Beelbeebub Posted June 11, 2025 Posted June 11, 2025 Bit of an odd question : Is anybody aware of a device that takes an AC 240v input and outputs a DC supply in a manner so it can be plugged into a hybrid inverter and the inverter think it's connected to a PV string? Ideally the device would be able to be controlled so the power delivered to the inverter could be varied in real time.
JohnMo Posted June 11, 2025 Posted June 11, 2025 No sorry no idea. But you don't need PV connected to a hybrid inverter for it to function with a battery.
Beelbeebub Posted June 11, 2025 Author Posted June 11, 2025 I'm trying to work out a way for a number of flats to share a single panel array. My thinking is a single large array and 3ph inverter provide a 240v supply and then each flat can have a standard hybrid inverter and battery pack fed by what it thinks is it's own PV array, but is actually this hypothetical device taking power from the actual array supply (that is totally separated from the mains).
SteamyTea Posted June 11, 2025 Posted June 11, 2025 Why not just wire in an off grid system and then run separate DC cables to small inverters in each flat. If too much much power is drawn the small inverters should shut down. But would it not be easier to wire in a grid tied to the main feed and then just sub meter the PV contribution to each flat.
Nickfromwales Posted June 11, 2025 Posted June 11, 2025 Do you do all inclusive rental or do they pay for their own electricity via unique electricity meters?
Beelbeebub Posted June 11, 2025 Author Posted June 11, 2025 34 minutes ago, SteamyTea said: Why not just wire in an off grid system and then run separate DC cables to small inverters in each flat. If too much much power is drawn the small inverters should shut down. But would it not be easier to wire in a grid tied to the main feed and then just sub meter the PV contribution to each flat. I don't think supplying each flat with a submeter PV would work. The connection from the PV would have to be after their meter, otherwise I could supply elec and their energy supplier would get paid! 😁 But that would mean each flat would be interconnected after the meter. If flat A drew power it would flow through the meters of Flat A, B, C etc. There would be no way to untangle who used what. I could wire each flat to it's own string but then have to run DC to each flat, there there are issues of a particular panel fails that flat loses it's PV, whilst if I share across one big array I can just disconnect the affected string and the system runs at a reduced capacity Which is why I thought about distributing the PV power as DC through the solar input. It should isolate each system and prevent "cross feeding" and allow flexibility for each flat to use more than it's share if nobody else is using it.
Beelbeebub Posted June 11, 2025 Author Posted June 11, 2025 4 minutes ago, Nickfromwales said: Do you do all inclusive rental or do they pay for their own electricity via unique electricity meters? They all pay individually with whatever supplier they pick. I'm looking to provide some PV as a benefit, as you would new carpets or the like. It also helps with the EPC ratings. It might be that providing solar is the cheapest and easiest way to get a C (it used to be switching to gas) So the generated elec would be provided free and unmetered to reduce their bills. Obviously some days would be better than others and some usage patterns would be more cost effective than others but that's on the tenants.
JohnMo Posted June 11, 2025 Posted June 11, 2025 Think you are just making life hard for your self. Give them a rent holiday, be cheaper for you and possibly more appreciated by them. 1
SteamyTea Posted June 11, 2025 Posted June 11, 2025 Got to go on a car journey for the next hour or so, do a little sketch of what you want and I can ponder it. I think you can claim a SEG payment that is unaffected by the main supplier (could with FiT) and to a different person. That way it would just be wired in after the individual meters but before the consumer/into units. Any generation will find it way to the nearest load.
Dillsue Posted June 11, 2025 Posted June 11, 2025 1 hour ago, Beelbeebub said: They all pay individually with whatever supplier they pick. So are they all on their own DNO meter and have their own MPAN? How many flats are there?
Alan Ambrose Posted June 11, 2025 Posted June 11, 2025 That's a slightly tricky / non-standard problem. Give us some more info, so we're not playing 20 questions. How big is the potential array? How many flats? Animal, vegetable or mineral etc?
Nickfromwales Posted June 11, 2025 Posted June 11, 2025 I’ve quoted jobs like these loads of times, and you just have (for eg) 6 flats, do 2-3 panels (or more, depending on roof and budget) per flat, and have 6 systems. Anything else would be impossible / impractical and hugely cost prohibitive. 1 MPAN = 1 PV system, one goes down, 5 stay online. Who’s going to monitor & maintain? Most landlord systems connect to the landlord meter that serves fire alarms and communal / external lighting etc (anything not billed to the tenants). SIMPLIFY!!
Beelbeebub Posted June 11, 2025 Author Posted June 11, 2025 3 hours ago, JohnMo said: Think you are just making life hard for your self. Give them a rent holiday, be cheaper for you and possibly more appreciated by them. Did that already but there is ultimately a limit to how long that can go on for as the running costs don't stop. The driving force is to get the EPC rating up. Reducing tenantt's utility bills is a nice side effect.
Beelbeebub Posted June 11, 2025 Author Posted June 11, 2025 So 17 flats in a 5 story building so the roof space is limited. The roof is also very old, very complex and not at all suitible for fitting PV to. The main option for panels is a pair of vertical arrays on the south side, where there are two large external chimney stacks - all the other vertical faces have windows, pipework etc on. There is also the matter of planning (aonb and conservation area) so it may be no panels are possible at all. Thereis alsoo two east facing balconies that could potentially have "balconysolar" style mounting on the balustrade . The problem is the flats near where the panels are don't need the EPC boost as much. It seems unfair to fit panels next to someone's flat and them not benefit from them, so I'd like to spread the benefits about a bit. Separate systems as mentioned by NickFromWales is a possibility but my worry is we could end up with a flat not using much of it's generating capacity, whilst the flat next door could use more capacity. Sort of like individual car ownership vs car pooling. A chunk of this depends on the upcoming EPC regs (due soon IIRC) currently (mains powered demand shifting) batteries are more or less ignored despite the potential impact on bills.It maybe fitting batteries gives me a big jump. Or not, who knows. At the mo I am just kicking about ideas.
DamonHD Posted June 11, 2025 Posted June 11, 2025 May be relevant: https://midsummerwholesale.co.uk/buy/solshare 1
Temp Posted June 12, 2025 Posted June 12, 2025 21 hours ago, DamonHD said: May be relevant: https://midsummerwholesale.co.uk/buy/solshare That looks cool.. Quote:.. The SolShare unit is placed between the inverter and the main switchboard. Receiving one three-phase AC input from the inverter and outputting up to 15 single-phase or 5 three-phase AC outputs (or a combination of both). Outputs are wired on the load side of each unit’s meter, at the building’s common main switchboard.
JohnMo Posted June 12, 2025 Posted June 12, 2025 2 hours ago, Temp said: SolShare Only £7500 for the basic unit.
Beelbeebub Posted June 13, 2025 Author Posted June 13, 2025 . Thanks for the solshare link. I've looked into it, and it is definitely a possibility. My two concerns are 1. It only does 15 flats per unit and I have 17! So two units or possibly 2 flats having their own standalone setup. 2. It seems quite "smart" and cloud enabled etc. I'm wary of stuff that requires a subscription - what happens if the company goes bust or is bought out and the new owner (or even the orginal owners) decide to jack up the prices or "enhance" your package by making it worse (hello Netflix)? Hence my wondering if there was a relatively simple sub £500 device that could allow for distribution of a single array between multiple flats via the already existing DC panel input. I was thinking of something along the lines of a current limiting 240v (or maybe 110v) power supply. The MPPT function would simply ramp up the current until it hit the limit which would be the maximum power point. If I wanted to reduce the power delivered to a given flat the current limit would reduce. The goal would be a system not reliant on external Internet connections etc.
SteamyTea Posted June 14, 2025 Posted June 14, 2025 What size (kWp) PV system are you thinking of installing? When divided by 17 flats, and accounting for utilisation (50%), is it going to be a useful saving.
Temp Posted June 14, 2025 Posted June 14, 2025 Many power supplies that have a current limit can't be used in current limiting mode continuously or they overheat and shut down further.
Beelbeebub Posted June 15, 2025 Author Posted June 15, 2025 On 14/06/2025 at 16:34, SteamyTea said: What size (kWp) PV system are you thinking of installing? When divided by 17 flats, and accounting for utilisation (50%), is it going to be a useful saving. Roughly the area to fit panels is 2 chimneys 12m high x 4m wide. So if we assume I can get 10 x 2 panels per chimney we are talking 40 panels. Assume 450w panels so nominal 18kwp but with them being vertical and other practical limits maybe 14kw peak. So a fair split of about 1kw per flat maybe. Maybe each flat has a 3kw inverter and maybe 5kwh or 10kwh storage.
JohnMo Posted June 15, 2025 Posted June 15, 2025 7 minutes ago, Beelbeebub said: 18kwp So +/-1kW per flat. So why not give each flat a Ecoflow Stream either Pro or Ultra. The pro has 3x MPPTs and the Ultra 4x MPPTs. Each MPPT will take a 500W panel. They also include a 2kWh battery. Cost £999 each, so battery and inverter. 2x PV panels £130. Then the mounts and cables. Each panel is controlled independently, so no shading issues. 1
SteamyTea Posted June 16, 2025 Posted June 16, 2025 Run it though PVGIS and then see if it is worth it.
Nickfromwales Posted June 16, 2025 Posted June 16, 2025 11 hours ago, Beelbeebub said: Roughly the area to fit panels is 2 chimneys 12m high x 4m wide. So if we assume I can get 10 x 2 panels per chimney we are talking 40 panels. Have you checked with a structural engineer to confirm you can attach 2 giant sails to the chimney stacks?
Nickfromwales Posted June 16, 2025 Posted June 16, 2025 At 40 panels divided by 17 flats, net delivered will be <1kwp per flat @460w per panel. Expensive pita of a job / idea imo, sorry. Then add maintenance and inverter(s) (17 of them) being replaced in <10-15 years, if they last that long, and there’s your ‘money savings’ gone and then some. KISS is my 2 cents, so leave well alone.
