Lincolnshire Ian Posted September 22, 2025 Posted September 22, 2025 Hi folks We need intumescent strips to close the 50mm void in our timber frame where we use cladding (about 30% of the house). I am more than a little shocked by the difference in price between cavity socks for the masonry walls and intumescent strips for the cladded walls. Does anyone have a supplier that offers intumescent strips at a reasonable price? Thanks
nwnw Posted September 22, 2025 Posted September 22, 2025 I was reading posts on this recently and it seems that Envirograf is generally cheaper than Tenmat. However, I did see that folks were getting away without using intumescent strips if they had an open 'rain screen' cladding format, which is what I'm looking at. Will need a chat with BCO.
Mr Punter Posted September 22, 2025 Posted September 22, 2025 43 minutes ago, nwnw said: I was reading posts on this recently and it seems that Envirograf is generally cheaper than Tenmat. However, I did see that folks were getting away without using intumescent strips if they had an open 'rain screen' cladding format, which is what I'm looking at. Will need a chat with BCO. Yes I think the chimney effect is much reduced if there are gaps between the boards.
Kelvin Posted September 22, 2025 Posted September 22, 2025 I might have some I could sell you at a fair price. Let me know exactly what you need and I’ll have a look at what I have.
saveasteading Posted September 22, 2025 Posted September 22, 2025 4 hours ago, nwnw said: Will need a chat with BCO. Firstly Envirograf. My favourite in this field as they understand fire and the products, many of which they first produced. I haven't contacted them for years but always found their advice interested, realistic and worthwhile. The BCO unfortunately probably will want to see a test certificate for exactly the situation. The purpose of the strip is to stop the spread of flame, and a lump of wood or metal would do it fine. But nobody has tested that as there is no market. A product exists so you probably have to use it. If the manufacturer made the exact same product but wrapped in red , and tested with timber, or wrapped in blue and tested in metal cladding, then those would be the test certificate that existed, and you have to use the red or the blue. How about intumescent paint on a timber block or metal profile? A pragmatic and knowledgeable BCO might agree to it: after all it has the magic word intumescent. I'm not guessing btw. I've worked on this a lot, including a high level course, but there were no qualifications awarded. 3 hours ago, Mr Punter said: the chimney effect is much reduced if there are gaps between the boards. Yes, but the effect of heat rising is still there. A fire spreads very rapidly upwards, chimney effect or not, as the material above is preheated, and then a flash flame can occur. 1
Lincolnshire Ian Posted September 22, 2025 Author Posted September 22, 2025 8 hours ago, Mr Punter said: Yes I think the chimney effect is much reduced if there are gaps between the boards. Our architect gave us the option of having vents added to the cladding or intumescent strips. We thought the vents looked pretty poor, but there might be more elegant solutions.
Lincolnshire Ian Posted September 22, 2025 Author Posted September 22, 2025 6 hours ago, Kelvin said: I might have some I could sell you at a fair price. Let me know exactly what you need and I’ll have a look at what I have. Ohh, that's a good idea. I need 32m to expand to fill a 50mm cavity. Thanks
saveasteading Posted September 22, 2025 Posted September 22, 2025 35 minutes ago, Lincolnshire Ian said: Our architect gave us the option of having vents added to the cladding or intumescent strips I hadn't seen this vent theory as being accepted practice. Do you have any backup to it as I'd love to know more? The main thing is never to build a bonfire against a timber-clad house. 1
Kelvin Posted September 22, 2025 Posted September 22, 2025 56 minutes ago, Lincolnshire Ian said: Ohh, that's a good idea. I need 32m to expand to fill a 50mm cavity. Thanks I’ll message you separately when I get home tomorrow and let you know exactly what I have.
Gus Potter Posted September 22, 2025 Posted September 22, 2025 10 hours ago, nwnw said: However, I did see that folks were getting away without using intumescent strips if they had an open 'rain screen' cladding format, which is what I'm looking at. And here is the crunch. I made what was a admittedly a rambling post a few days ago about principle designers in response to a thread by @Oceanjules. One point here is that it's not what you can get away with.. much more about designing safely and the onus is now much more on the designer and everyone involved in that process, the liability has now much been past to the designer. There are two key principles. 1/ If a fire starts the occupants need to have time to exit safely. 2/ That the fire fighters should not be put at risk. But here is the business case. The onus is very much more on the designer. One thing my PI insurer broker pointed out to me when we were talking the extent of my fire design liability is, hey Gus.. from the underwriters perspective.. a fire does not need to occur, all it needs is for a Client to potentially later say.. your design could be flawed and it's up to you to prove it's not! This liability does not lie with BC anymore but with the designer, although to support our case we may refer to BC regs and manufacture's data. But as soon as we go off piste life becomes a design and cost adventure!
Dunc Posted September 23, 2025 Posted September 23, 2025 Just installing ours right now. Envirograf CV strip significantly less expensive than the Tenmat offering. Got ours from www.lifelinefireprevention.com Probably worth checking with BCO exactly what they would want to see; the regs are pretty general and your individual building may not need "everything".
Kelvin Posted September 23, 2025 Posted September 23, 2025 (edited) 22 hours ago, Kelvin said: I’ll message you separately when I get home tomorrow and let you know exactly what I have. @Lincolnshire Ian I’m still away. Back tonight so will let you know tomorrow. Edited September 23, 2025 by Kelvin
marmic Posted September 25, 2025 Posted September 25, 2025 Jit Sehra Senior Technical Fire Consultant Intumescent Systems Ltd T/A Envirograf p: m: 01304 842 555 07831451628 e: Jit.Sehra@envirograf.com a: Intumescent Systems Ltd, Envirograf House, Barfrestone, Dover, Kent, CT15 7JG, United Kingdom w: www.envirograf.com
marmic Posted September 25, 2025 Posted September 25, 2025 Jit was extremely helpful........... cost lower than other products i found. significanty in some cases
Lincolnshire Ian Posted September 28, 2025 Author Posted September 28, 2025 Thank you everyone - very helpful. I will call Envirograf to get the info we need.
Lincolnshire Ian Posted September 30, 2025 Author Posted September 30, 2025 I spoke to the guys from Envirograf and it was a stress-free process for a novice. I explained my scenario, they asked a few questions, made some suggestions and followed up with an email - all within the space of a couple of hours. 1
Alan Ambrose Posted April 20 Posted April 20 I've been looking at this issue and talking to my BC guy. His opinion is: Fire stopping cavity barriers are not enforceable under building regulations for individual domestic dwellings. Only enforceable in buildings with separate compartment ie flats or semi’s. Although I do think the fire stopping strip is a good idea it is your choice in this circumstance. I suggested this stainless metal strip (we already have 25mm ply around the window apertures), which would work well for us: https://www.roofingsuperstore.co.uk/product/terne-coated-stainless-steel-fixing-strip-50mm-x-20m-roll.html And his response was: I think metal is a good option although not seen it used, timber or fire socks (fibreglass) are nearly always used.
marmic Posted April 20 Posted April 20 don't forget drainage and ventilation. you don't want water sitting on top of window/door reveals. I'd be inclined to double check regs, particularly if cavity behind cladding open to roof cavity
marmic Posted April 20 Posted April 20 ps meant to add our bc insisted. (socks etc from memory only for masonry cavities - also for acoustic barrier between dwellings. and needs tray over)
