Arrenite Posted September 20, 2025 Posted September 20, 2025 I have a problem with groundwater ingress into an inspection chamber that links to a septic tank, obviously a problem. The site is pretty saturated and flat, and water I think is coming in through the extension turret on the chamber, which extends down one metre.There is a high water table when it rains a lot. Does anyone know how to fix this problem - the septic tank is not viable with load of ground water going into it. many thanks Simon
Gone West Posted September 20, 2025 Posted September 20, 2025 15 minutes ago, Arrenite said: I have a problem with groundwater ingress into an inspection chamber that links to a septic tank, obviously a problem. The site is pretty saturated and flat, and water I think is coming in through the extension turret on the chamber, which extends down one metre.There is a high water table when it rains a lot. Does anyone know how to fix this problem - the septic tank is not viable with load of ground water going into it. We had a similar problem with the high water table forcing water past the pipe seals into our treatment plant. I dug around the seals, when the water table was lower, and packed in around 200mm of bentonite granules. It seemed to seal very well. 2
ProDave Posted September 20, 2025 Posted September 20, 2025 gI presume you have a number of risers stacked? did you forget the bit O ring that should seal them? I am still surprised the amount of water ingress is enough to trouble a TP.
Arrenite Posted September 20, 2025 Author Posted September 20, 2025 Yes the seals went in ok. But will check to see if they are damaged when I try to rectify.
ProDave Posted September 20, 2025 Posted September 20, 2025 Just now, Arrenite said: Not sure what a TP is @ProDave Treatment Plant but equally just how much ground water is leaking in to bother a septic tank?
saveasteading Posted September 20, 2025 Posted September 20, 2025 Plastic rings are supposedly formers for a concrete surround but that is seldom done on private projects. The seals may have distorted during backfilling. Is it a big job to expose and reset the chamber, and concrete it in? Wrapping it in a bentonite or similar membrane would be belt and braces and worth considering. If the volume leaking in is signigicant then it is, indeed, an issue as the contents will flush through too quickly and mucky stuff go to the soakaway/ drainage field.
Arrenite Posted September 20, 2025 Author Posted September 20, 2025 My builder is suggesting concreting in the inspection chambers to prevent water ingress. Does that sound reasonable? Thanks for your suggestions so far.
BadgerBodger Posted September 20, 2025 Posted September 20, 2025 Typically minimum 200mm concrete, wet cast with jacket. Or mass fill the hole. Well pokered. I suppose on a smaller ring you could use something like peckafil or even heavy duty correx. Should be effective enough. If it were a concrete ring with torching that were leaking this would reduce it to damp patches in most scenarios.
saveasteading Posted September 20, 2025 Posted September 20, 2025 5 hours ago, Arrenite said: concreting in the inspection chambers Yes i do agree, thats what i was saying, maybe worded unclearly.
crooksey Posted September 22, 2025 Posted September 22, 2025 Just get a drainage company to seal the pipes from the inside with a patch liner.
Arrenite Posted October 3, 2025 Author Posted October 3, 2025 Are there makes of inspection chambers that are one piece r and designed for high water tables?
saveasteading Posted October 4, 2025 Posted October 4, 2025 No. I suggest you visit a builders merchant, see what they have, and ask for the manufacturers installation details. That will refer you back to previous advice. On 22/09/2025 at 07:39, crooksey said: drainage company to seal the pipes from the inside with a patch liner. Explain please?
crispy_wafer Posted October 4, 2025 Posted October 4, 2025 https://www.drainagesuperstore.co.uk/product/accesso-ic110-450mm-single-piece-adoptable-inspection-chamber-1500mm-invert.html?ppc_keyword=&gad_source=1&gad_campaignid=22291034282&gclid=CjwKCAjwi4PHBhA-EiwAnjTHuYGbRQ2uc_O_SIFjCE4ec5OjeIdvk3QPTyu2zdoLGYQ9ZLhafKKjghoCK5gQAvD_BwE 1
Arrenite Posted October 19, 2025 Author Posted October 19, 2025 Hi folks. On inspection the seals from the risers in 3 inspection chambers were found to be missing, hence the water ingress. The seals were inserted and glued into position. We then poured about 30cm of concrete around the entire inspection chamber. Problem no solved, no water ingress. Thank you for your help. 1
