oldkettle Posted January 7, 2018 Posted January 7, 2018 CCTV camera may be helpful for quick assessment. Add software which triggers on any picture change and it may just spot these water drops. Probably expensive to run even if it works, though.
Russell griffiths Posted January 7, 2018 Posted January 7, 2018 When I fitted air con in my last place the unit in the loft had a folded galv tray under the unit with a drain pipe that went to the outside, any condensation or water drips would exit out the pipe very effectively. So maybe we should start thinking about these under any wet equipment. 1
Onoff Posted January 7, 2018 Posted January 7, 2018 1 hour ago, Russell griffiths said: When I fitted air con in my last place the unit in the loft had a folded galv tray under the unit with a drain pipe that went to the outside, any condensation or water drips would exit out the pipe very effectively. So maybe we should start thinking about these under any wet equipment. Condensate drain pipes or trays with pipes tend to be de rigueur on commercial installs.
Jeremy Harris Posted January 7, 2018 Posted January 7, 2018 I found that if you hunt around you can usually find a plastic tray that will be the right sort of size. The ones made for gardening like this: http://www.ebay.co.uk/itm/Garland-Garden-Trays-Various-Sizes-Types-Colours-Plastic-Hydroponic-Greenhouse/131800494006?_trkparms=aid%3D555019%26algo%3DPL.BANDIT%26ao%3D1%26asc%3D20151005190705%26meid%3D1b04e6e4aff2486f848526df591e0ac3%26pid%3D100506%26rk%3D1%26rkt%3D1%26&_trksid=p2045573.c100506.m3226 are often a good starting point. You can usually fit a small tank fitting and run a drain from them or fit a water level alarm, as I've done in the water treatment plant shed, or do both, so you have a warning of a leak as well as somewhere for the run off to go.
Nickfromwales Posted January 7, 2018 Posted January 7, 2018 The tray and overflow pipe is just so much easier and requires no thought. Run the discharge pipe over a door or window so you can see it's leaking reasonably quickly. Dont forget a simple easily accessible means of local isolation, like a 1/4 turn lever valve.
Russell griffiths Posted January 7, 2018 Posted January 7, 2018 Our tray for the air con unit was hung from the rafters on 4 pieces of threaded rod so very easy to adjust to give a little fall to the outlet.
