5 hours ago, G and J said:
PIR instead of 120mm each of polystyrene and PIR
You are still comparing overall thickness though (I know you had a (expletive deleted) up are limited on thickness).
What you need to do is pick a U-Value (i.e. 1.2 W/m².K) and compare the prices to achieve that, not compare prices to fill the gap up.
4 hours ago, saveasteading said:
10 year return would be my judgement
Not if you had made that decision in 2015, 6 years before our energy prices doubled.
5 hours ago, JohnMo said:
But you also need to buy the correct grade for appropriate compression strength. Not all are equal.
Now thats a bit of a minefield if ever there was one...............
 Doesnt building control use 15 years as its guide as to insisting on stuff, at least in a retrofit situation?
No idea.
Would be OK for windows and doors, but not very good for slab insulation.
We ended up with 335mm to 345mm to fill to get to FFL which includes screed with UFH.  I am keen on a good thickness screed so wanted circa 100mm.  So for us the insulation thickness was given.
We want the biggest living space we can fit in to our narrow plot so our walls haven’t the most fantastic U values so to an extent the floor and ceiling can sort of compensate a bit, so I targeted 0.1 for the floor.
Going from the architects suggested 0.13 U value to that felt ok, cost wise.  Beyond that felt silly.
11 hours ago, saveasteading said:
coarse cut handsaw and a big bench
I’d strongly agreee, using a piece of wood knelt on as a guide for me really sped it up.
Both polystyrene and PIR made mess, but for me only PIR was unpleasant.
Edited by G and J
Typo
Just use a layer of 50mm PIR on the bottom, with 100mm on the top. Your local merchant will have 1000s of these in stock, at good prices, as that's what the building trade uses. They won't have any /much 75mm PIR or EPS. As a consequence , 50+100mm will work out better value than 2x 75mm. Thin EPS is a nightmare to work with as it just snaps. Foil faced PIR holds together better, can be cut more precisely, despite it being "harder" to cut than EPS. You also can't have steps in your inusaltion, so just allow the screed to take care of those level variations.
(Our floor is 50mm eps, 50mm PIR, 100mm PIR, 50mm screed. 50mm eps at bottom as we changed from 100mm to 50mm screed last minute)
17 hours ago, SteamyTea said:
desired U-Value.
Excellent graph thanks. May I ask it's origin?
That's for an infinite area or based on some HP/A assumption?
Theres a bit of a kink at 100mm ish thickness which seems wierd and that really underlines how worthwhile 100mm is.
Severely diminishing returns after,  I'd say, 200mm PIR.
And no significant benefit after 0.3? ie a complete waste of resources.
I just knocked it up from assumed k-values.
It is a 1D model, so edges, which can have greater losses, would need to be added on.
I think that is caused by the charting software, see below for a different curve algorithm (changed to a B-Spline from a Cubic Hermite Spline).
This is where it gets difficult.  It depends, primarily, on energy prices and installation prices.  UFH would cause greater losses than just heating the air in the building, the building form factor would make a difference as well.
This is why individual buildings need to have heat loss calculations and not have the heating system sized by a rules of thumb i.e. just floor area or number of windows (I have heard a plumber assess the heat loss that way).
Losses though the slab are uneven as they can be affected by the room temperature above, the ground type below and if there is any ground water movement nearby.
So probably safer to pop a bit extra in, rather than too little.
Allow me, (in my post New Year’s Eve socialising, sleep deprived, just driven 3.5 hours and me adrenaline left the building about 5 miles short of home state), to translate into buildspeak.
”Dunno.  Hard innit.  Better put enough in to stop anyone moaning, which means too much.  But sod it, it’s cheap enough.”
That gets me to @Pocsterland, or about a third of my bi-monthly trips up country.  I find filling my mind with thermodynamics problems passes the time.
I must be bored.
Here is a chart showing price comparison between insulation types.  I have only got the prices from 1 site, and have used median k-Values.  To get better results, do your own research.
There is little difference between XPS and Phenolic at the 0.1 W.m-2.K-1 level, about £10.m-2.
There is a 0.1m thickness difference though, which may or may not be important depending on how you excavate and dispose of the dirt.
(as usual, there may be errors as I am tired)
On 31/12/2025 at 14:30, JohnMo said:
You can also get specialised insulation saws.
Something else I didn't know.
Seems to be a saw tooth but with a wavy profile to avoid sticking, and produces less dust. Between a saw and a knife.  £22
The Bahco insulation saw has been specially developed for cutting various types of insulation material
I'm aware of that but reminders are no bad thing.
I wonder how well a soft packaging eps would fare beneath 100mm or more of PIR and a grand piano on top. perhaps with a big enough dish under each wheel it would be ok.  This is whimsical: I am not saving amazon packaging to try it.
Ive found this very difficult to use on the thicker boards. PIR at least. Works great at 50mm. Useless at 100mm. Better off with a cheap normal saw.
Where is this cheap PIR you speak of?
