Kelvin Posted 13 hours ago Posted 13 hours ago Our open plan living room, dining room, and kitchen is almost identical to your plan in layout and size. What we did is made the island quite big at 1.2m deep by 3m long and fitted it with deep drawers so there are no cupboards at all in it. We also put the dishwasher, sink and hob on it. I think many would say not to do this but it actually works really well. That then allowed us to remove the cupboards/sink at the end and we made a feature of that wall (where your window is) and we moved the island up a bit. This gave us more space and took £7k of cost out of the kitchen. We had the same concern as you about seeing the back of the sofa. The sofa we moved in with was a huge L shaped thing that dominated the living area a bit. However we sold that in the summer and replaced it with a new sofa I think what they call a matching snuggle chair. They are on legs so takes away some of that back of the sofa look. We tried a console table behind the sofa but it becomes very easy to make a big space look crammed in. I also used some planning software to 3D render the room as I found it really hard to visualise such a big open space. That really helped. 1
-rick- Posted 12 hours ago Posted 12 hours ago 41 minutes ago, Gballam said: The dining table isn’t drawn in the right place - it will be moved towards the kitchen slightly and therefore there will be a bit of circulation space on entering the main room. We will have a behind the sofa sideboard to create a bit of room divide/conceal the back of the sofa And that is the sort of layout I was thinking about. 16 minutes ago, Kelvin said: We had the same concern as you about seeing the back of the sofa. The sofa we moved in with was a huge L shaped thing that dominated the living area a bit. However we sold that in the summer and replaced it with a new sofa I think what they call a matching snuggle chair. They are on legs so takes away some of that back of the sofa look. I've seen designers recommend this approach and it does look nice. In this case maybe a couple of chairs replacing the sofa backing the dining table. But some sort of room divider appeals more to me. 16 minutes ago, Kelvin said: We tried a console table behind the sofa but it becomes very easy to make a big space look crammed in. Do you have any before/after photos? If you don't mind sharing. 1
Kelvin Posted 12 hours ago Posted 12 hours ago (edited) I do with the two different sofa’s but not with console table. I’ll post up when I’m back home. The other advantage with them being on legs is the robot hoover fits underneath to clean the dog hair. Before that all got trapped underneath it. Edited 12 hours ago by Kelvin 1 1
Gballam Posted 12 hours ago Author Posted 12 hours ago @Kelvin Many thanks for your helpful input. I’d be really interested to see the pics - and of your kitchen if you don’t mind sharing. Even with online 3D models, it’s hard to fully imagine the space
Bramco Posted 11 hours ago Posted 11 hours ago 1 hour ago, Kelvin said: Our open plan living room, dining room, and kitchen is almost identical to your plan in layout and size. What we did is made the island quite big at 1.2m deep by 3m long and fitted it with deep drawers so there are no cupboards at all in it. We also put the dishwasher, sink and hob on it. I think many would say not to do this but it actually works really well. We have a very similar layout - but the island is only 950 wide by just under 3m which gives room at the back of the cupboards to put the bar stools under. There's also an overhang at one end for a couple of stools. So a row of 2x600 units with drawers, then an 800 unit with the downdraft induction hob and one 400 at the end. Personally I'd keep the dishwasher with the sink on the end wall. We have 2x600 full height units, one with two ovens, then 4 600 base units with top units and then a full height with the fridge freezer. Can't remember the full cost but I DIY'ed it and all the units and appliances came from IKEA except for the hot water tap. Don't think it cost us anywhere near £7k all in. 59 minutes ago, Kelvin said: The other advantage with them being on legs is the robot hoover fits underneath t +1 for that. Make to sure measure any sofas to make sure you can extend to a robot vacuum. I could send photos of ours if you are interested.
Kelvin Posted 11 hours ago Posted 11 hours ago We have found open plan living has taken a while to adjust to. Neither of us are particularly tidy although I’m tidier than my other half who has a tendency to use every flat surface as a shelf. 1
-rick- Posted 9 hours ago Posted 9 hours ago 2 hours ago, Kelvin said: Nice. Those sofas are a definite improvement and nice idea with the recliner/window combo. That large fixed window with side door is an arrangement I'm thinking about. How do you find it? Seems like it could have been mirrored at the kitchen end but see you went for a slider + french doors. What were your reasons behind that?
Kelvin Posted 8 hours ago Posted 8 hours ago 1 minute ago, -rick- said: Nice. Those sofas are a definite improvement and nice idea with the recliner/window combo. That large fixed window with side door is an arrangement I'm thinking about. How do you find it? Seems like it could have been mirrored at the kitchen end but see you went for a slider + french doors. What were your reasons behind that? They are tilt and turn windows. We never use them as doors. We have them in all the downstairs rooms as they are a means of escape in case of fire. That particular one is great for getting the heat out as we have a Velux above the stairs and the heat is quite quickly funnelled out. Long story short. The slider should have been longer but we wanted it 3G and because it’s so big it’s also laminated. Consequently it’s heavy. The timber kit company also supplied and fitted the windows but refused to take responsibility for installing that window due to the weight (they had apparently a few examples of significant problems with them in other builds) . We finally agreed on a size they would fit and that we were happy with. Unfortunately it meant that the tilt and turn window that should have been there was going to be over 1m wide. As it’s inward opening it meant moving the island back into the room a bit to stop the window fouling the island or hinged the other side block the stairs if it was open. Also because it’s not technically a door the threshold isn’t flush so you’d be stepping over the frame or in reality tripping over it. Hence fitting the double outward opening French doors. We use that door all the time so the tilt and turn wouldn’t have worked. 1
Gballam Posted 7 hours ago Author Posted 7 hours ago Thanks so much for sharing those pictures, so helpful to see. Agree - sofas are much better as they are now
