-rick- Posted 16 hours ago Posted 16 hours ago 2 hours ago, Gone West said: Another update. Since installing Starlink we have an intermittent problem with WiFi calling. We are out in the sticks with no mobile signal and rely on using broadband for phone calls. I have searched t'internet and it seems to be a known problem to do with IP addresses but without a definite solution. Has anyone else here experienced similar problems or even better, found a solution? Just to eliminate the obvious when you've encountered this issue have you rebooted both the router and your phone/device? 1
Gone West Posted 14 hours ago Posted 14 hours ago 2 hours ago, SteamyTea said: Have you tried changing your DNS service. Can do it either on the devices (WARP) or in the actual router. So I just changed the phone DNS from automatic to off. The calling and text services now appear to be working. Do you know if there are any security issues with the changes I have made?
Gone West Posted 14 hours ago Posted 14 hours ago 1 hour ago, -rick- said: Just to eliminate the obvious when you've encountered this issue have you rebooted both the router and your phone/device? Yes I have tried that without any success. 1
SteamyTea Posted 14 hours ago Posted 14 hours ago 2 minutes ago, Gone West said: So I just changed the phone DNS from automatic to off. The calling and text services now appear to be working. Do you know if there are any security issues with the changes I have made? Not sure about security when it is off. I use CloudFlare as they only keep limited data for 24 hours. There are a number of free, and paid for, services. https://www.lifewire.com/free-and-public-dns-servers-2626062 1
BotusBuild Posted 2 hours ago Posted 2 hours ago DNS stands for Domain Name Service and is the things that changes website names to IP addresses (simple explanation). There is such a thing as DNS spoofing, which intercepts call to DNS and provides a "bad" IP address. So, yes correct DNS setup is crucial to a secure network.
Gone West Posted 2 hours ago Posted 2 hours ago 4 minutes ago, BotusBuild said: So, yes correct DNS setup is crucial to a secure network. So on my phone I have turned off auto DNS and in doing so my WiFi calling now works but I have removed a level of security. If I do as @SteamyTea has and use a private DNS such as CloudFlare then the security is improved but will my WiFi calling still work? I guess I can try it and see!!
BotusBuild Posted 2 hours ago Posted 2 hours ago 9 minutes ago, Gone West said: will my WiFi calling still work? I don't know. Never had to try it
SteamyTea Posted 1 hour ago Posted 1 hour ago 29 minutes ago, Gone West said: guess I can try it and see Will take about 5 minutes to set it up with CloudFire, just download the apps and away you go.
saveasteading Posted 1 hour ago Posted 1 hour ago We've had it fitted as part of the deal. Very fast when nearby. Very slow to nil at 30m away in the site caravan. As the project is all metal clad, we will have to provide boosters. The fitter asked why starlink when there was an O2 mast within sight. Well, because O2 don't say that reception is any good in the area and because they are right... it's very poor.
Gone West Posted 1 hour ago Posted 1 hour ago 12 minutes ago, SteamyTea said: Will take about 5 minutes to set it up with CloudFire, just download the apps and away you go. I've set up CloudFlare and everything appears to be working as it should. Many thanks for the suggestion.
SteamyTea Posted 23 minutes ago Posted 23 minutes ago 58 minutes ago, Gone West said: Many thanks for the suggestion. Your welcome. Seems i did not waste my time being an IT lecturer. You may find that your connection is a little slower, but probably not noticeably so. Does anyone know how much data Starlink collects, stores, analyses and then sells on? It is only recently that I have started to think more about the data retention by the big boys, even though I have always been sensible about my internet usage.
