Pocster Posted Wednesday at 14:46 Author Posted Wednesday at 14:46 OK! Back here again! So need to cool 2 bedrooms with AC. No floor standing shite. So I guess single contained units; 1 in each room no split system. Going to be a BASTARD to install i.e. to get the vent pipe through. (TWICE!) Am I allowed to vent into the loft? 🙃 has it GOT to be outdoors? Electrics ok to wire off either a plug or off an existing socket ring?. No chance getting wiring from AC back to CU.... I'm under SWMBO orders to investigate!
Mr Punter Posted Wednesday at 15:00 Posted Wednesday at 15:00 You may as well get someone to supply and fit, as you need to meet electrical and Fgas regs. They are probably busy now. Have a ring round in a week or two.
Pocster Posted Wednesday at 15:01 Author Posted Wednesday at 15:01 Water cooled air con? As far as I understand no vent through wall. Air con unit just needs pipe work to condensor unit. I could mount that under MVHR unit and share its drainage channel to outdoors???
Pocster Posted Wednesday at 15:02 Author Posted Wednesday at 15:02 2 minutes ago, Mr Punter said: You may as well get someone to supply and fit, as you need to meet electrical and Fgas regs. They are probably busy now. Have a ring round in a week or two. Don't want someone looking! DIY please
Pocster Posted Wednesday at 15:06 Author Posted Wednesday at 15:06 https://cooleasy.co.uk/products/powrmatic-vision-h2o???? 3k! presumably is the condenser aswell???
Mr Punter Posted Wednesday at 15:21 Posted Wednesday at 15:21 17 minutes ago, Pocster said: Don't want someone looking! DIY please Well you could gag and blindfold them I suppose...
Pocster Posted Wednesday at 15:22 Author Posted Wednesday at 15:22 But now I'm thinking... https://www.argos.co.uk/product/7623899?deeplink=true&gclsrc=aw.ds&&_$ja=tsid:11675|acid:542-316-8335|cid:6514064352|agid:76370554737|tid:kwl-3500001|crid:610242503975|nw:g|rnd:4608841013949138266|dvc:c|adp:|mt:a|loc:9045627&utm_source=Google&utm_medium=cpc&utm_campaign=6514064352&utm_term=&utm_content=text&utm_custom1=76370554737&utm_custom2=542-316-8335&cmpid=GG05X&GPDP=true&gad_source=1&gad_campaignid=6514064352&gbraid=0AAAAAD9II9kB4EdwoWJiJtjRBVlI1afcv&gclid=EAIaIQobChMI4sjlieLZlAMVhotQBh3GDSczEAAYASAAEgKcafD_BwE £400 and make a 'panel' so the vent isnt just hanging out a window/sliding door.
Pocster Posted Wednesday at 15:22 Author Posted Wednesday at 15:22 1 minute ago, Mr Punter said: Well you could gag and blindfold them I suppose... I can only think of 1 reason someone would gag............
SimonD Posted Wednesday at 15:31 Posted Wednesday at 15:31 22 minutes ago, Pocster said: https://cooleasy.co.uk/products/powrmatic-vision-h2o???? 3k! presumably is the condenser aswell??? For a minute I thought you'd uncovered a blinder of a solution. Well, maybe not quite as simple as hoped, unless you're happy to tap into your heating system. Have a look at the required schematic. Easier to go with the 2 hole versions probably.
Pocster Posted Wednesday at 16:20 Author Posted Wednesday at 16:20 49 minutes ago, SimonD said: For a minute I thought you'd uncovered a blinder of a solution. Well, maybe not quite as simple as hoped, unless you're happy to tap into your heating system. Have a look at the required schematic. Easier to go with the 2 hole versions probably. My link is!. water in, electric in, drain out. Cost is upsetting though.... Looking back at cheap mobile units where you jsut sticka vent out the door and seal that gap up....
SimonD Posted Wednesday at 17:26 Posted Wednesday at 17:26 53 minutes ago, Pocster said: My link is!. water in, electric in, drain out. If only it were that simple. The screenshot is from the installation manual for that exact model - the Powrmatic Vision H20. I'm more inclined to believe the manufacturer than the salesman? Think about it. It's a bonkers idea that you just turn a mains tap on and then let it run into a drain? 1 hour ago, Pocster said: Cost is upsetting though Yes, the through wall ones can be had for about 1/2 that price.
Pocster Posted Wednesday at 17:48 Author Posted Wednesday at 17:48 21 minutes ago, SimonD said: If only it were that simple. The screenshot is from the installation manual for that exact model - the Powrmatic Vision H20. I'm more inclined to believe the manufacturer than the salesman? Think about it. It's a bonkers idea that you just turn a mains tap on and then let it run into a drain? Yes, the through wall ones can be had for about 1/2 that price. Buy it ! Prove me wrong ! Said that to a girl a few months ago … didn’t end well ! 1
SteamyTea Posted Wednesday at 21:03 Posted Wednesday at 21:03 6 hours ago, Pocster said: Water cooled air con There is air cooling and air conditioning, they are not the same thing. Air conditioning controls the humidity and the temperature.
Pocster Posted 4 hours ago Author Posted 4 hours ago What a pile of wank . I think just a piece of ply somehow fixed to opening ( not (expletive deleted)ing window ) would be better ! Wank concept and wank install 2
Pocster Posted 4 hours ago Author Posted 4 hours ago (edited) Presumably I go out and burglar just opens window and steals everything. shite I think a simple piece of board fixed against frame with hole in would be better . Take seconds to setup and take down . This is shite with a capital S ! Edited 4 hours ago by Pocster 1
Pocster Posted 4 hours ago Author Posted 4 hours ago 4 minutes ago, crispy_wafer said: what the feck on earth is that? Don’t just don’t !
Ed_ Posted 3 hours ago Posted 3 hours ago Some of these portable AC units can be simply modified so that the air intake is ducted outside too which makes it closed loop. A whole internet ecosystem of people doing it!
SteamyTea Posted 3 hours ago Posted 3 hours ago 31 minutes ago, crispy_wafer said: Better! Is that a sex robot. Not quite what I imagined, but each to their own. Something for everyone here. 1 1
Pocster Posted 2 hours ago Author Posted 2 hours ago 11 minutes ago, SteamyTea said: Is that a sex robot. Not quite what I imagined, but each to their own. Something for everyone here. I would
Pocster Posted 2 hours ago Author Posted 2 hours ago The unit itself whilst noisy does seem to work !
SteamyTea Posted 2 hours ago Posted 2 hours ago 6 minutes ago, Pocster said: I would Is it the grey cardigan that does it for you? 1
Pocster Posted 1 hour ago Author Posted 1 hour ago (edited) 1 hour ago, SteamyTea said: Is it the grey cardigan that does it for you? Willma in a cardy............😋 Edited 1 hour ago by Pocster
