Antec123 Posted June 4, 2025 Posted June 4, 2025 (edited) Hi, we have had our kitchen screeded with "Cemfloor Level+ with Fibers", 20m2 and at 25mm depth, this was yesterday. Wet UFH under it, with XPS boards (with grooves for the pipes) We were told we can walk on it after 24 hours (24 hours has passed by and yes its walkable and have opened the windows and door for ventilation) and tile after 3 weeks, we are going to tile on it with 1200x1200 tiles, which came with enough Kelmore MoreFlex S1 Standard adhesive for the tiles. Ive read Cemfloor has no Laitance so we will not need to remove the dust? thats a relief! As we have spent a pretty penny on these tiles, I was thinking of using Dural Durabase CI++ decoupling matt due to its vapour control, do you think it's wise? will cost around £170 for 20m2, or are there any cheaper ones I can use? I will need to buy some adhesive for it, which is the go to for matting? and how many bags do I need? Also in your option, how soon can Cemfloor be tiled on? how do I know when the floor is completely cured?, does it need priming before the decoupling matt? Thanks Edited June 4, 2025 by Antec123
Conor Posted June 4, 2025 Posted June 4, 2025 (edited) We tiled directly on to our cemfloor, no issues. No grinding, no decoupling mats. Tho our drying time was a lot longer, 3 months for 50mm. The general rule is 1 day per mm, for standard adhesive directly on to screed. You can use green screed adhesive and tile within days. Edited June 4, 2025 by Conor 1
nod Posted June 4, 2025 Posted June 4, 2025 1 hour ago, Antec123 said: Hi, we have had our kitchen screeded with "Cemfloor Level+ with Fibers", 20m2 and at 25mm depth, this was yesterday. Wet UFH under it, with XPS boards (with grooves for the pipes) We were told we can walk on it after 24 hours (24 hours has passed by and yes its walkable and have opened the windows and door for ventilation) and tile after 3 weeks, we are going to tile on it with 1200x1200 tiles, which came with enough Kelmore MoreFlex S1 Standard adhesive for the tiles. Ive read Cemfloor has no Laitance so we will not need to remove the dust? thats a relief! As we have spent a pretty penny on these tiles, I was thinking of using Dural Durabase CI++ decoupling matt due to its vapour control, do you think it's wise? will cost around £170 for 20m2, or are there any cheaper ones I can use? I will need to buy some adhesive for it, which is the go to for matting? and how many bags do I need? Also in your option, how soon can Cemfloor be tiled on? how do I know when the floor is completely cured?, does it need priming before the decoupling matt? Thanks Scrape any loose material off the top Prime with SBR 12 hours before if possible No need for matting 1
Antec123 Posted June 4, 2025 Author Posted June 4, 2025 (edited) 8 minutes ago, nod said: Scrape any loose material off the top Prime with SBR 12 hours before if possible No need for matting Thank you, would you still say 3 week is long enough to wait? how does one actually know its cured? or just play by ear Edited June 4, 2025 by Antec123
Antec123 Posted June 4, 2025 Author Posted June 4, 2025 17 minutes ago, Conor said: We tiled directly on to our cemfloor, no issues. No grinding, no decoupling mats. Tho our drying time was a lot longer, 3 months for 50mm. The general rule is 1 day per mm, for standard adhesive directly on to screed. You can use green screed adhesive and tile within days. Thank you, good to know matting not needed!
Antec123 Posted June 4, 2025 Author Posted June 4, 2025 Looking at the Guidelines for Cemfloor UFH, it says can start UFH commissioning after 7 days: https://cemfloor.co.uk/wp-content/uploads/Datasheet_Cemfloor-Therm-UFH-Guideline_2020.pdf @nod whats your take on this?
nod Posted June 4, 2025 Posted June 4, 2025 15 minutes ago, Antec123 said: Looking at the Guidelines for Cemfloor UFH, it says can start UFH commissioning after 7 days: https://cemfloor.co.uk/wp-content/uploads/Datasheet_Cemfloor-Therm-UFH-Guideline_2020.pdf @nod whats your take on this? I can only go from experience I tile dozens of these floors each year without any Matt The floor matting has only become popular over the last 20 years It was once the norm to screed in the morning and tile in the afternoon 1
Antec123 Posted June 5, 2025 Author Posted June 5, 2025 9 hours ago, nod said: I can only go from experience I tile dozens of these floors each year without any Matt The floor matting has only become popular over the last 20 years It was once the norm to screed in the morning and tile in the afternoon Thank you. Have you ever commissioned UFH with Cemfloor? Is the 7 day start time realistic?
Kelvin Posted June 5, 2025 Posted June 5, 2025 (edited) What our tiler wanted was for us to run the ASHP in floor drying mode which, from memory, took two weeks. It slowly heats up the floor then slowly cools it back down again. It then had to be off for at least 24 hours before tiling. We did this after 14 days from the screed being poured. The reason I used Ditra mat is because a friend tiled directly onto Cemfloor and had three cracked tiles a few months later. However he didn’t fit crack inducers in any of the doorways etc Edited June 5, 2025 by Kelvin 1
nod Posted June 5, 2025 Posted June 5, 2025 2 minutes ago, Antec123 said: Thank you. Have you ever commissioned UFH with Cemfloor? Is the 7 day start time realistic? Nearly all the sites and houses that we tile haven’t got a bio or ASHP in place at the time of tiling While I’m not a heating engineer the temperatures are so low that it never effects the floor coverings Weve just finished a 5 million pound house 700 m2 of floor tiles indoor swimming pool The HP is set to be commissioned in October and that’s on a traditional screed I commissioned the heating on both our builds {traditional screed ) Simply because I could The reality is that on most commercial or Grand designs The heating is rarely commissioned You are paying extra money Around a third for Flo Simply for convenience Prime tile 1
Kelvin Posted June 5, 2025 Posted June 5, 2025 Our Cemfloor supplier said the same as Nod. No need for Ditra mat, tile on it after 7 days, no need for prep just clean it, no need to commission the UFH. I chose to do all of it because we had time and I’d had enough problems up until that point 😂 1
NEMCA Posted January 20 Posted January 20 On 05/06/2025 at 08:33, Kelvin said: Our Cemfloor supplier said the same as Nod. No need for Ditra mat, tile on it after 7 days, no need for prep just clean it, no need to commission the UFH. I chose to do all of it because we had time and I’d had enough problems up until that point 😂 Did you apply a coat of SBR prior to tiling or just clean Cemfloor and then start tiling? What size is area did you tile, did you have any expansion joints?
Kelvin Posted January 20 Posted January 20 No just made sure the floor was as clean. 164m2. Yes across the longest room and at every door junction. 1
NEMCA Posted January 22 Posted January 22 On 20/01/2026 at 16:17, Kelvin said: No just made sure the floor was as clean. 164m2. Yes across the longest room and at every door junction. Cheers, that's what I had in mind regarding expansion, my longest area is 10.3m x 6.0m wide so I'll prob split that in half. Coincidentally I have the exact same ground floor m2 🤓. And you started tiling after 7 days? No issues with moisture?
Kelvin Posted January 24 Posted January 24 On 22/01/2026 at 11:12, NEMCA said: Cheers, that's what I had in mind regarding expansion, my longest area is 10.3m x 6.0m wide so I'll prob split that in half. Coincidentally I have the exact same ground floor m2 🤓. And you started tiling after 7 days? No issues with moisture? No it ended up being slightly longer due to useless plasterer delaying me. I did run the ASHP in floor drying mode which I think took about 10 days. We had one small crack in the screed across the floor from a doorway into the kitchen.
Nickfromwales Posted January 24 Posted January 24 Standard tile adhesive had been mentioned earlier on, so best to reiterate this needs to be flexible tile adhesive for best results and to provide some decoupling. 1
crispy_wafer Posted February 25 Posted February 25 I'm going to bounce into this thread rather start afresh, Appreciate I'm taking from the forum and not giving much back, but same situation! Cemfloor, Tiles... matting required or not. Two tilers been round, middle aged gent asks how long screed been down, I says 2 years, has the odd (3) crack coming out of doorways where expansion joints were not inserted, asks my opinion on anti crack matting me says no idea you're the expert!, he says 'good, 2 years, I don't think you need it' Younger chappie comes round at weekend would rather install matting! Now I've no idea what to do, it's budgeted for, but if I can put the £15 m2 (supply + install) cost towards doors or other fittings then I'd rather do so. But, belt and braces and all that, will I regret not doing so?
Kelvin Posted February 25 Posted February 25 (edited) It’s likely fine without it however we used it and we only had one relatively small crack in the Cemfloor. Both the tilers that quoted for ours said they’d prefer to use it though were happy to quote without it. One of them said he’d just done his house and used it. There’s very little labour in it so it’s not as if it’s an unnecessary upsell. Edited February 25 by Kelvin 1
saveasteading Posted February 25 Posted February 25 I can't see the point unless the floor is very badly made and likely to shrink or deflect. I've never known tiles to crack in my house (old and poor quality slab) or commercially ( new but high quality slabs) or even over hardboard over floorboards. I have seen a crack elsewhere: parallel to a movement joint, so the slab must have been moving. Would a mat have prevented this? Maybe. Summary: in a newbuild of unknown quality I might use it. Otherwise no. 1
Gone West Posted February 25 Posted February 25 1 hour ago, crispy_wafer said: Two tilers been round, middle aged gent asks how long screed been down, I says 2 years, has the odd (3) crack coming out of doorways where expansion joints were not inserted, asks my opinion on anti crack matting me says no idea you're the expert!, he says 'good, 2 years, I don't think you need it' Our concrete slab had been down for nearly six years when we tiled. We used BAL flexible tile adhesive and used door threshold expansion strips. No decoupling matting used. We didn't have any problems. 1
saveasteading Posted February 25 Posted February 25 2 hours ago, Gone West said: BAL flexible tile adhesive I wonder if the grout is quite weak, it crushes before a tile cracks, as with mortar and bricks.
