readiescards Posted January 21, 2018 Posted January 21, 2018 Following on from: I've been looking at the Nice 24V gate openers. Just wondering from these spec which says 7A at 24V is worse case - what size cables should I use for a 25 m in duct cable run? Many thanks Paul
PeterW Posted January 21, 2018 Posted January 21, 2018 Where is the control box going ..?? Normally you need to put the box with the gates as not only do you have to run the motors you will need sensor wires etc for the beams, key fobs etc. To answer the wire question though - 4mm2 would be a 2% voltage drop for 7A at 25m
readiescards Posted January 21, 2018 Author Posted January 21, 2018 I had assumed the entire system was 24V - but will investigate
PeterW Posted January 21, 2018 Posted January 21, 2018 So there will be a wire per gate as they are normally separate plus at least a wire to a beam sensor, and depending on the unit there may also be a flashing light to show it’s opening or closing. This is all normally in an IP65 box at the gate with just a single power wire. There may then just be a single control wire to an intercom 1
Barney12 Posted January 21, 2018 Posted January 21, 2018 I might be wrong but that looks like the spec for the gate motors not the control panel psu. As Peter has said the control panel would normally be located close to the gates to allow the various sensor circuits, gate motors and indicators to be connected to the panel. The control panels I researched were all 240v with a transformer to step the motor voltages down to 24v. Remember to add add provision for communication from the house to the gate. I.e. voice and/or video access. Normally CAT5/6 is sufficient. 1
PeterW Posted January 21, 2018 Posted January 21, 2018 As @Barney12 says that’s the gate box spec. We have these - the grey box is the control box. Everything from it is in 20mm flexi conduit. http://www.gatemotors.co.uk/page-166-49-13 1
Onoff Posted January 21, 2018 Posted January 21, 2018 This I think is the opener manual: idv0532a01en.pdf Says on page 3 of the above that the MC824H control panel is compatible with the 36W LFAB4024 and the XLFAB5024 50W. And here's the manual for that: D00011568.pdf The control panel still needs 230V AC to it even though the motors are 24V DC I think you'll find. All the cable sizes / run lengths are in the manual on page 2 of the second manual. 1
ProDave Posted January 21, 2018 Posted January 21, 2018 You really don't want to be running 24V that length. If you do it's no use applying the voltage drop calculations for 240V. A 10V drop may be allowable for 240V but would be catastrophic for a 24V system, so you would end up with a monster sized cable. Stick to 240V and put the control box close to the gates. 1
Onoff Posted January 21, 2018 Posted January 21, 2018 @readiescards, you're not thinking 24V DC for a system with solar charged batteries are you? 1
readiescards Posted January 21, 2018 Author Posted January 21, 2018 Darn was hoping could use 24v from the house to save digging up my duct to repair it for 240v. These automatic gates getting tedious, think I might tell my partner she'll have to open/shut them manually instead Thanks all
PeterW Posted January 21, 2018 Posted January 21, 2018 You can use 24v out of the box with a pair of leisure batteries and a solar charger but it’s not as simple ..!
Nickfromwales Posted January 21, 2018 Posted January 21, 2018 25 minutes ago, readiescards said: Darn was hoping could use 24v from the house to save digging up my duct to repair it for 240v. These automatic gates getting tedious, think I might tell my partner she'll have to open/shut them manually instead Thanks all Why do you need to dig it up ? Isn't it cheaper and easier to pull a HO5 or HO7 cable through and leave it submerged? Just a 2.5mm2 3.core flex then with an cat6 for comms / accessory switching.
Onoff Posted January 22, 2018 Posted January 22, 2018 Imho any underground duct might be subject to condensation internally, more so if the cables run a bit warm. This could conceivably pool at any low point in the duct and affect and cable laying in it. I imagine this is one reason why any cable in a duct should be "duct rated". Paranoia? The regs touch on the issue of condensation, protection against moisture etc. The last bit of duct I ran I even considered running a length of aquarium tube in there so I could periodically pump out whatever, if anything, got in there. I even considered punching some drain holes mid point in the duct, wrapping in landscape fabric and packing gravel around it before concreting. Of course then I worried about the water table etc so in the end did nothing! I just ran everything in 20mm conduit and kept those together with some black dowpipe for neatness when concreting. Just noted that photo was taken in June 2014 @readiescards and it's still not finished! Tell your missus 1
Nickfromwales Posted January 22, 2018 Posted January 22, 2018 Spec APPLICATIONS OVERVIEW Our H07RN-F is a heavy-duty rubber flexible trailing cable for power supply with a voltage rating of 450/750V designed to provide high flexibility and to withstand chemical, mechanical and thermal stresses. It is suitable for applications such as handling equipment, mobile power supplies, worksites, stage and audio visual equipment, port areas and dams. As part of Eland Cables' portfolio of rubber flexible cables, the tough rubber sheath also makes this cable suitable for use in drainage and water treatment, cold or refrigerated environments, and severe industrial environments. And yes, he is paranoid 1
Nickfromwales Posted January 22, 2018 Posted January 22, 2018 @readiescards, you can run that stuff between Dover and Calais without a single worry. Perfect for your wet gate duct imo. 1
