Pocster Posted 10 hours ago Posted 10 hours ago Ran out of floor tiles ! apparently discontinued- can’t find anywhere ! (expletive deleted)
-rick- Posted 10 hours ago Posted 10 hours ago 6 minutes ago, Iceverge said: You could substitute in some walk on glazing. I laughed but then felt a pang of guilt that @Pocster is always at the arse end of jokes. I'm not even sure I get the joke as I've read a lot of the threads on here and don't feel I've read about what must be a hell of a story. 🙃 1
Pocster Posted 10 hours ago Author Posted 10 hours ago 14 minutes ago, Iceverge said: You could substitute in some walk on glazing. You know what I said out loud when I read your reply ? “ (expletive deleted)ing (expletive deleted) (expletive deleted) bastard mofo (expletive deleted) “ 1
Pocster Posted 10 hours ago Author Posted 10 hours ago I suppose it could be worse . This is a utility room - any different tiles wouldn’t be seen from the doorway . Got some spare black bathroom ones I could use in the centre . When you can’t hide it make a feature ?? 🙄
Pocster Posted 10 hours ago Author Posted 10 hours ago (edited) Or rip up the others in the centre ? I.e so there’s a strip running the length of the room . But my gut instinct is getting them up will be a bitch ! Edited 10 hours ago by Pocster
Pocster Posted 9 hours ago Author Posted 9 hours ago I think best is to not bother with a “ strip “ nor attempt to match ( and fail ) . So tile half differently so it looks deliberate. But with what ?
ProDave Posted 9 hours ago Posted 9 hours ago Tile the WHOLE utility room different. Keep the rest of the white ones as spares for the other rooms. 1
Pocster Posted 9 hours ago Author Posted 9 hours ago 3 minutes ago, ProDave said: Tile the WHOLE utility room different. Keep the rest of the white ones as spares for the other rooms. But that means ripping them up ! I’m not sure how easy that will be !!
ProDave Posted 9 hours ago Posted 9 hours ago 10 minutes ago, Pocster said: But that means ripping them up ! I’m not sure how easy that will be !! You should have counted how many you had before you started that room....... 1
ProDave Posted 9 hours ago Posted 9 hours ago Surely a utility room will have a sink unit or something, put the odd ones under there?
Pocster Posted 9 hours ago Author Posted 9 hours ago 14 minutes ago, ProDave said: Surely a utility room will have a sink unit or something, put the odd ones under there? Nah ! It’s not really an anything room . Anyway I kind of guessed they’d be coming up . Tiles aren’t to bad - cleaning the ditra not much fun !
SteamyTea Posted 8 hours ago Posted 8 hours ago (edited) Lay what you can, then fill where the missing ones go with some concrete. Then cover in cheap vinyl flooring. Edited 8 hours ago by SteamyTea 1
Pocster Posted 7 hours ago Author Posted 7 hours ago 57 minutes ago, SteamyTea said: Lay what you can, then fill where the missing ones go with some concrete. Then cover in cheap vinyl flooring. I did contemplate doing a bodge like that . But I won’t ever sleep knowing the hideous thing I’ve done . The other hideous things I’ve done I can live with !
Iceverge Posted 6 hours ago Posted 6 hours ago Get the best match you can. Dry lay them. See if you can tell the difference. If you can rip up the rest of the old tiles and finish it with the new tiles.
SteamyTea Posted 6 hours ago Posted 6 hours ago 56 minutes ago, Pocster said: other hideous things I’ve done I can live with https://youtu.be/gnsoRheU_v8?list=RDgnsoRheU_v8
