Dunc Posted 21 hours ago Posted 21 hours ago (edited) Hopefully a quick one: When installing the PIR floor insulation a 50mm perimeter upstand is specified. In one of the architects diagrams the upstand stops level with the screed and the final floor covering oversails this to butt up aginst the wall. In another diagram the perimeter upstand extends high enough for the floor covering to be separated from the outisde wall. As this is a larsen truss frame, the inner sole plate is effectively insulated from the outside as it doesn't span the full width of the wall. The blockwork underneath the sole plate has a course of Marmox blocks below the top block and this will overlap with the 220mm PIR, so the top block is thermally broken from the ground....so I *think* it's OK to oversail the upstand? Top to bottom: Tiles 50mm screed with UFH. Top of screed is level with the bottom of the sole plate slip membrane 220mm PIR 150mm reinforced slab. Edited 21 hours ago by Dunc adding diagrams
Oz07 Posted 21 hours ago Posted 21 hours ago You may as well go with bottom drawing. No need for floor finish to go any further than the line of your finished wall and looks like your wall is in from the timber frame? 1 1
JohnMo Posted 20 hours ago Posted 20 hours ago Took my insulation at the wall edge out as far as the inside edge of the skirting. So bottom image but wider. I would do 200mm PIR and increase screed depth. 1
Gus Potter Posted 19 hours ago Posted 19 hours ago 1 hour ago, Oz07 said: You may as well go with bottom drawing. No need for floor finish to go any further than the line of your finished wall and looks like your wall is in from the timber frame? Plus 1 to that. Once you take into account the build sequence then agree second option is more practicable. I know you have just asked about the inside but can you just check the weathering detail on the outside? This is a critical detail for longevity. Ask your Architect if they know whether the Larsen truss has been designed so both the inside and outside flanges require structural support. @Dunc Does your cladding require ventilation behind, always worth checking the fire protection detail around doors , windows and at the wall head if this is the case. 1
Dunc Posted 8 hours ago Author Posted 8 hours ago @Gus Potter thanks for looking at the other details. The load transfer is on the inner leaf, aparantly. Vertical timber cladding has 20mm vertical battens then 42mm horizontal so there should be plenty ventilation.
Bonner Posted 7 hours ago Posted 7 hours ago 13 hours ago, JohnMo said: I would do 200mm PIR and increase screed depth Agree, 50mm screed is absolute minimum and leaves no margin for variations
torre Posted 4 hours ago Posted 4 hours ago 2 hours ago, Bonner said: 50mm screed is absolute minimum If this is a liquid screed then 50mm is fine, some are even 40mm
JohnMo Posted 3 hours ago Posted 3 hours ago 40 minutes ago, torre said: If this is a liquid screed then 50mm is fine, some are even 40mm The reason I said in the first place was, that the flexibility comes from having a big energy store, then you can play tunes with how you heat your house. Pure weather compensation is fine with thin and thicker screeds, batch charge can only be done with thicker screeds. Batch charging can be useful with time of use tariffs. A few on here only heat on cheap rate periods. 40mm is more like a big radiator.
Dunc Posted 3 hours ago Author Posted 3 hours ago I'm well aware of the arguments around thin and thick screeds. There are many excellent discussions on this forum covering the subject. We're going at 50mm (architect was pushing for 40mm!). The PIR is already on site and the first layer (120mm) installed so rightly or wrongly, we're fully committed. I would, in retrospect, have preferred 70mm to allow better tolerance of the uneven slab but we are where we are and I'm sure it'll work out. Everyones thoughts and recommendations have been much appreciated as always!
saveasteading Posted 3 hours ago Posted 3 hours ago 5 minutes ago, Dunc said: 70mm to allow better tolerance of the uneven slab How uneven? 40mm screed should be the minimum and some slab layers are hopeless at levels..
