Pocster Posted 4 hours ago Author Posted 4 hours ago OK! Back here again! So need to cool 2 bedrooms with AC. No floor standing shite. So I guess single contained units; 1 in each room no split system. Going to be a BASTARD to install i.e. to get the vent pipe through. (TWICE!) Am I allowed to vent into the loft? 🙃 has it GOT to be outdoors? Electrics ok to wire off either a plug or off an existing socket ring?. No chance getting wiring from AC back to CU.... I'm under SWMBO orders to investigate!
Mr Punter Posted 4 hours ago Posted 4 hours ago You may as well get someone to supply and fit, as you need to meet electrical and Fgas regs. They are probably busy now. Have a ring round in a week or two.
Pocster Posted 4 hours ago Author Posted 4 hours ago Water cooled air con? As far as I understand no vent through wall. Air con unit just needs pipe work to condensor unit. I could mount that under MVHR unit and share its drainage channel to outdoors???
Pocster Posted 4 hours ago Author Posted 4 hours ago 2 minutes ago, Mr Punter said: You may as well get someone to supply and fit, as you need to meet electrical and Fgas regs. They are probably busy now. Have a ring round in a week or two. Don't want someone looking! DIY please
Pocster Posted 3 hours ago Author Posted 3 hours ago https://cooleasy.co.uk/products/powrmatic-vision-h2o???? 3k! presumably is the condenser aswell???
Mr Punter Posted 3 hours ago Posted 3 hours ago 17 minutes ago, Pocster said: Don't want someone looking! DIY please Well you could gag and blindfold them I suppose...
Pocster Posted 3 hours ago Author Posted 3 hours ago But now I'm thinking... https://www.argos.co.uk/product/7623899?deeplink=true&gclsrc=aw.ds&&_$ja=tsid:11675|acid:542-316-8335|cid:6514064352|agid:76370554737|tid:kwl-3500001|crid:610242503975|nw:g|rnd:4608841013949138266|dvc:c|adp:|mt:a|loc:9045627&utm_source=Google&utm_medium=cpc&utm_campaign=6514064352&utm_term=&utm_content=text&utm_custom1=76370554737&utm_custom2=542-316-8335&cmpid=GG05X&GPDP=true&gad_source=1&gad_campaignid=6514064352&gbraid=0AAAAAD9II9kB4EdwoWJiJtjRBVlI1afcv&gclid=EAIaIQobChMI4sjlieLZlAMVhotQBh3GDSczEAAYASAAEgKcafD_BwE £400 and make a 'panel' so the vent isnt just hanging out a window/sliding door.
Pocster Posted 3 hours ago Author Posted 3 hours ago 1 minute ago, Mr Punter said: Well you could gag and blindfold them I suppose... I can only think of 1 reason someone would gag............
SimonD Posted 3 hours ago Posted 3 hours ago 22 minutes ago, Pocster said: https://cooleasy.co.uk/products/powrmatic-vision-h2o???? 3k! presumably is the condenser aswell??? For a minute I thought you'd uncovered a blinder of a solution. Well, maybe not quite as simple as hoped, unless you're happy to tap into your heating system. Have a look at the required schematic. Easier to go with the 2 hole versions probably.
Pocster Posted 2 hours ago Author Posted 2 hours ago 49 minutes ago, SimonD said: For a minute I thought you'd uncovered a blinder of a solution. Well, maybe not quite as simple as hoped, unless you're happy to tap into your heating system. Have a look at the required schematic. Easier to go with the 2 hole versions probably. My link is!. water in, electric in, drain out. Cost is upsetting though.... Looking back at cheap mobile units where you jsut sticka vent out the door and seal that gap up....
SimonD Posted 1 hour ago Posted 1 hour ago 53 minutes ago, Pocster said: My link is!. water in, electric in, drain out. If only it were that simple. The screenshot is from the installation manual for that exact model - the Powrmatic Vision H20. I'm more inclined to believe the manufacturer than the salesman? Think about it. It's a bonkers idea that you just turn a mains tap on and then let it run into a drain? 1 hour ago, Pocster said: Cost is upsetting though Yes, the through wall ones can be had for about 1/2 that price.
Pocster Posted 1 hour ago Author Posted 1 hour ago 21 minutes ago, SimonD said: If only it were that simple. The screenshot is from the installation manual for that exact model - the Powrmatic Vision H20. I'm more inclined to believe the manufacturer than the salesman? Think about it. It's a bonkers idea that you just turn a mains tap on and then let it run into a drain? Yes, the through wall ones can be had for about 1/2 that price. Buy it ! Prove me wrong ! Said that to a girl a few months ago … didn’t end well ! 1
