flanagaj Posted May 18, 2025 Posted May 18, 2025 I have a number of conditions that need to be signed off before we can officially start development. Before our app was granted, I dug a trench to have a temporary water supply put in, and I now need to get a hard standing down asap for a static caravan (seen a very tidy one for reasonable money), but will putting down a temporary hard standing for a mobile home fall foul of enforcement or will they be ok about it?
nod Posted May 18, 2025 Posted May 18, 2025 It probably wouldn’t as far as planners are concerned But I’d check with your cil that it doesn’t breach it 1
BotusBuild Posted May 18, 2025 Posted May 18, 2025 Can you wait until your CIL exemption has been granted? I know you've already submitted this. If not, no one locally should complain if you do the work tidily (the main way local council will find out). If you can achieve tidy, quietist, clean work before CIL exemption crack on. 1
Temp Posted May 18, 2025 Posted May 18, 2025 Don't start on site until the CIL exemption is granted in writing or you can lose it. Not worth the risk. 1
flanagaj Posted May 19, 2025 Author Posted May 19, 2025 (edited) There is no CIL for a single dwelling with Basingstoke & Deane. So I had a response back from Development Control. They basically confirmed what the architects stated. "The siting of the mobile home and the hardcore standing are permitted development for a temporary period whilst the dwelling is constructed. The siting of the mobile home and hardcore would not constitute commencement of the development." Edited May 19, 2025 by flanagaj 1
saveasteading Posted May 19, 2025 Posted May 19, 2025 42 minutes ago, flanagaj said: commencement of the development." Building inspectors became strict on this about 8? Years ago. There must have been an issue. Whereas once you could prepare the site or put up surveying posts and profiles, they now wanted some actual construction of the primary project.. Eg a section of foundation or the hardcore for a slab.
DevilDamo Posted May 19, 2025 Posted May 19, 2025 5 hours ago, saveasteading said: Building inspectors became strict on this about 8? Years ago. There must have been an issue. Whereas once you could prepare the site or put up surveying posts and profiles, they now wanted some actual construction of the primary project.. Eg a section of foundation or the hardcore for a slab. The Building Regulation definition of commencement changed. The Planning definition of commencement has not changed. According to legislation, making a material start would be defined as any of the following material operations: - Any work of construction in the course of the erection of a building. - Any work of demolition of a building (where demolition is authorised by the planning permission). - The digging of a trench which is to contain the foundations, or part of the foundations, of a building. - The laying of any underground main or pipe to the foundations or part of the foundations of a building. - Any operation in the course of laying out or constructing a road or part of a road. - Any change in the use of any land which constitutes material development. To be material, an operation must be more than de minimis (i.e. more than negligible). 1
saveasteading Posted May 19, 2025 Posted May 19, 2025 4 hours ago, DevilDamo said: Any operation in the course of laying out or constructing a road or part of a road. Our BCO didn't accept that any longer. Even strippng the site was a marginal decision unless on a grand scale. Banging in some posts with cross rails and painting red and white stripes had been my default for years.....they look good on site too.
DevilDamo Posted May 20, 2025 Posted May 20, 2025 14 hours ago, saveasteading said: Our BCO didn't accept that any longer. I wasn’t talking about Building Control.
saveasteading Posted May 20, 2025 Posted May 20, 2025 28 minutes ago, DevilDamo said: wasn’t talking about Building Control My error in non clarity. Planners required Bco to be satisfied it was started. They would only seek proof if there was any complaint but it was our risk. The bco advised what they now deemed 'started', and it was stricter than previously. He didn't know the reason, but said it was policy. Presumably there had been a dispute somewhere.
