Gibdog Posted April 7 Posted April 7 Hello all, Has anyone else done a timber frame build with brick skin/cladding? I'm trying to make our build as low carbon as possible so would like to use lime mortar - with no cement - but I'm getting push back from the brickie. Has anyone else done this or have any recommendations? NHBC have guidelines on bricklaying which all include cement, but is that a rule or recommendation? I know people in the natural building world are using lime only products so it must be possible somehow...! Cheers, G
Mr Punter Posted April 7 Posted April 7 I doubt it would have the strength for modern construction types. Cavity wall, wall ties, lintels will not work / be properly tested.
JohnMo Posted April 7 Posted April 7 28 minutes ago, Gibdog said: but I'm getting push back from the brickie But what does your structural engineer say - he will have a view based on bond strength and wind loads etc.
lookseehear Posted April 7 Posted April 7 43 minutes ago, Gibdog said: Hello all, Has anyone else done a timber frame build with brick skin/cladding? I'm trying to make our build as low carbon as possible so would like to use lime mortar - with no cement - but I'm getting push back from the brickie. Has anyone else done this or have any recommendations? NHBC have guidelines on bricklaying which all include cement, but is that a rule or recommendation? I know people in the natural building world are using lime only products so it must be possible somehow...! Cheers, G You also need to remember that there are different types of lime mortar. I'm not sure how familiar you are but broadly you have two types Natural Hydraulic Lime (NHL, available in 2, 3.5 and 5 in increasing strength and reducing free lime content) Non-hydraulic lime (also technically 'NHL' by name but no-one refers to it as that) also called air-lime or you might see 'lime putty' This can be in the form of quicklime which needs to be slaked, or as hydrated lime ('bagged lime' at the builders merchants) which has already been partially hydrated I don't actually know how low carbon the different lime mortars are, but my understanding is that they all require burning either pure limestone or some mix of limestone and other stones in a kiln at very high temperatures, and that energy has to come from somewhere, which could be burning coal I guess. I just asked ChatGPT about this and got the below summary. The issue here is that non-hydraulic lime sets very slowly and isn't very strong. It's the best thing for old buildings with solid walls and no DPC, so while there's carbon to be saved, it might not be something you can get sign off from a structural perspective.
Mike Posted April 7 Posted April 7 (edited) 2 hours ago, Gibdog said: Has anyone else done a timber frame build with brick skin/cladding? No, but you may be able to do it. 2 hours ago, Gibdog said: NHBC have guidelines on bricklaying which all include cement, but is that a rule or recommendation? The use of lime lies outside the current British Standards, so it would be down to your structural engineer to make an assessment of suitability. However the NHBC Foundation have produced a paper on the subject, which may help - The use of lime-based mortars in new build (https://www.nhbc.co.uk/binaries/content/assets/nhbc/foundation/the-use-of-lime-based-mortars-in-new-build.pdf) which does say that "The data available indicates that single skin brickwork or blockwork masonry constructed with lime-based mortars quickly develops sufficient resistance to vertical loads, but that it has less resistance to lateral loads at an early age and so consideration needs to be given to this at the design stage." Edited April 7 by Mike
maxe307 Posted April 7 Posted April 7 The pushback from the bricklayer is because lime mortar takes longer to set so building a wall takes more time but you are the client so if thats what you want then its more than possible. Its also great because should your project get knocked down in the future they can scrape the lime mortar off the bricks and reuse them. There are plenty of HLM projects throughout the UK.
Rishard Posted April 7 Posted April 7 Lime is another world. My guesses are, if your Bricky isn’t familiar with it then you would need to find another. I’ve no doubt he could work with lime but it does require a bit of guidance. It would be a bit of a learning curve, if you’re happy for him to learn on your job, that would be up to you. What you really want is a hot mixed lime mortar, gauged appropriately with a local pozzalan to fit in with the local vernacular. I’ve rebuilt a barn with hot lime, some solid walls and some cavity wall with insulation. In this case it was stone with a 150mm bed with wall ties. We laid stones roughly 7-9” inches height up to 30” long. Compressive strength is very different with hot lime mortar. It firms up very quick unlike putty mixed lime which means you can lay as quick as you could with sand and cement. 2
goodbyegti Posted April 7 Posted April 7 We used lime NHL 3 (otterbein), 1 part to 2 parts yellow sand and 1 part grit. It still looks great after a couple of years. It was hard getting a regular bricky to mix it properly. Luckily we found some good masons. You also have to beat it back at just the right time to pack it into the joint. I'd do it again! 2
Rishard Posted April 7 Posted April 7 (edited) Looks great! The stone here is very soft sand stone and would degrade even with an NHL. What is the brick you’re using? Edited April 7 by Rishard
goodbyegti Posted April 7 Posted April 7 Thanks! It's 125mm cropped Purbeck limestone and a bit of blue lias. Up against some Surecav except the end which is solid.
SteamyTea Posted April 8 Posted April 8 On 07/04/2025 at 08:31, Gibdog said: I'm trying to make our build as low carbon as possible so would like to use lime mortar - with no cement That is not where the embodied CO2 savings are to be made, there is just not enough of it in a building. The delivery to site will probably produce more CO2. There are a number of ways to reduce CO2, daily energy usage is probably the most important.
Gibdog Posted May 27 Author Posted May 27 Hi all, many thanks for all your replies. It took a while but we found a solution that everyone seems happy with so just in case anyone reads this in future wanting to use lime mortar, I'd recommend speaking to Ty Mawr who are experts in lime. Our structural warranty provider has been OK with us using it as long as we buy both the mortar and aggregate from Ty Mawr. We'll be using Secil 3.5 (https://www.lime.org.uk/hydraulic-lime-singleton-birch.html) with their Cumbrian aggregate (https://www.lime.org.uk/aggregates-for-mortar-cumbrian.html).
Mr Punter Posted May 27 Posted May 27 Well done for finding a solution. I was surprised that the material cost is less than double sand cement. Let us know how you get on.
Oz07 Posted May 27 Posted May 27 I found them helpful buying some gear for a job. What did you do find another brickie or stick with original @Gibdog? I like the idea of this with the flexibility but if using on a concreted foundation I suppose the flexibility is redundant?
Gibdog Posted May 28 Author Posted May 28 14 hours ago, Oz07 said: I found them helpful buying some gear for a job. What did you do find another brickie or stick with original @Gibdog? I like the idea of this with the flexibility but if using on a concreted foundation I suppose the flexibility is redundant? Plan is to use the same brickie - he seems happy to learn and Ty Mawr assured me most brickie's are surprised to find it's not that dissimilar to their usual mix. 16 hours ago, Mr Punter said: Well done for finding a solution. I was surprised that the material cost is less than double sand cement. Let us know how you get on. Yes I was surprised it wasn't more expensive too - anything that comes in below what's in the spreadsheet is a winner!
ToughButterCup Posted May 28 Posted May 28 On 07/04/2025 at 21:48, goodbyegti said: That is just beautiful. A real treat to the eye.
sgt_woulds Posted May 28 Posted May 28 If you really want to save upfront carbon, then changing to natural stone will save much more than the mortar alone - and it will look lovely as shown above. Changing to engineered timber rather than sawn will save more - (less timber section required for the same strength, and more of the tree can be used for structural components versus traditional sawn timber). The smaller cross-section allows more insulation and reduces cold bridging as a useful side effect. This works well with a woodfibre external sheathing board and flexible insulation between the studs - hemp flex for preference to reduce upfront carbon even more. TF can work well with a brick skin as long as you allow adequate ventilation and effective protection for the insulation. Probably the best area to save UFC is in the foundations. These don't need to be concrete - a rubble trench foundation is as green as it gets and is perfectly acceptable to building control with a structural engineer's sign-off. As a plus, it is the quickest foundation type to make, and also act like a French drain to keep your walls bone dry.
Andehh Posted May 28 Posted May 28 Low carbon argument also stretches to building it to last, and preventing a need to repair and replace!!.. The most sustainable wall, is one that lasts a very very long time.
sgt_woulds Posted May 28 Posted May 28 True, and the oldest man-made structures on earth are made of mud bricks or cob on rubble trench foundations 🙂 There are also plenty of timber frame buildings in this country dating back more than 800 years. Combining the best features of all of these structures that will last the test of time is the ideal, as long-term savings in running costs and maintenance can then ameliorate any initial up-front carbon costs. So-called 'energy-efficient' monstrosities built using tonnes of concrete and bricks, but with a practical life measured in decades, is where we are at today, unfortunately. At least as a self-builder, you have the chance to build something better. Put your name on a little commemorative brick like the Victorians did, and someone can praise your efforts in 100 years...
SteamyTea Posted May 28 Posted May 28 23 minutes ago, sgt_woulds said: True, and the oldest man-made structures on earth are made of mud bricks or cob on rubble trench foundations This is a modification of the Doomsday arguenent, used by Prof. J Richard Gotta. Tends to hold true if you don't count the buildings that have failed and turned to dust.
sgt_woulds Posted May 28 Posted May 28 (edited) No, just stating a known fact 🙂 I may have been getting the wrong end of the stick, but I felt the inference from Andehh's comment was that TF and rubble trenches were inferior. I not stating that such a building would definitely last for thousands of years, merely that it could, based on extant evidence. As could any structure built with care, and with proper design and maintenance. Not something we can apply to most mass housebuilder efforts, nor the ego-boosting glass and concrete towers littering most major cities. I suspect most of these will be torn down or require a substantial rebuild in the next 50 years. Edited May 28 by sgt_woulds missing words
Oz07 Posted May 29 Posted May 29 Never really heard of rubble foundations. They look cool. Wonder how many one off builds get built with these over here.
