dustyb Posted Tuesday at 15:02 Posted Tuesday at 15:02 We've just had a look at a house which needs a full renovation but was thinking, maybe, it might be better to demolish it and start again. This will be my first question on the forum so be gentle🙂. If you wanted to actually build the property yourself and time wasn't a problem but price would be, which method would you look at. There seems to be 6 different ways on this forum (sips,blockwork,timberframe,steelframe etc) so any advice from anyone who has built one way but regretted it would be interested.
Post and beam Posted Tuesday at 17:50 Posted Tuesday at 17:50 Depends on your skill level, physical ability to climb heights etc, attitude to risk. Also the size of building and the space/layout of the plot. Loads of other variables i'm sure but a little more detail would be good. I didn't build mine, but i am very experienced at hitting 'buy now' .Â
dustyb Posted Wednesday at 09:20 Author Posted Wednesday at 09:20 Thank you for your reply. Skill level- jack of all trades, master of none. I don't mean that to sound flippant but have done a few small renovations in the past. Not scared to have a go, have always had a problem letting someone else do a job for me, cause I can't justify the cost. Will probably want to replace the house (bungalow) with another bungalow or maybe chalet bungalow due to height of neighbouring properties. Will probably be the start of a long journey but at the moment I'm wanting to do some research on construction methods used by self builders who actually did build it themselves
G and J Posted Wednesday at 09:29 Posted Wednesday at 09:29 Not me, but G, and not finished, but have a look at our blog......demolished bungalow and timber frame build 2 1
jack Posted Wednesday at 09:30 Posted Wednesday at 09:30 Welcome to the forum.  In your situation, I'd consider insulated concrete formwork (ICF). Excellent structural and thermal performance, and good results are possible even with minimal building experience (although I'm sure it helps a lot if you're generally "handy"). Many of the big formwork suppliers run training programmes for self builders. Google search of BuildHub for 'ICF': https://www.google.com/search?q=icf+site%3Abuildhub.org.uk  Personally, I'd stay away from SIPs. No-one ever posts about how great their experience was building with them, and plenty have had serious problems.  1
Nestor Posted Wednesday at 09:53 Posted Wednesday at 09:53 (edited) 39 minutes ago, dustyb said: Not scared to have a go, have always had a problem letting someone else do a job for me, cause I can't justify the cost. Had some very minor domestic renovation experience but achieved possibly 90% of our self build. Paid professionals for electrics, plaster skimming, ASHP, window installation and screed. It is doable, time, money, quality consideration. 3 years before we moved in and 6 years later fitting final architrave ready for repainting!! Has been an amazing experience, learnt so much and the amazing contributions from Buildhub. My Dad, 75 years at the time helped me with the stick build. Would look at other build methods in the future. Edited Wednesday at 10:01 by Nestor 2 1
Russell griffiths Posted Wednesday at 09:55 Posted Wednesday at 09:55 If you want to do as much as possible yourself then I think there’s a few options. icf you can do everything yourself timber kit, get that put up and then finish it yourself timber built on site, you will probably need a couple of carpenters to help brick block cavity you will need a bricklaying gang.  will also depend if you have a large chunk of cash up front, timber frame erected on site will probably be the heaviest up front cost.  icf has a large up front cost, but probably 20% of a timberframe then you can drip feed cash into it.  brick n block lowest up front cost but large weekly payments for labour. 2 1
Nickfromwales Posted Wednesday at 11:08 Posted Wednesday at 11:08 1 hour ago, jack said: Welcome to the forum.  In your situation, I'd consider insulated concrete formwork (ICF). Excellent structural and thermal performance, and good results are possible even with minimal building experience (although I'm sure it helps a lot if you're generally "handy"). Many of the big formwork suppliers run training programmes for self builders. Google search of BuildHub for 'ICF': https://www.google.com/search?q=icf+site%3Abuildhub.org.uk  Personally, I'd stay away from SIPs. No-one ever posts about how great their experience was building with them, and plenty have had serious problems.  Ditto. SIPS would be my last choice, but then I’d just go masonry and simplify. 1
Nickfromwales Posted Wednesday at 11:14 Posted Wednesday at 11:14 1 hour ago, dustyb said: Not scared to have a go, have always had a problem letting someone else do a job for me, cause I can't justify the cost. You’ll need to get over this aversion, but directing the right funds to the right people, at an appropriate and controlled time.  1 hour ago, dustyb said: Will probably want to replace the house (bungalow) with another bungalow or maybe chalet bungalow due to height of neighbouring properties. Look to go 1.5 storeys as to build a bungalow is just such a waste of the same footprint. It’s not much more cost to put rooms in a roof, 2 birds with 1 stone afaic, so look at costing out both options. But for planning I’d go for the 1.5 storey first and see if it gets passed, as the long term resale value for an extra bedroom with ensuite upstairs would be significant, and may be somewhere where you can recover part of the overall investment (in equity).  Bungalows suck imo lol. Why use up a good piece of land to only utilise half the potentially habitable space?? 1
Roger440 Posted Wednesday at 22:32 Posted Wednesday at 22:32 11 hours ago, Nickfromwales said: Â Â Bungalows suck imo lol. Why use up a good piece of land to only utilise half the potentially habitable space?? Â Depends if the land is valuable. Â Id build a bungalow tommorow if i could. But my land is near worthless........... Â Oh, and one day we will be old and infirm 1
Roger440 Posted Wednesday at 22:33 Posted Wednesday at 22:33 12 hours ago, Russell griffiths said: If you want to do as much as possible yourself then I think there’s a few options. icf you can do everything yourself timber kit, get that put up and then finish it yourself timber built on site, you will probably need a couple of carpenters to help brick block cavity you will need a bricklaying gang.  will also depend if you have a large chunk of cash up front, timber frame erected on site will probably be the heaviest up front cost.  icf has a large up front cost, but probably 20% of a timberframe then you can drip feed cash into it.  brick n block lowest up front cost but large weekly payments for labour.  How can you do ICF yourself. Not going to do the concrete!
Roger440 Posted Wednesday at 22:36 Posted Wednesday at 22:36 On 06/01/2026 at 15:02, dustyb said: We've just had a look at a house which needs a full renovation but was thinking, maybe, it might be better to demolish it and start again. This will be my first question on the forum so be gentle🙂. If you wanted to actually build the property yourself and time wasn't a problem but price would be, which method would you look at. There seems to be 6 different ways on this forum (sips,blockwork,timberframe,steelframe etc) so any advice from anyone who has built one way but regretted it would be interested.  Though ive abandoned my self build aspirations, i spent a lot of time pondering.  If you are actually going to do it yourself, masonary or timber frame. That was my conclusion.  Does knocking down and rebuilding make economic sense? Id do it tommorow if i could, but the "non-building costs" and planning issues kill it completely. 1
dustyb Posted Wednesday at 23:44 Author Posted Wednesday at 23:44 Thanks for all your replies so far. You've surprised me about sips but interesting that icf seems a popular choice as that has been recommended from elsewhere. Nestor, that is one beautiful home, you must be really proud. Nickfromwales- I guess we are all getting older so there will always be a market for a bungalow, in my opinion, but understand your reasoning G&J- will have a read of your blog Roger440- I'm sure there are better people to answer the knocking down and starting again reason on here, which is why I've joined this forum
Nick Laslett Posted Thursday at 07:18 Posted Thursday at 07:18 On 06/01/2026 at 15:02, dustyb said: We've just had a look at a house which needs a full renovation but was thinking, maybe, it might be better to demolish it and start again. This will be my first question on the forum so be gentle🙂. If you wanted to actually build the property yourself and time wasn't a problem but price would be, which method would you look at. There seems to be 6 different ways on this forum (sips,blockwork,timberframe,steelframe etc) so any advice from anyone who has built one way but regretted it would be interested. If price is your primary concern. Take a look at this channel doing an ICF Ecobrix build.  https://www.youtube.com/@TurningRosemountUpsideDown 1
Russell griffiths Posted Thursday at 08:07 Posted Thursday at 08:07 9 hours ago, Roger440 said:  How can you do ICF yourself. Not going to do the concrete! Well the concrete comes in a ready mix truck, and you need to hire a pump to get it up to the top of the wall, but that’s about it.  like saying you can’t put a timberframe up yourself because you haven’t got a crane. 1
Post and beam Posted Thursday at 09:20 Posted Thursday at 09:20 Our new house is a SIPs construction and i am very happy with it. This the only house i have ever had built or will ever build so have nothing to compare it against. It is warm, draught free, straight square and true to dimensions.  There have been issues, mostly with Potton Homes but i do not regard these as related to the basic construction method.  On the subject of knock down & rebuild, there is a bungalow next door to us that is up for sale @ £500k for 662 square metres. It is non standard construction, single skin walls, tiny and poorly made. The foundations are not up to the job of adding a second floor. All of the people that i have talked to that have come to view it have said that the only thing to do with it would be to remove it and build new. But, the asking price makes this non viable. I guess this is likely to be the case with a lot of houses around the country. 1
Roger440 Posted Thursday at 10:53 Posted Thursday at 10:53 2 hours ago, Russell griffiths said: Well the concrete comes in a ready mix truck, and you need to hire a pump to get it up to the top of the wall, but that’s about it.  like saying you can’t put a timberframe up yourself because you haven’t got a crane.  Not really. Concrete work on that scale means a team of people and equipment. Thats not what id call DIY, though perfectly acceptable if you want to pay.  DIY concrete has many pitfalls for the unwary, and re-work is rather harder than with timber frame. I can do most things, but id not tackle ICF on a DIY basis. 1
Roger440 Posted Thursday at 10:55 Posted Thursday at 10:55 11 hours ago, dustyb said: Thanks for all your replies so far. You've surprised me about sips but interesting that icf seems a popular choice as that has been recommended from elsewhere. Nestor, that is one beautiful home, you must be really proud. Nickfromwales- I guess we are all getting older so there will always be a market for a bungalow, in my opinion, but understand your reasoning G&J- will have a read of your blog Roger440- I'm sure there are better people to answer the knocking down and starting again reason on here, which is why I've joined this forum  Indeed there are. Which is why when you suggested it, i took an interest, as, in my expeience its rare that it can fly financially.  Do keep us posted if you go down that route. 1
Russell griffiths Posted Thursday at 13:29 Posted Thursday at 13:29 2 hours ago, Roger440 said:  Not really. Concrete work on that scale means a team of people and equipment. Thats not what id call DIY, though perfectly acceptable if you want to pay.  DIY concrete has many pitfalls for the unwary, and re-work is rather harder than with timber frame. I can do most things, but id not tackle ICF on a DIY basis. Nope. I poured 27 cubic metres on our first pour with me and one helper. there was the owner operator of the pump working that, then just two of us using the vibrator and checking it was all plumb.  Icf is very diy friendly your not pouring a flat house floor that needs to be within 3-5 mm tolerance  your pouring wet concrete inside form work that you have already plumbed up  theres a good few on this forum that have done their own icf including the pours.Â
Roger440 Posted Thursday at 13:36 Posted Thursday at 13:36 7 minutes ago, Russell griffiths said: Nope. I poured 27 cubic metres on our first pour with me and one helper. there was the owner operator of the pump working that, then just two of us using the vibrator and checking it was all plumb.  Icf is very diy friendly your not pouring a flat house floor that needs to be within 3-5 mm tolerance  your pouring wet concrete inside form work that you have already plumbed up  theres a good few on this forum that have done their own icf including the pours.  Good work. Dont think i would try it.
G and J Posted Friday at 21:08 Posted Friday at 21:08 On 06/01/2026 at 15:02, dustyb said: We've just had a look at a house which needs a full renovation but was thinking, maybe, it might be better to demolish it and start again. This will be my first question on the forum so be gentle🙂. If you wanted to actually build the property yourself and time wasn't a problem but price would be, which method would you look at. There seems to be 6 different ways on this forum (sips,blockwork,timberframe,steelframe etc) so any advice from anyone who has built one way but regretted it would be interested. Sorry to be über boring, but how bad is the existing building?
Iceverge Posted Friday at 22:12 Posted Friday at 22:12 On 06/01/2026 at 15:02, dustyb said: better to demolish it and start again   HURRAY!!!!!   On 07/01/2026 at 09:53, Nestor said: Has been an amazing experience, learnt so much and the amazing contributions from Buildhub. My Dad, 75 years at the time helped me with the stick build. Would look at other build methods in the future.  Interesting, I would love to stick frame a house. Mainly because I just love hammering bits of timber together. There were large aspects of our masonry house I hated with the dust and the hardship that TF avoids. What other method would you like?!  On 07/01/2026 at 11:14, Nickfromwales said: You’ll need to get over this aversion, but directing the right funds to the right people, at an appropriate and controlled time.   Good people are always worth paying. Bad people are worth paying to keep them away.  On 08/01/2026 at 10:53, Roger440 said: Not really. Concrete work on that scale means a team of people and equipment. Thats not what id call DIY, though perfectly acceptable if you want to pay.  Depends on how fast you are blockwork. One mason built out house with no labourer.  Icf Always stuck me as the wrong way around.nsoft on the outside and hard on the inside. Like a Dime bar when what you really need is an Armadillo.  TF or masonry I think are the best.Â
Nickfromwales Posted Friday at 22:46 Posted Friday at 22:46 34 minutes ago, Iceverge said: Good people are always worth paying. Bad people are worth paying to keep them away. Can I just have some money for the heck of it?
Iceverge Posted Friday at 23:15 Posted Friday at 23:15 No problem.  I'll give you 50p but I must subtract the cost of the stamp from that. 1
