We've just had a look at a house which needs a full renovation but was thinking, maybe, it might be better to demolish it and start again. This will be my first question on the forum so be gentle🙂. If you wanted to actually build the property yourself and time wasn't a problem but price would be, which method would you look at. There seems to be 6 different ways on this forum (sips,blockwork,timberframe,steelframe etc) so any advice from anyone who has built one way but regretted it would be interested.
Depends on your skill level, physical ability to climb heights etc, attitude to risk. Also the size of building and the space/layout of the plot. Loads of other variables i'm sure but a little more detail would be good.
I didn't build mine, but i am very experienced at hitting 'buy now' .
Thank you for your reply.
Skill level- jack of all trades, master of none. I don't mean that to sound flippant but have done a few small renovations in the past. Not scared to have a go, have always had a problem letting someone else do a job for me, cause I can't justify the cost.
Will probably want to replace the house (bungalow) with another bungalow or maybe chalet bungalow due to height of neighbouring properties.
Will probably be the start of a long journey but at the moment I'm wanting to do some research on construction methods used by self builders who actually did build it themselves
Not me, but G, and not finished, but have a look at our blog......demolished bungalow and timber frame build
Welcome to the forum.
In your situation, I'd consider insulated concrete formwork (ICF). Excellent structural and thermal performance, and good results are possible even with minimal building experience (although I'm sure it helps a lot if you're generally "handy"). Many of the big formwork suppliers run training programmes for self builders.
Google search of BuildHub for 'ICF': https://www.google.com/search?q=icf+site%3Abuildhub.org.uk
Personally, I'd stay away from SIPs. No-one ever posts about how great their experience was building with them, and plenty have had serious problems.
Had some very minor domestic renovation experience but achieved possibly 90% of our self build.
Paid professionals for electrics, plaster skimming, ASHP, window installation and screed.
It is doable, time, money, quality consideration.
3 years before we moved in and 6 years later fitting final architrave ready for repainting!!
Has been an amazing experience, learnt so much and the amazing contributions from Buildhub.
My Dad, 75 years at the time helped me with the stick build.
Would look at other build methods in the future.
Edited by Nestor
  • Like 4
If you want to do as much as possible yourself then I think there’s a few options.
icf you can do everything yourself
timber kit, get that put up and then finish it yourself
timber built on site, you will probably need a couple of carpenters to help
brick block cavity you will need a bricklaying gang.
will also depend if you have a large chunk of cash up front, timber frame erected on site will probably be the heaviest up front cost.
icf has a large up front cost, but probably 20% of a timberframe then you can drip feed cash into it.
brick n block lowest up front cost but large weekly payments for labour.
Ditto. SIPS would be my last choice, but then I’d just go masonry and simplify.
You’ll need to get over this aversion, but directing the right funds to the right people, at an appropriate and controlled time. ;)
Look to go 1.5 storeys as to build a bungalow is just such a waste of the same footprint. It’s not much more cost to put rooms in a roof, 2 birds with 1 stone afaic, so look at costing out both options. But for planning I’d go for the 1.5 storey first and see if it gets passed, as the long term resale value for an extra bedroom with ensuite upstairs would be significant, and may be somewhere where you can recover part of the overall investment (in equity).
Bungalows suck imo lol. Why use up a good piece of land to only utilise half the potentially habitable space??
Depends if the land is valuable.
Id build a bungalow tommorow if i could. But my land is near worthless...........
Oh, and one day we will be old and infirm
How can you do ICF yourself. Not going to do the concrete!
Though ive abandoned my self build aspirations, i spent a lot of time pondering.
If you are actually going to do it yourself, masonary or timber frame. That was my conclusion.
Does knocking down and rebuilding make economic sense? Id do it tommorow if i could, but the "non-building costs" and planning issues kill it completely.
Thanks for all your replies so far. You've surprised me about sips but interesting that icf seems a popular choice as that has been recommended from elsewhere. Nestor, that is one beautiful home, you must be really proud.
Nickfromwales- I guess we are all getting older so there will always be a market for a bungalow, in my opinion, but understand your reasoning
G&J- will have a read of your blog
Roger440- I'm sure there are better people to answer the knocking down and starting again reason on here, which is why I've joined this forum
If price is your primary concern. Take a look at this channel doing an ICF Ecobrix build.
https://www.youtube.com/@TurningRosemountUpsideDown
Well the concrete comes in a ready mix truck, and you need to hire a pump to get it up to the top of the wall, but that’s about it.
like saying you can’t put a timberframe up yourself because you haven’t got a crane.
Our new house is a SIPs construction and i am very happy with it. This the only house i have ever had built or will ever build so have nothing to compare it against.
It is warm, draught free, straight square and true to dimensions.
There have been issues, mostly with Potton Homes but i do not regard these as related to the basic construction method.
On the subject of knock down & rebuild, there is a bungalow next door to us that is up for sale @ £500k for 662 square metres. It is non standard construction, single skin walls, tiny and poorly made. The foundations are not up to the job of adding a second floor.
All of the people that i have talked to that have come to view it have said that the only thing to do with it would be to remove it and build new. But, the asking price makes this non viable.
I guess this is likely to be the case with a lot of houses around the country.
Not really. Concrete work on that scale means a team of people and equipment. Thats not what id call DIY, though perfectly acceptable if you want to pay.
DIY concrete has many pitfalls for the unwary, and re-work is rather harder than with timber frame. I can do most things, but id not tackle ICF on a DIY basis.
Indeed there are. Which is why when you suggested it, i took an interest, as, in my expeience its rare that it can fly financially.
Do keep us posted if you go down that route.
Nope.
I poured 27 cubic metres on our first pour with me and one helper.
there was the owner operator of the pump working that, then just two of us using the vibrator and checking it was all plumb.
Icf is very diy friendly
your not pouring a flat house floor that needs to be within 3-5 mm tolerance
your pouring wet concrete inside form work that you have already plumbed up
theres a good few on this forum that have done their own icf including the pours.
7 minutes ago, Russell griffiths said:
Nope.
Good work. Dont think i would try it.
Sorry to be über boring, but how bad is the existing building?
HURRAY!!!!!
Interesting, I would love to stick frame a house. Mainly because I just love hammering bits of timber together. There were large aspects of our masonry house I hated with the dust and the hardship that TF avoids. What other method would you like?!
Good people are always worth paying. Bad people are worth paying to keep them away.
Depends on how fast you are blockwork.  One mason built out house with no labourer.
Icf Always stuck me as the wrong way around.nsoft on the outside and hard on the inside. Like a Dime bar when what you really need is an Armadillo.
TF or masonry I think are the best.
Can I just have some money for the heck of it?
  • 5 weeks later...
@dustyb My partner and I were in exactly the same situation. We are the ones from the channel mentioned above.
We’ve given ourselves a realistic time scale to help both budget and build quality. We are using Ecobrix which is a Woodcrete ICF.
It works out at around £11 a block… I think. Which sounds pricey but I feel the block has many advantages to the self builder. Our structural steelwork thats made of rebar and concealed in the block can all be constructed ourselves and has the ability to create many aspects, one of which in our case is a 1 meter cantilever.
All the rebar for our build only came to £700, and there’s some nice thick long stuff in there. It’s much cheaper than your typical I beam steel work.
Your drives on why to build it yourself are similar to ours, we know there’s a lot we can have a crack at and do well ourselves to save paying someone else though…. We know our limitations and getting a company in to build and pour our slab was money well spent.
I do not agree with the comment regarding an ICF pour requiring lots of labour (it may do for an EPS ICF) but our Woodcrete ones from Ecobrix performed brilliantly, though we did go full belts and braces on the shoring up but that’s easily done by screwing OSB directly to the blocks.
We had more people than needed in the end (just incase it went Pete Tong). Our build is only small, the first pour was 9.5m3 and would have been done in a morning if the concrete wagons arrived when they said they would. The pour came to just shy of £3000.
We have only done one pour so far, fingers crossed we weren’t just lucky!😅
We are also not planning on doing this again or moving… unless we are 90 and in a box.🤞🏼
  • Like 4
