gavztheouch Posted Thursday at 23:04 Posted Thursday at 23:04 I have a metal roof made of green coat steel from sweden apparently it should last 50 years. Is this also a good material to make window sills from. I can get it up to 0.9mm I think.
Gus Potter Posted yesterday at 00:04 Posted yesterday at 00:04 49 minutes ago, gavztheouch said: I have a metal roof made of green coat steel from sweden apparently it should last 50 years. Is this also a good material to make window sills from. I can get it up to 0.9mm I think. Ha ha..this is a hot topic on my books at the moment! story for another day. The secret is in the detailing. Let's go back to traditional leadwork. In any place where you get regular dripping of water then we would go for code 5 lead as a minimum . Your first port of call is to look at the exposure condition, is it sheltered or near the coast with salt in the air. Next is to refer to say Kingspan cladding techincal data for steel coated panels, similar to Greencoat... your cill is just the same. To give you a direct answer in ideal conditions say as a roofing panel away from the sea.. 50 years.. but as a cill maybe not unless it is under shetlered eaves. But will your window last that long?
saveasteading Posted yesterday at 07:08 Posted yesterday at 07:08 7 hours ago, gavztheouch said: green coat steel I'd never heard of this despite building 300+ steel buildings, so thanks fof widening my awareness. The website is vague about why it is supposedly so good , and even what the coating is made of. Can one if you tell me briefly? 8 hours ago, gavztheouch said: Is this also a good material to make window sills from? That's for a window sills manufacturer to decide isn't it? It might depend on the folds and how much the coating stretches.
Russell griffiths Posted yesterday at 08:31 Posted yesterday at 08:31 No, get them folded in aluminium and powder coated in the colour of your choice.
Tosh Posted 22 hours ago Posted 22 hours ago I have it as well https://www.ssab.com/en-gb/brands-and-products/greencoat/products/plx/pural-bt Can't see any technical reason why you couldn't use it to make cills, we used it for that but only because it was an integral part of the metal facade cladding. However we used aluminium cills everywhere else, supplied by the window supplier, was just easier to procure and cheaper. Metalsolutions are the Greencoat UK distribtor and looks like they will fabricate to order as well if you want to go down that route.
gavztheouch Posted 22 hours ago Author Posted 22 hours ago (edited) 30 minutes ago, Tosh said: I have it as well https://www.ssab.com/en-gb/brands-and-products/greencoat/products/plx/pural-bt Can't see any technical reason why you couldn't use it to make cills, we used it for that but only because it was an integral part of the metal facade cladding. However we used aluminium cills everywhere else, supplied by the window supplier, was just easier to procure and cheaper. Metalsolutions are the Greencoat UK distribtor and looks like they will fabricate to order as well if you want to go down that route. Thanks Tosh, yes I’ve been in contact with metal solutions they are very helpful. The Glasgow depot is close to me. I liked the idea of cutting and folding my own cills. A future project of mine is to learn how to work the metal for standing seam roofs and cladding. Edited 22 hours ago by gavztheouch 1
Russell griffiths Posted 4 hours ago Posted 4 hours ago 17 hours ago, gavztheouch said: Thanks Tosh, yes I’ve been in contact with metal solutions they are very helpful. The Glasgow depot is close to me. I liked the idea of cutting and folding my own cills. A future project of mine is to learn how to work the metal for standing seam roofs and cladding. My cills have welded upstands on the ends to prevent water running from the sides and into the fabric of the building, you can’t weld the green coat without damage to the coating.
