Murch Posted July 13 Posted July 13 Hello folks. 1st time poster so forgive me if my terminology isn’t correct on certain components . Basically we have bought a new home to which we need to carry out certain renovations. The first job on the agenda is seeing if I can raise the height of 2 doorways. The older part of the house was originally a block of three very small cottages so also originally were not linked by doors between . I shall try and post a picture below for reference as I try to describe the issue . As the cottages we’re fairly small the upper floors are I think what is referred to as “vaulted” . Inside each room is actually a decent head height. However where they had put doors adjoining each cottage, the height of the doorways is some 5’! I’m 6’6” so don’t wish to bang my shoulders let alone my head ! The reason these doors are low is because there is a timber joist spanning each wall and tied to the outer walls with a bracket . So my 1st question is .. is this actually a structural joist even though “collar ties” are installed onto every rafter ? From the picture I shall attach the dividing walls do not extend to the point of the roof. Also there is no ridge board or beam, just rafter to rafter .
SteamyTea Posted July 13 Posted July 13 Generally, if a solid walls goes from the foundation to the roof, it is structural. It can be removed and parts replaced with structural beams, but it needs to be properly calculated by a structural engineer who knows what they are doing, as it can impact on other parts of the building structure. We have a good structural engineer on here, @Gus Potter, so hopefully he will come along and give some words of wisdom. 1
ProDave Posted July 13 Posted July 13 I suspect those walls are supporting the roof purlins at either side. So treat them as structural. The only way to get enough headroom for taller doors, is move them towards the centre a bit. The headroom at the edge is what made them put small doors there. 1
Murch Posted July 14 Author Posted July 14 Thankyou for input so far . Yes my plan would be to move the door over to allow for a squared off door not one with a 45degree cut off. It’s the beam as mentioned which I am curious. I’m not going to do anything without a structural engineer but I’m trying to design the upper floor to dictate what I am actually going to ask for.
Nickfromwales Posted July 15 Posted July 15 On 14/07/2025 at 03:50, ETC said: Move the door! Assuming that’s a corridor that comes past the room next door, not so easy to do? 6 hours ago, Murch said: Yes my plan would be to move the door over to allow for a squared off door not one with a 45degree cut off. Just depends on how much of the adjoining room you have to give up to allow the dog-leg required at the end of the corridor. Would require an L shaped corridor to get a full door.
Murch Posted July 15 Author Posted July 15 The middle room is already a very small room due to a disused chimney breast and built in cupboards. I’m undecided weather to do away with the middle room as a bedroom and possibly make use as en-suites or maybe just a landing area
ETC Posted July 15 Posted July 15 11 hours ago, Nickfromwales said: Assuming that’s a corridor that comes past the room next door, not so easy to do? Just depends on how much of the adjoining room you have to give up to allow the dog-leg required at the end of the corridor. Would require an L shaped corridor to get a full door. Obviously!
Nickfromwales Posted July 15 Posted July 15 3 hours ago, ETC said: Obviously! On 14/07/2025 at 03:50, ETC said: Move the door! #captainabruptinthehouse Relax, time for a spa day?
SteamyTea Posted July 16 Posted July 16 On 15/07/2025 at 06:33, Murch said: The middle room is already a very small room due to a disused chimney breast and built in cupboards. I’m undecided weather to do away with the middle room as a bedroom and possibly make use as en-suites or maybe just a landing area Do a dimensioned sketch and see what the creative minds on here can come up with. 1
