Wood/Multifuel clean-burning 5 kw stove recommendations (never bought one before!)
Hi, I’m looking at getting a clean-burning 5 kw Wood/Multifuel stove as part of my Small Mission Hall renovation project in the Outer Hebrides (no, I don’t have access to a peat bank)
Unfortunately, I didn’t realise just how many different options and makes of stoves that exist out there! 😳
Hoping that I might be able to get a bit of advice or recommendations as to ones that are worth looking at (or avoiding!), to try and help narrow down my search a little…
Any experience or advice would be greatly appreciated!
I would always get a stove that took external air for air for primary and secondary air. Otherwise you are heating air then it's being sucked back in to stove as combustion air and cold outside air is being pulled in.
Another thing I have found is stoves with plenty of soap stone give off a much more steady flow of heat, slowly heat up, steady output and then slow to cool when fire has stopped.
any recommendations on stoves that do or have this?
Ours is a Mendip stoves Churchill 5. Chosen because it is a nice compromise between traditional look and modern look. and it takes both primary and secondary air from a direct air duct.  Very pleased it burns well, easy to manage and keeps itself clean.
Nice, yeah I’m not after the more traditional styled soves, so yeah, this works style-wise for me 😎
The Burley small stove works well IME. Not sure if they have a closed combustion option though
You mean something like the Bradgate 9305-C?
2 hours ago, Temp said:
The Clearview wood burners are pretty good.
Thanks, but a little bit too traditional looking wise for what I’m after
We have clearviews and they are brilliant, but fir our new place we are going for a small charnwood with external air kit which is , for us the next best option performance/cost wise and more modern looking.
