Crofter Posted 5 hours ago Posted 5 hours ago Looking to do a low budget build, some years in the future, and I was wondering about picking up some good quality windows on Gumtree etc. There seems to be quite a lot of stuff around, I don't know if it's from renovations, or wrong sizes being ordered etc. Question is, would I need some sort of certification to satisfy BCO about u values etc? If so, what would they be looking for, and would it be stamped on the frame or would I be needing documentation? 1
JohnMo Posted 4 hours ago Posted 4 hours ago 35 minutes ago, Crofter said: BCO about u values Not sure BCO will give a monkeys. If the SAP report says you pass go, you are good to go. It's what the SAP assessor wants really. Mine wanted manufacturers calculations for U value for the whole window. 2
torre Posted 3 hours ago Posted 3 hours ago Probably depends on the inspector. One thing they may well check (and you do want to get right!) is whether safety glazing is used where it's required. That should be marked on the glass.
ADLIan Posted 3 hours ago Posted 3 hours ago SAP assessor and BCO will want documentary evidence of window performance including Uw value & G value (and, as above, safety glass where needed for BCO)
craig Posted 3 hours ago Posted 3 hours ago If not a available, they do tend to accept therm calculations.
Gus Potter Posted 2 hours ago Posted 2 hours ago 2 hours ago, Crofter said: Looking to do a low budget build, some years in the future, and I was wondering about picking up some good quality windows on Gumtree etc. There seems to be quite a lot of stuff around, I don't know if it's from renovations, or wrong sizes being ordered etc. Question is, would I need some sort of certification to satisfy BCO about u values etc? If so, what would they be looking for, and would it be stamped on the frame or would I be needing documentation? Love this. Ok, first thing is if double glazing often the spacer bar will have a mark and date with the BS code, sometimes the year of manufacture of the unit. So you can bench mark that with the historic U value of the unit. If you can find that then we might explore more. 1
Crofter Posted 2 hours ago Author Posted 2 hours ago 38 minutes ago, Gus Potter said: If you can find that then we might explore more. It's hypothetical at the moment- was just wondering if I might be wasting my time going hunting for windows on Gumtree.
