SteamyTea Posted 5 hours ago Posted 5 hours ago 5 hours ago, G and J said: PIR instead of 120mm each of polystyrene and PIR You are still comparing overall thickness though (I know you had a (expletive deleted) up are limited on thickness). What you need to do is pick a U-Value (i.e. 1.2 W/m².K) and compare the prices to achieve that, not compare prices to fill the gap up. 4 hours ago, saveasteading said: 10 year return would be my judgement Not if you had made that decision in 2015, 6 years before our energy prices doubled.
Roger440 Posted 3 hours ago Posted 3 hours ago 5 hours ago, JohnMo said: But you also need to buy the correct grade for appropriate compression strength. Not all are equal. Now thats a bit of a minefield if ever there was one...............
Roger440 Posted 3 hours ago Posted 3 hours ago 2 hours ago, SteamyTea said: Not if you had made that decision in 2015, 6 years before our energy prices doubled. Doesnt building control use 15 years as its guide as to insisting on stuff, at least in a retrofit situation?
SteamyTea Posted 3 hours ago Posted 3 hours ago 1 minute ago, Roger440 said: Doesnt building control use 15 years as its guide as to insisting on stuff, at least in a retrofit situation? No idea. Would be OK for windows and doors, but not very good for slab insulation.
SteamyTea Posted 2 hours ago Posted 2 hours ago Use this simple cut out guide to work out your ideal insulation thickness for your desired U-Value.
