-rick- Posted Monday at 18:09 Posted Monday at 18:09 2 hours ago, Gone West said: Another update. Since installing Starlink we have an intermittent problem with WiFi calling. We are out in the sticks with no mobile signal and rely on using broadband for phone calls. I have searched t'internet and it seems to be a known problem to do with IP addresses but without a definite solution. Has anyone else here experienced similar problems or even better, found a solution? Just to eliminate the obvious when you've encountered this issue have you rebooted both the router and your phone/device? 1
Gone West Posted Monday at 19:45 Posted Monday at 19:45 2 hours ago, SteamyTea said: Have you tried changing your DNS service. Can do it either on the devices (WARP) or in the actual router. So I just changed the phone DNS from automatic to off. The calling and text services now appear to be working. Do you know if there are any security issues with the changes I have made?
Gone West Posted Monday at 19:46 Posted Monday at 19:46 1 hour ago, -rick- said: Just to eliminate the obvious when you've encountered this issue have you rebooted both the router and your phone/device? Yes I have tried that without any success. 1
SteamyTea Posted Monday at 19:49 Posted Monday at 19:49 2 minutes ago, Gone West said: So I just changed the phone DNS from automatic to off. The calling and text services now appear to be working. Do you know if there are any security issues with the changes I have made? Not sure about security when it is off. I use CloudFlare as they only keep limited data for 24 hours. There are a number of free, and paid for, services. https://www.lifewire.com/free-and-public-dns-servers-2626062 1
BotusBuild Posted Tuesday at 08:08 Posted Tuesday at 08:08 DNS stands for Domain Name Service and is the things that changes website names to IP addresses (simple explanation). There is such a thing as DNS spoofing, which intercepts call to DNS and provides a "bad" IP address. So, yes correct DNS setup is crucial to a secure network.
Gone West Posted Tuesday at 08:19 Posted Tuesday at 08:19 4 minutes ago, BotusBuild said: So, yes correct DNS setup is crucial to a secure network. So on my phone I have turned off auto DNS and in doing so my WiFi calling now works but I have removed a level of security. If I do as @SteamyTea has and use a private DNS such as CloudFlare then the security is improved but will my WiFi calling still work? I guess I can try it and see!!
BotusBuild Posted Tuesday at 08:29 Posted Tuesday at 08:29 9 minutes ago, Gone West said: will my WiFi calling still work? I don't know. Never had to try it
SteamyTea Posted Tuesday at 08:49 Posted Tuesday at 08:49 29 minutes ago, Gone West said: guess I can try it and see Will take about 5 minutes to set it up with CloudFire, just download the apps and away you go.
saveasteading Posted Tuesday at 08:56 Posted Tuesday at 08:56 We've had it fitted as part of the deal. Very fast when nearby. Very slow to nil at 30m away in the site caravan. As the project is all metal clad, we will have to provide boosters. The fitter asked why starlink when there was an O2 mast within sight. Well, because O2 don't say that reception is any good in the area and because they are right... it's very poor.
Gone West Posted Tuesday at 09:04 Posted Tuesday at 09:04 12 minutes ago, SteamyTea said: Will take about 5 minutes to set it up with CloudFire, just download the apps and away you go. I've set up CloudFlare and everything appears to be working as it should. Many thanks for the suggestion.
SteamyTea Posted Tuesday at 10:08 Posted Tuesday at 10:08 58 minutes ago, Gone West said: Many thanks for the suggestion. Your welcome. Seems i did not waste my time being an IT lecturer. You may find that your connection is a little slower, but probably not noticeably so. Does anyone know how much data Starlink collects, stores, analyses and then sells on? It is only recently that I have started to think more about the data retention by the big boys, even though I have always been sensible about my internet usage.
-rick- Posted Tuesday at 11:18 Posted Tuesday at 11:18 1 hour ago, SteamyTea said: Your welcome. Seems i did not waste my time being an IT lecturer. You may find that your connection is a little slower, but probably not noticeably so. Does anyone know how much data Starlink collects, stores, analyses and then sells on? It is only recently that I have started to think more about the data retention by the big boys, even though I have always been sensible about my internet usage. Have to say that DNS being the cause of this surprised me a bit, despite 'it's always DNS' being a thing that people put on t-shirts. Was expecting it to be more NAT/firewall stuff. In any case, i expect cloudflare will be faster than almost anything else. Because a huge chunk of webtraffic flow through them anyway, using their DNS can often speed things up vs slow it down. 9.9.9.9 is another service thats worth looking at (Google Quad9) Both cloudflare and Quad9 offer filtered 'safe' versions (using different addresses) that might be preferable to use if you have kids.
SteamyTea Posted Tuesday at 11:49 Posted Tuesday at 11:49 29 minutes ago, -rick- said: Both cloudflare and Quad9 offer filtered 'safe' versions (using different addresses) that might be preferable to use if you have kids. I think @Gone West's kids can sort that. What kids are for. I once defaulted my browser (Brave), stopped me looking at just about everything.
Gone West Posted Tuesday at 11:57 Posted Tuesday at 11:57 6 minutes ago, SteamyTea said: I think @Gone West's kids can sort that. Grandkids these days, I wouldn't be suprised if it isn't Great Grandkids in the next year or two.
SteamyTea Posted Tuesday at 11:59 Posted Tuesday at 11:59 Just now, Gone West said: Great Grandkids Good, need more arms to pay our pensions. They the (expletive deleted)ers down the fishmines.
Gone West Posted Tuesday at 12:00 Posted Tuesday at 12:00 3 hours ago, saveasteading said: we will have to provide boosters I've bought an outdoor unit to add to my mesh network, as the signal is weak in the garden. Wendy likes to listen to BBC Sounds stories while gardening.
SteamyTea Posted Tuesday at 12:28 Posted Tuesday at 12:28 27 minutes ago, Gone West said: Wendy likes to listen to BBC Sounds stories while gardening. Half hour till The Archers.
Gone West Posted Tuesday at 15:11 Posted Tuesday at 15:11 2 hours ago, SteamyTea said: Half hour till The Archers. Or, I'm told, the omnibus on Sunday is good.
SteamyTea Posted Tuesday at 15:27 Posted Tuesday at 15:27 14 minutes ago, Gone West said: Or, I'm told, the omnibus on Sunday is good. You have been lied to. 1
saveasteading Posted Wednesday at 08:45 Posted Wednesday at 08:45 22 hours ago, SteamyTea said: how much data Starlink collects, stores, analyses and then sells on? Everything I'd guess. I'm getting very prompt adverts for things we are discussing but absolutely not mentioning in messages or searches. So that's the phone listening? I bought a watch and there were ads for watches the same day and since. Pointless as I now have a watch. Wood burning stoves discussed... ads appear. And other such.
Onoff Posted Wednesday at 17:35 Posted Wednesday at 17:35 On 12/05/2026 at 13:00, Gone West said: I've bought an outdoor unit to add to my mesh network, as the signal is weak in the garden. Wendy likes to listen to BBC Sounds stories while gardening. Would you have a link to the outdoor unit?
Gone West Posted Wednesday at 18:00 Posted Wednesday at 18:00 17 minutes ago, Onoff said: Would you have a link to the outdoor unit? I have TP Link Deco M4 units in the house and I've bought a Deco X50 outdoor unit for the garden. 1
Gone West Posted 2 hours ago Posted 2 hours ago (edited) I've just had notification from Starlink that my monthly payments are increasing to $40 (~£30) from next month. I thought when I signed up that I was getting the first six months at £25, and then onwards, £35 a month. There is no record of that agreement as it was on the order form that I filled in. So now I have actually paid £23 a month for the first three months and I will then be paying ~£30 a month. I hope it doesn't keep creeping up. Just a warning to others to keep a record of any agreements. It is a rolling monthly agreement so I can cancel at any time. Edited 2 hours ago by Gone West
Onoff Posted 1 hour ago Posted 1 hour ago 40 minutes ago, Gone West said: I've just had notification from Starlink that my monthly payments are increasing to $40 (~£30) from next month. I thought when I signed up that I was getting the first six months at £25, and then onwards, £35 a month. There is no record of that agreement as it was on the order form that I filled in. So now I have actually paid £23 a month for the first three months and I will then be paying ~£30 a month. I hope it doesn't keep creeping up. Just a warning to others to keep a record of any agreements. It is a rolling monthly agreement so I can cancel at any time. Do you have any email confirmation from sign-up that might reference the £35 ongoing price, even indirectly? Sometimes the promotional rate appears in an order confirmation even if the form itself is gone.
