2 minutes ago, LnP said:
is there an umbrella scheme operator out there who will work with the client on the design
Maybe, but they have to follow all MCS guidance.
So unless you have an actual air test they have to use the MCS figures for ventilation heat losses etc.
To take credit for MVHR it has to be installed and commissioned etc etc.
I just couldn't be ar£ed with all the faff to get very little in return.
I DIY installed my Vaillant Arotherm via an umbrella scheme and it was cost neutral once I received the £7.5k BUS grant.  Headline figures were £4k for 7kW heat pump (250 m2 property) , £1k for 250l Vaillant cylinder and £1.6k for umbrella side of things.  I did all of the plumbing and electrics and it took me 3 or 4 days off and on, it was fairly simple as already had the underfloor side of things installed, I did take the opportunity to remove the mixer and pump from manifold, also removed all of the actuators.  System has been running great with COP in high 4's
I used :  https://www.air2heat.co.uk/mcs-umbrella-scheme   Paul was great, he does a site visit, does the heat loss calcs, all of the BUS application etc.  He is also flexible as to what manufacturer you go with and as far as I am aware supports Vaillant, Panasonic, Daiken, Mitsubishi & Samsung.  I had already set my heart on the Vaillant but I remember Paul being a huge advocate of the Panasonics.  I also understand he supports most of the country but may be wrong. A really nice chap so well worth a call.
  • Like 3
  • Thanks 3
Hi @mk1_man
I would like to know more about your experience with air2heat please? I've had some obscene quotes for an ASHP, and given the entire house is being renovated room by room and the house needs to be replumbed, and have UFH installed I think id prefer the DIY at my pace route.
Are you a plumber by trade?
Thanks
On 20/04/2025 at 06:41, SelfBuildSmurf said:
Hi @mk1_man
Thanks
Hi, not a plumber just a very hands on self builder.  what would you like to know?  Drop me a pm with your number and I can give you a call if that works better?
A2A here.
It's working pucker.
You can hear the fan but it's not bad. Estimate cop is 3-3.5. cost €1500 installed, eBay and cash to a mate for Fgas.
Daikin FTXM25R.
Im looking to DIY an ASHP. Did you need anything additional for the unvented cylinder install (G3)? I already have a mixergy but assume they would want to use a their cylinder! Did the Vaillant come with all the controls etc in the package?
Thanks
Why - you can just fit the Mixergy heat pump kit? So why change it, unless it's tiny capacity wise.
Its 180L so should be OK for my usage. I just thought they would want to pair it with the ASHP and keep it the same manufacturer. I wonder if they could supply the mixergy heat pump kit within the BUS grant? Although it is only about £400.
Hi, I wasn't forced to use the Vaillant cylinder but they weren't happy with the re-heat capacity of my existing cylinder be it had twin coils being a solar cylinder.  Instead of trying to fight the point I decided to upgrade cylinder to a ashp compatible version, was originally going with a Joule but found lots of negative feedback about build quality and warranty claim issues.  Very happy with the 250l Vaillant, it heats really quickly and retains heat well.  I installed it myself and then had it signed off to cover G3 side of things.  As long as the Mixergy external plate heat exchanger satisfies mcs requirements then don;t see why it can't be kept.
Edited by mk1_man
