with loads of different / bespoke projects, and I’ve picked up lots of important things you’d (and I’d) otherwise never have thought twice about.
I completely agree. Investigate first.
For example - when we bought our shell for development, the bungalow built in the 1920s, which we had to live in for a few years was extremely damp - I installed a pretty heavy duty extractor in the bathroom as a first step because there wasn't one in there. We found problems in a few of the rooms that had to be addressed and when we stripped out the old kitchen, we found black mould completely covering the wall behind the cupboards.
