flanagaj Posted April 13, 2025 Posted April 13, 2025 I came across the Mux Mixer on Facebook Marketplace and I did think that it looks like an interesting bit of kit. Portable & Electric Concrete Mixer | MMXR-3221 | MudMixer® Has anyone looked into these or found something similar for the UK market?
Iceverge Posted April 13, 2025 Posted April 13, 2025 No reason why it wouldn't work. Does it limit you to pre bagged concrete though?
flanagaj Posted April 13, 2025 Author Posted April 13, 2025 3 minutes ago, Iceverge said: No reason why it wouldn't work. Does it limit you to pre bagged concrete though? They do all seem to use Quikcrete, which I think is pre mixed.
ProDave Posted April 13, 2025 Posted April 13, 2025 What the website does not SAY (you have to look at a video to understand it) is this is a continual process mixer. Feed bagged content into the top and as long as you keep that fed, you get a continuous stream of concrete out of the end. A Completely different thing to the conventional mixer which is a batch process. So I would say different machine for different use with limited overlap. Choose the machine that suits the task. 1
Russell griffiths Posted April 13, 2025 Posted April 13, 2025 What do you want it for ? i cannot think of a use for it apart from rendering.
Iceverge Posted April 13, 2025 Posted April 13, 2025 I mix a fair chunk of concrete here in a 300l tractor mixer. The mixing and filing time are the main limitations on output. It was less than half the price of that and I can do about 1m³ per HR if I'm mixing only. The this is a nice machine if you can use it as demonstrated and continually feed and pour directly into your forms. However if you want a particularly lean or strong mix I think you're stuck with what comes out of the bags. Once you need to stick a wheel barrow under the spout I think all the advantages disappear. 1
flanagaj Posted April 13, 2025 Author Posted April 13, 2025 1 hour ago, Russell griffiths said: What do you want it for ? i cannot think of a use for it apart from rendering. I thought it might be quicker for building a 20m wall of vertically installed sleepers, but having looked into it further though, the mix / flow rate does seem to be pretty low.
Iceverge Posted April 13, 2025 Posted April 13, 2025 Premixed concrete I assume is much the same as a 3:2:1 general mix which I make up for £85/m3 or 2400kg. Bagged premix concrete is about £6/40kg at best or over 4 times dearer. I bought my ballast in a truckload though so that may not be convenient for everyone. 1
